c8051F040液晶显示程序
#include "c8051F040.h"
#define uchar unsigned char
#define uint unsigned int
void os_init();
void adc_init();
uchar l;
uchar h;
uint temp;
uchar xdata virt_port;
bit SPI_BUSY;
unsigned char xdata tab1[12]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x2e,0x56};
sbit LCDCs=P2^5;
void os_init();
void port_init();
void spi_init();
void writecode(uchar ins);
void writEDAta(uchar d);
void lcdchar (void);
void lcdinit();
void writelcd(uchar spi_data);
*主函数
void main()
WDTCN = 0xDE; // 关闭看门狗
WDTCN = 0xAD;
os_init();
adc_init();
port_init();
spi_init();
lcdinit();
SFRPAGE = CONFIG_PAGE;
EIE2 = 0x02; //允许ADC中断
//IE = 0x80; //允许所有中断
EIE1 = 0x01;
EA=1;
while(1)
SFRPAGE = ADC0_PAGE;
AD0INT=0;
AD0BUSY=1;
while(AD0INT==0);
lcdinit();
lcdchar();
*晶振选择及时钟初始化函数
void os_init()
int i = 0;
OSCXCN = 0x67;
for (i = 0; i < 3000; i++); // 等待外部晶振稳定
while ((OSCXCN & 0x80) == 0);
CLKSEL = 0x01; //选择系统时钟频率
*12位ADC初始化
void adc_init()
REF0CN = 0x00; //0x03
ADC0CN = 0x80; //向AD0BUSY写1启动转换
*ADC中断函数
void adc_isr () interrupt 15
if(AD0INT==1)
{l=ADC0L;
h=ADC0H;
AD0INT=0;
void port_init()
P0MDOUT=0xff;
XBR0 = 0x06;
XBR2 = 0x40;
void spi_init()
SFRPAGE = SPI0_PAGE;
SPI0CFG = 0x40;
SPI0CN = 0x01;
SPI0CKR = 0x6D;
void delay1us(void)
uchar xdata i;
for(i=10;i>0;i--);
void writelcd(uchar spi_data) //向LV595写数据以SPI方式
uint xdata i,j,k;
for(i=0;i<9;i++);
LcdCs=0;
delay1us();
SPI_BUSY=1;
SPI0DAT=spi_data;
for(j=0;j<500;j++)
if(!SPI_BUSY)break;
delay1us();
LcdCs=1;
delay1us();
delay1us();
delay1us();
delay1us();
delay1us();
delay1us();
for(k=0;k<5000;k++);
void writecode(uchar ins) //向液晶控制模块写命令
uchar xdata t;
uint xdata j;
for(j=0;j<500;j++);
virt_port|=ins&0xf0; //取高字节向1602写数据
writelcd(virt_port); //先写高4位后再写低4位 这是在选择四个数据线的时候
virt_port|=0x08;
writelcd(virt_port); //使能E脚为高电平
virt_port&=~0x08;
writelcd(virt_port); //使能E脚为低电平
t=ins<<4;
virt_port|=t&0xf0; //取低字节向1602写数据
virt_port|=0x08; //使能E脚为高电平
virt_port&=~0x08; //使能E脚为低电平
virt_port=0;
void writedata(uchar d) //写数据到1602
uchar xdata i,t;
uint xdata j;
for(j=0;j<500;j++);
virt_port|=0x02; //光标返回指令
virt_port|=d&0xf0; //取高字节数据给数据寄存器
virt_port&=0xf7; //使能E脚为低电平
virt_port&=0x07; //设置光标右移,文字也右移
t=d&0x0f;
virt_port|=t<<4; //取低字节数据给数据寄存器
for(i=3;i>0;i--);
virt_port=0; //数据清零
void lcdchar (void)
uchar a,b,c,d;
h=h<<8;
temp=h+l;
temp=temp*250;
temp=temp/4096;
a=temp/1000;d=temp%1000;
if(a!=0)
writedata(tab1[a]); //除100
b=d/100;d=d%100;
writedata(tab1[b]);
writedata(tab1[10]);
c=d/10; d=d%10;
writedata(tab1[c]);
writedata(tab1[d]);
writedata(tab1[11]);
void lcdinit()
uint xdata i;
virt_port=0x00;
writelcd(virt_port); //RS脚为零写指令寄存器 RW为低电平
virt_port|=0x08; //使能脚E=1
virt_port&=0xf7; //使E=0使能脚发生跳变高--低
for(i=1000;i>0;i--); //3次延时,重要!
for(i=8000;i>0;i--); //用延时代替查询
virt_port=0; //写入20码,设置为4位总线方式,非常重要!!!!!
virt_port|=0x20; //只写高字节
virt_port|=0x08; //E=1
for(i=20;i>0;i--); //使命令执行
virt_port&=0xf7; //E=0
for(i=10;i>0;i--);
virt_port=0;
writecode(0x38); //设两行显示,4线方式5*10字符显示
for(i=50;i>0;i--);
writecode(0x06); //光标右移
for(i=50;i>0;i--);
writecode(0x0c); //开显示指令
for(i=50;i>0;i--);
writecode(0x02); //光标返回指令
for(i=50;i>0;i--);
writecode(0x01); //清屏指令
for(i=50;i>0;i--);
void spi_srs () interrupt 6
if(SPIF)
SPIF=0;
SPI_BUSY=0;
if(WCOL)
WCOL=0;
; FILE NAME : C8051F040.H
; TARGET MCUs : C8051F040, 'F041, 'F042, 'F043
; DESCRIPTION : Register/bit definitions for the C8051F04x product family.
; REVISION 1.2
; CHANGES from Rev. 1.1: Properly labLED sbit def's for CAN0STA
/* BYTE Registers */
sfr P0 = 0x80; /* PORT 0 */
sfr SP = 0x81; /* STACK POINTER */
sfr DPL = 0x82; /* DATA POINTER - LOW BYTE */
sfr DPH = 0x83; /* DATA POINTER - HIGH BYTE */
sfr SFRPAGE = 0x84; /* SFR PAGE SELECT */
sfr SFRNEXT = 0x85; /* SFR STACK NEXT PAGE */
sfr SFRLAST = 0x86; /* SFR STACK LAST PAGE */
sfr PCON = 0x87; /* POWER CONTROL */
sfr TCON = 0x88; /* TIMER CONTROL */
sfr CPT0CN = 0x88; /* COMPARATOR 0 CONTROL */
sfr CPT1CN = 0x88; /* COMPARATOR 1 CONTROL */
sfr CPT2CN = 0x88; /* COMPARATOR 2 CONTROL */
sfr TMOD = 0x89; /* TIMER MODE */
sfr CPT0MD = 0x89; /* COMPARATOR 0 MODE */
sfr CPT1MD = 0x89; /* COMPARATOR 1 MODE */
sfr CPT2MD = 0x89; /* COMPARATOR 2 MODE */
sfr TL0 = 0x8A; /* TIMER 0 - LOW BYTE */
sfr OSCICN = 0x8A; /* INTERNAL OSCILLATOR CONTROL */
sfr TL1 = 0x8B; /* TIMER 1 - LOW BYTE */
sfr OSCICL = 0x8B; /* INTERNAL OSCILLATOR CALIBRATION */
sfr TH0 = 0x8C; /* TIMER 0 - HIGH BYTE */
sfr OSCXCN = 0x8C; /* EXTERNAL OSCILLATOR CONTROL */
sfr TH1 = 0x8D; /* TIMER 1 - HIGH BYTE */
sfr CKCON = 0x8E; /* TIMER 0/1 CLOCK CONTROL */
sfr PSCTL = 0x8F; /* FLASH WRITE/ERASE CONTROL */
sfr P1 = 0x90; /* PORT 1 */
sfr SSTA0 = 0x91; /* UART 0 STATUS */
sfr SFRPGCN = 0x96; /* SFR PAGE CONTROL */
sfr CLKSEL = 0x97; /* SYSTEM CLOCK SELECT */
sfr SCON0 = 0x98; /* UART 0 CONTROL */
sfr SCON1 = 0x98; /* UART 1 CONTROL */
sfr SBUF0 = 0x99; /* UART 0 BUFFER */
sfr SBUF1 = 0x99; /* UART 1 BUFFER */
sfr SPI0CFG = 0x9A; /* SPI 0 CONFIGURATION */
sfr SPI0DAT = 0x9B; /* SPI 0 DATA */
sfr P4MDOUT = 0x9C; /* PORT 4 OUTPUT MODE */
sfr SPI0CKR = 0x9D; /* SPI 0 CLOCK RATE CONTROL */
sfr P5MDOUT = 0x9D; /* PORT 5 OUTPUT MODE */
sfr P6MDOUT = 0x9E; /* PORT 6 OUTPUT MODE */
sfr P7MDOUT = 0x9F; /* PORT 7 OUTPUT MODE */
sfr P2 = 0xA0; /* PORT 2 */
sfr EMI0TC = 0xA1; /* EMIF TIMING CONTROL */
sfr EMI0CN = 0xA2; /* EMIF CONTROL */
sfr EMI0CF = 0xA3; /* EMIF CONFIGURATION */
sfr P0MDOUT = 0xA4; /* PORT 0 OUTPUT MODE */
sfr P1MDOUT = 0xA5; /* PORT 1 OUTPUT MODE */
sfr P2MDOUT = 0xA6; /* PORT 2 OUTPUT MODE CONFIGURATION */
sfr P3MDOUT = 0xA7; /* PORT 3 OUTPUT MODE CONFIGURATION */
sfr IE = 0xA8; /* INTERRUPT ENABLE */
sfr SADDR0 = 0xA9; /* UART 0 SLAVE ADDRESS */
sfr SADDR1 = 0xA9; /* UART 1 SLAVE ADDRESS */
sfr P1MDIN = 0xAD; /* PORT 1 INPUT MODE */
sfr P2MDIN = 0xAE; /* PORT 2 INPUT MODE */
sfr P3MDIN = 0xAF; /* PORT 3 INPUT MODE */
sfr P3 = 0xB0; /* PORT 3 */
sfr FLSCL = 0xB7; /* FLASH TIMING PRESCALAR */
sfr FLACL = 0xB7; /* FLASH ACCESS LIMIT */
sfr IP = 0xB8; /* INTERRUPT PRIORITY */
sfr SADEN0 = 0xB9; /* UART 0 SLAVE ADDRESS MASK */
sfr AMX2CF = 0xBA; /* ADC 2 MUX CONFIGURATION */
sfr AMX0PRT = 0xBD; /* ADC 0 MUX PORT PIN SELECT REGISTER */
sfr AMX0CF = 0xBA; /* ADC 0 CONFIGURATION REGISTER */
sfr AMX0SL = 0xBB; /* ADC 0 AND ADC 1 MODE SELECTION */
sfr AMX2SL = 0xBB; /* ADC 2 MUX CHANNEL SELECTION */
sfr ADC0CF = 0xBC; /* ADC 0 CONFIGURATION */
sfr ADC2CF = 0xBC; /* ADC 2 CONFIGURATION */
sfr ADC0L = 0xBE; /* ADC 0 DATA - LOW BYTE */
sfr ADC2 = 0xBE; /* ADC 2 DATA - LOW BYTE */
sfr ADC0H = 0xBF; /* ADC 0 DATA - HIGH BYTE */
sfr SMB0CN = 0xC0; /* SMBUS 0 CONTROL */
sfr CAN0STA = 0xC0; /* CAN 0 STATUS */
sfr SMB0STA = 0xC1; /* SMBUS 0 STATUS */
sfr SMB0DAT = 0xC2; /* SMBUS 0 DATA */
sfr SMB0ADR = 0xC3; /* SMBUS 0 SLAVE ADDRESS */
sfr ADC0GTL = 0xC4; /* ADC 0 GREATER-THAN REGISTER - LOW BYTE */
sfr ADC2GT = 0xC4; /* ADC 2 GREATER-THAN REGISTER - LOW BYTE */
sfr ADC0GTH = 0xC5; /* ADC 0 GREATER-THAN REGISTER - HIGH BYTE */
sfr ADC0LTL = 0xC6; /* ADC 0 LESS-THAN REGISTER - LOW BYTE */
sfr ADC2LT = 0xC6; /* ADC 2 LESS-THAN REGISTER - LOW BYTE */
sfr ADC0LTH = 0xC7; /* ADC 0 LESS-THAN REGISTER - HIGH BYTE */
sfr TMR2CN = 0xC8; /* TIMER 2 CONTROL */
sfr TMR3CN = 0xC8; /* TIMER 3 CONTROL */
sfr TMR4CN = 0xC8; /* TIMER 4 CONTROL */
sfr P4 = 0xC8; /* PORT 4 */
sfr TMR2CF = 0xC9; /* TIMER 2 CONFIGURATION */
sfr TMR3CF = 0xC9; /* TIMER 3 CONFIGURATION */
sfr TMR4CF = 0xC9; /* TIMER 4 CONFIGURATION */
sfr RCAP2L = 0xCA; /* TIMER 2 CAPTURE REGISTER - LOW BYTE */
sfr RCAP3L = 0xCA; /* TIMER 3 CAPTURE REGISTER - LOW BYTE */
sfr RCAP4L = 0xCA; /* TIMER 4 CAPTURE REGISTER - LOW BYTE */
sfr RCAP2H = 0xCB; /* TIMER 2 CAPTURE REGISTER - HIGH BYTE */
sfr RCAP3H = 0xCB; /* TIMER 3 CAPTURE REGISTER - HIGH BYTE */
sfr RCAP4H = 0xCB; /* TIMER 4 CAPTURE REGISTER - HIGH BYTE */
sfr TMR2L = 0xCC; /* TIMER 2 - LOW BYTE */
sfr TMR3L = 0xCC; /* TIMER 3 - LOW BYTE */
sfr TMR4L = 0xCC; /* TIMER 4 - LOW BYTE */
sfr TMR2H = 0xCD; /* TIMER 2 - HIGH BYTE */
sfr TMR3H = 0xCD; /* TIMER 3 - HIGH BYTE */
sfr TMR4H = 0xCD; /* TIMER 4 - HIGH BYTE */
sfr SMB0CR = 0xCF; /* SMBUS 0 CLOCK RATE */
sfr PSW = 0xD0; /* PROGRAM STATUS WORD */
sfr REF0CN = 0xD1; /* VOLTAGE REFERENCE 0 CONTROL */
sfr DAC0L = 0xD2; /* DAC 0 REGISTER - LOW BYTE */
sfr DAC1L = 0xD2; /* DAC 1 REGISTER - LOW BYTE */
sfr DAC0H = 0xD3; /* DAC 0 REGISTER - HIGH BYTE */
sfr DAC1H = 0xD3; /* DAC 1 REGISTER - HIGH BYTE */
sfr DAC0CN = 0xD4; /* DAC 0 CONTROL */
sfr DAC1CN = 0xD4; /* DAC 1 CONTROL */
sfr HVA0CN = 0xD6; /* HVDA CONTROL REGISTER */
sfr PCA0CN = 0xD8; /* PCA 0 COUNTER CONTROL */
sfr CAN0DATL = 0xD8; /* CAN 0 DATA - LOW BYTE */
sfr P5 = 0xD8; /* PORT 5 */
sfr PCA0MD = 0xD9; /* PCA 0 COUNTER MODE */
sfr CAN0DATH = 0xD9; /* CAN 0 DATA - HIGH BYTE */
sfr PCA0CPM0 = 0xDA; /* PCA 0 MODULE 0 CONTROL */
sfr CAN0ADR = 0xDA; /* CAN 0 ADDRESS */
sfr PCA0CPM1 = 0xDB; /* PCA 0 MODULE 1 CONTROL */
sfr CAN0TST = 0xDB; /* CAN 0 TEST */
sfr PCA0CPM2 = 0xDC; /* PCA 0 MODULE 2 CONTROL */
sfr PCA0CPM3 = 0xDD; /* PCA 0 MODULE 3 CONTROL */
sfr PCA0CPM4 = 0xDE; /* PCA 0 MODULE 4 CONTROL */
sfr PCA0CPM5 = 0xDF; /* PCA 0 MODULE 5 CONTROL */
sfr ACC = 0xE0; /* ACCUMULATOR */
sfr PCA0CPL5 = 0xE1; /* PCA 0 MODULE 5 CAPTURE/COMPARE - LOW BYTE */
sfr XBR0 = 0xE1; /* CROSSBAR CONFIGURATION REGISTER 0 */
sfr PCA0CPH5 = 0xE2; /* PCA 0 MODULE 5 CAPTURE/COMPARE - HIGH BYTE */
sfr XBR1 = 0xE2; /* CROSSBAR CONFIGURATION REGISTER 1 */
sfr XBR2 = 0xE3; /* CROSSBAR CONFIGURATION REGISTER 2 */
sfr XBR3 = 0xE4; /* CROSSBAR CONFIGURATION REGISTER 3 */
sfr EIE1 = 0xE6; /* EXTERNAL INTERRUPT ENABLE 1 */
sfr EIE2 = 0xE7; /* EXTERNAL INTERRUPT ENABLE 2 */
sfr ADC0CN = 0xE8; /* ADC 0 CONTROL */
sfr ADC2CN = 0xE8; /* ADC 2 CONTROL */
sfr P6 = 0xE8; /* PORT 6 */
sfr PCA0CPL2 = 0xE9; /* PCA 0 MODULE 2 CAPTURE/COMPARE - LOW BYTE */
sfr PCA0CPH2 = 0xEA; /* PCA 0 MODULE 2 CAPTURE/COMPARE - HIGH BYTE */
sfr PCA0CPL3 = 0xEB; /* PCA 0 MODULE 3 CAPTURE/COMPARE - LOW BYTE */
sfr PCA0CPH3 = 0xEC; /* PCA 0 MODULE 3 CAPTURE/COMPARE - HIGH BYTE */
sfr PCA0CPL4 = 0xED; /* PCA 0 MODULE 4 CAPTURE/COMPARE - LOW BYTE */
sfr PCA0CPH4 = 0xEE; /* PCA 0 MODULE 4 CAPTURE/COMPARE - HIGH BYTE */
sfr RSTSRC = 0xEF; /* RESET SOURCE */
sfr B = 0xF0; /* B REGISTER */
sfr EIP1 = 0xF6; /* EXTERNAL INTERRUPT PRIORITY REGISTER 1 */
sfr EIP2 = 0xF7; /* EXTERNAL INTERRUPT PRIORITY REGISTER 2 */
sfr SPI0CN = 0xF8; /* SPI 0 CONTROL */
sfr CAN0CN = 0xF8; /* CAN 0 CONTROL */
sfr P7 = 0xF8; /* PORT 7 */
sfr PCA0L = 0xF9; /* PCA 0 TIMER - LOW BYTE */
sfr PCA0H = 0xFA; /* PCA 0 TIMER - HIGH BYTE */
sfr PCA0CPL0 = 0xFB; /* PCA 0 MODULE 0 CAPTURE/COMPARE - LOW BYTE */
sfr PCA0CPH0 = 0xFC; /* PCA 0 MODULE 0 CAPTURE/COMPARE - HIGH BYTE */
sfr PCA0CPL1 = 0xFD; /* PCA 0 MODULE 1 CAPTURE/COMPARE - LOW BYTE */
sfr PCA0CPH1 = 0xFE; /* PCA 0 MODULE 1 CAPTURE/COMPARE - HIGH BYTE */
sfr WDTCN = 0xFF; /* WATCHDOG TIMER CONTROL */
/* BIT Registers */
/* TCON 0x88 */
sbit TF1 = TCON ^ 7; /* TIMER 1 OVERFLOW FLAG */
sbit TR1 = TCON ^ 6; /* TIMER 1 ON/OFF CONTROL */
sbit TF0 = TCON ^ 5; /* TIMER 0 OVERFLOW FLAG */
sbit TR0 = TCON ^ 4; /* TIMER 0 ON/OFF CONTROL */
sbit IE1 = TCON ^ 3; /* EXT. INTERRUPT 1 EDGE FLAG */
sbit IT1 = TCON ^ 2; /* EXT. INTERRUPT 1 TYPE */
sbit IE0 = TCON ^ 1; /* EXT. INTERRUPT 0 EDGE FLAG */
sbit IT0 = TCON ^ 0; /* EXT. INTERRUPT 0 TYPE */
/* CPT0CN 0x88 */
sbit CP0EN = CPT0CN ^ 7; /* COMPARATOR 0 ENABLE */
sbit CP0OUT = CPT0CN ^ 6; /* COMPARATOR 0 OUTPUT */
sbit CP0RIF = CPT0CN ^ 5; /* COMPARATOR 0 RISING EDGE INTERRUPT */
sbit CP0FIF = CPT0CN ^ 4; /* COMPARATOR 0 FALLING EDGE INTERRUPT */
sbit CP0HYP1 = CPT0CN ^ 3; /* COMPARATOR 0 POSITIVE HYSTERESIS 1 */
sbit CP0HYP0 = CPT0CN ^ 2; /* COMPARATOR 0 POSITIVE HYSTERESIS 0 */
sbit CP0HYN1 = CPT0CN ^ 1; /* COMPARATOR 0 NEGATIVE HYSTERESIS 1 */
sbit CP0HYN0 = CPT0CN ^ 0; /* COMPARATOR 0 NEGATIVE HYSTERESIS 0 */
/* CPT1CN 0x88 */
sbit CP1EN = CPT1CN ^ 7; /* COMPARATOR 1 ENABLE */
sbit CP1OUT = CPT1CN ^ 6; /* COMPARATOR 1 OUTPUT */
sbit CP1RIF = CPT1CN ^ 5; /* COMPARATOR 1 RISING EDGE INTERRUPT */
sbit CP1FIF = CPT1CN ^ 4; /* COMPARATOR 1 FALLING EDGE INTERRUPT */
sbit CP1HYP1 = CPT1CN ^ 3; /* COMPARATOR 1 POSITIVE HYSTERESIS 1 */
sbit CP1HYP0 = CPT1CN ^ 2; /* COMPARATOR 1 POSITIVE HYSTERESIS 0 */
sbit CP1HYN1 = CPT1CN ^ 1; /* COMPARATOR 1 NEGATIVE HYSTERESIS 1 */
sbit CP1HYN0 = CPT1CN ^ 0; /* COMPARATOR 1 NEGATIVE HYSTERESIS 0 */
/* CPT2CN 0x88 */
sbit CP2EN = CPT2CN ^ 7; /* COMPARATOR 2 ENABLE */
sbit CP2OUT = CPT2CN ^ 6; /* COMPARATOR 2 OUTPUT */
sbit CP2RIF = CPT2CN ^ 5; /* COMPARATOR 2 RISING EDGE INTERRUPT */
sbit CP2FIF = CPT2CN ^ 4; /* COMPARATOR 2 FALLING EDGE INTERRUPT */
sbit CP2HYP1 = CPT2CN ^ 3; /* COMPARATOR 2 POSITIVE HYSTERESIS 1 */
sbit CP2HYP0 = CPT2CN ^ 2; /* COMPARATOR 2 POSITIVE HYSTERESIS 0 */
sbit CP2HYN1 = CPT2CN ^ 1; /* COMPARATOR 2 NEGATIVE HYSTERESIS 1 */
sbit CP2HYN0 = CPT2CN ^ 0; /* COMPARATOR 2 NEGATIVE HYSTERESIS 0 */
/* SCON0 0x98 */
sbit SM00 = SCON0 ^ 7; /* UART 0 MODE 0 */
sbit SM10 = SCON0 ^ 6; /* UART 0 MODE 1 */
sbit SM20 = SCON0 ^ 5; /* UART 0 MCE */
sbit REN0 = SCON0 ^ 4; /* UART 0 RX ENABLE */
sbit TB80 = SCON0 ^ 3; /* UART 0 TX BIT 8 */
sbit RB80 = SCON0 ^ 2; /* UART 0 RX BIT 8 */
sbit TI0 = SCON0 ^ 1; /* UART 0 TX INTERRUPT FLAG */
sbit RI0 = SCON0 ^ 0; /* UART 0 RX INTERRUPT FLAG */
/* SCON1 0x98 */
sbit S0MODE = SCON1 ^ 7; /* UART 1 MODE */
sbit MCE1 = SCON1 ^ 5; /* UART 1 MCE */
sbit REN1 = SCON1 ^ 4; /* UART 1 RX ENABLE */
sbit TB81 = SCON1 ^ 3; /* UART 1 TX BIT 8 */
sbit RB81 = SCON1 ^ 2; /* UART 1 RX BIT 8 */
sbit TI1 = SCON1 ^ 1; /* UART 1 TX INTERRUPT FLAG */
sbit RI1 = SCON1 ^ 0; /* UART 1 RX INTERRUPT FLAG */
/* IE 0xA8 */
sbit EA = IE ^ 7; /* GLOBAL INTERRUPT ENABLE */
sbit ET2 = IE ^ 5; /* TIMER 2 INTERRUPT ENABLE */
sbit ES0 = IE ^ 4; /* UART0 INTERRUPT ENABLE */
sbit ET1 = IE ^ 3; /* TIMER 1 INTERRUPT ENABLE */
sbit EX1 = IE ^ 2; /* EXTERNAL INTERRUPT 1 ENABLE */
sbit ET0 = IE ^ 1; /* TIMER 0 INTERRUPT ENABLE */
sbit EX0 = IE ^ 0; /* EXTERNAL INTERRUPT 0 ENABLE */
/* IP 0xB8 */
sbit PT2 = IP ^ 5; /* TIMER 2 PRIORITY */
sbit PS = IP ^ 4; /* SERIAL PORT PRIORITY */
sbit PT1 = IP ^ 3; /* TIMER 1 PRIORITY */
sbit PX1 = IP ^ 2; /* EXTERNAL INTERRUPT 1 PRIORITY */
sbit PT0 = IP ^ 1; /* TIMER 0 PRIORITY */
sbit PX0 = IP ^ 0; /* EXTERNAL INTERRUPT 0 PRIORITY */
/* SMB0CN 0xC0 */
sbit BUSY = SMB0CN ^ 7; /* SMBUS 0 BUSY */
sbit ENSMB = SMB0CN ^ 6; /* SMBUS 0 ENABLE */
sbit STA = SMB0CN ^ 5; /* SMBUS 0 START FLAG */
sbit STO = SMB0CN ^ 4; /* SMBUS 0 STOP FLAG */
sbit SI = SMB0CN ^ 3; /* SMBUS 0 INTERRUPT PENDING FLAG */
sbit AA = SMB0CN ^ 2; /* SMBUS 0 ASSERT/ACKNOWLEDGE FLAG */
sbit SMBFTE = SMB0CN ^ 1; /* SMBUS 0 FREE TIMER ENABLE */
sbit SMBTOE = SMB0CN ^ 0; /* SMBUS 0 TIMEOUT ENABLE */
/* CAN0STA 0xC0 */
sbit BOFF = CAN0STA ^ 7; /* Bus Off Status */
sbit EWARN = CAN0STA ^ 6; /* Warning Status */
sbit EPASS = CAN0STA ^ 5; /* Error Passive */
sbit RXOK = CAN0STA ^ 4; /* Received Message Successfully */
sbit TXOK = CAN0STA ^ 3; /* Transmit a Message Successfully */
sbit LEC2 = CAN0STA ^ 2; /* Last error code bit 2 */
sbit LEC1 = CAN0STA ^ 1; /* Last error code bit 1 */
sbit LEC0 = CAN0STA ^ 0; /* Last error code bit */
/* TMR2CN 0xC8 */
sbit TF2 = TMR2CN ^ 7; /* TIMER 2 OVERFLOW FLAG */
sbit EXF2 = TMR2CN ^ 6; /* TIMER 2 EXTERNAL FLAG */
sbit EXEN2 = TMR2CN ^ 3; /* TIMER 2 EXTERNAL ENABLE FLAG */
sbit TR2 = TMR2CN ^ 2; /* TIMER 2 ON/OFF CONTROL */
sbit CT2 = TMR2CN ^ 1; /* TIMER 2 COUNTER SELECT */
sbit CPRL2 = TMR2CN ^ 0; /* TIMER 2 CAPTURE SELECT */
/* TMR3CN 0xC8 */
sbit TF3 = TMR3CN ^ 7; /* TIMER 3 OVERFLOW FLAG */
sbit EXF3 = TMR3CN ^ 6; /* TIMER 3 EXTERNAL FLAG */
sbit EXEN3 = TMR3CN ^ 3; /* TIMER 3 EXTERNAL ENABLE FLAG */
sbit TR3 = TMR3CN ^ 2; /* TIMER 3 ON/OFF CONTROL */
sbit CT3 = TMR3CN ^ 1; /* TIMER 3 COUNTER SELECT */
sbit CPRL3 = TMR3CN ^ 0; /* TIMER 3 CAPTURE SELECT */
/* TMR4CN 0xC8 */
sbit TF4 = TMR4CN ^ 7; /* TIMER 4 OVERFLOW FLAG */
sbit EXF4 = TMR4CN ^ 6; /* TIMER 4 EXTERNAL FLAG */
sbit EXEN4 = TMR4CN ^ 3; /* TIMER 4 EXTERNAL ENABLE FLAG */
sbit TR4 = TMR4CN ^ 2; /* TIMER 4 ON/OFF CONTROL */
sbit CT4 = TMR4CN ^ 1; /* TIMER 4 COUNTER SELECT */
sbit CPRL4 = TMR4CN ^ 0; /* TIMER 4 CAPTURE SELECT */
/* PSW 0xD0 */
sbit CY = PSW ^ 7; /* CARRY FLAG */
sbit AC = PSW ^ 6; /* AUXILIARY CARRY FLAG */
sbit F0 = PSW ^ 5; /* USER FLAG 0 */
sbit RS1 = PSW ^ 4; /* REGISTER BANK SELECT 1 */
sbit RS0 = PSW ^ 3; /* REGISTER BANK SELECT 0 */
sbit OV = PSW ^ 2; /* OVERFLOW FLAG */
sbit F1 = PSW ^ 1; /* USER FLAG 1 */
sbit P = PSW ^ 0; /* ACCUMULATOR PARITY FLAG */
/* PCA0CN 0xD8 */
sbit CF = PCA0CN ^ 7; /* PCA 0 COUNTER OVERFLOW FLAG */
sbit CR = PCA0CN ^ 6; /* PCA 0 COUNTER RUN CONTROL BIT */
sbit CCF5 = PCA0CN ^ 5; /* PCA 0 MODULE 5 INTERRUPT FLAG */
sbit CCF4 = PCA0CN ^ 4; /* PCA 0 MODULE 4 INTERRUPT FLAG */
sbit CCF3 = PCA0CN ^ 3; /* PCA 0 MODULE 3 INTERRUPT FLAG */
sbit CCF2 = PCA0CN ^ 2; /* PCA 0 MODULE 2 INTERRUPT FLAG */
sbit CCF1 = PCA0CN ^ 1; /* PCA 0 MODULE 1 INTERRUPT FLAG */
sbit CCF0 = PCA0CN ^ 0; /* PCA 0 MODULE 0 INTERRUPT FLAG */
/* ADC0CN 0xE8 */
sbit AD0EN = ADC0CN ^ 7; /* ADC 0 ENABLE */
sbit AD0TM = ADC0CN ^ 6; /* ADC 0 TRACK MODE */
sbit AD0INT = ADC0CN ^ 5; /* ADC 0 EOC INTERRUPT FLAG */
sbit AD0BUSY = ADC0CN ^ 4; /* ADC 0 BUSY FLAG */
sbit AD0CM1 = ADC0CN ^ 3; /* ADC 0 CONVERT START MODE BIT 1 */
sbit AD0CM0 = ADC0CN ^ 2; /* ADC 0 CONVERT START MODE BIT 0 */
sbit AD0WINT = ADC0CN ^ 1; /* ADC 0 WINDOW INTERRUPT FLAG */
/* ADC2CN 0xE8 */
sbit AD2EN = ADC2CN ^ 7; /* ADC 2 ENABLE */
sbit AD2TM = ADC2CN ^ 6; /* ADC 2 TRACK MODE */
sbit AD2INT = ADC2CN ^ 5; /* ADC 2 EOC INTERRUPT FLAG */
sbit AD2BUSY = ADC2CN ^ 4; /* ADC 2 BUSY FLAG */
sbit AD2WINT = ADC2CN ^ 3; /* ADC 2 WINDOW INTERRUPT FLAG */
sbit AD2CM2 = ADC2CN ^ 2; /* ADC 2 CONVERT START MODE BIT 2 */
sbit AD2CM1 = ADC2CN ^ 1; /* ADC 2 CONVERT START MODE BIT 1 */
sbit AD2CM0 = ADC2CN ^ 0; /* ADC 2 CONVERT START MODE BIT 0 */
/* SPI0CN 0xF8 */
sbit SPIF = SPI0CN ^ 7; /* SPI 0 INTERRUPT FLAG */
sbit WCOL = SPI0CN ^ 6; /* SPI 0 WRITE COLLISION FLAG */
sbit MODF = SPI0CN ^ 5; /* SPI 0 MODE FAULT FLAG */
sbit RXOVRN = SPI0CN ^ 4; /* SPI 0 RX OVERRUN FLAG */
sbit NSSMD1 = SPI0CN ^ 3; /* SPI 0 SLAVE SELECT MODE BIT 1 */
sbit NSSMD0 = SPI0CN ^ 2; /* SPI 0 SLAVE SELECT MODE BIT 0 */
sbit TXBMT = SPI0CN ^ 1; /* SPI 0 TX BUFFER EMPTY */
sbit SPIEN = SPI0CN ^ 0; /* SPI 0 SPI ENABLE */
/* CAN0CN 0xF8 */
sbit CANINIT = CAN0CN ^ 0; /* CAN Initialization bit */
sbit CANIE = CAN0CN ^ 1; /* CAN Module Interrupt Enable Bit */
sbit CANSIE = CAN0CN ^ 2; /* CAN Status change Interrupt Enable Bit */
sbit CANEIE = CAN0CN ^ 3; /* CAN Module Error Interrupt Enable Bit */
sbit CANIF = CAN0CN ^ 4; /* CAN Module Interrupt Flag */
sbit CANDAR = CAN0CN ^ 5; /* CAN DISAble Automatic Retransmission bit */
sbit CANCCE = CAN0CN ^ 6; /* CAN Configuration Change Enable bit */
sbit CANTEST = CAN0CN ^ 7; /* CAN Test Mode Enable bit */
/* SFR PAGE DEFINITIONS */
#define CONFIG_PAGE 0x0F /* SYSTEM AND PORT CONFIGURATION PAGE */
#define LEGACY_PAGE 0x00 /* LEGACY SFR PAGE */
#define TIMER01_PAGE 0x00 /* TIMER 0 AND TIMER 1 */
#define CPT0_PAGE 0x01 /* COMPARATOR 0 */
#define CPT1_PAGE 0x02 /* COMPARATOR 1 */
#define CPT2_PAGE 0x03 /* COMPARATOR 2 */
#define UART0_PAGE 0x00 /* UART 0 */
#define UART1_PAGE 0x01 /* UART 1 */
#define SPI0_PAGE 0x00 /* SPI 0 */
#define EMI0_PAGE 0x00 /* EXTERNAL MEMORY INTERFACE */
#define ADC0_PAGE 0x00 /* ADC 0 */
#define ADC2_PAGE 0x02 /* ADC 2 */
#define SMB0_PAGE 0x00 /* SMBUS 0 */
#define TMR2_PAGE 0x00 /* TIMER 2 */
#define TMR3_PAGE 0x01 /* TIMER 3 */
#define TMR4_PAGE 0x02 /* TIMER 4 */
#define DAC0_PAGE 0x00 /* DAC 0 */
#define DAC1_PAGE 0x01 /* DAC 1 */
#define PCA0_PAGE 0x00 /* PCA 0 */
#define CAN0_PAGE 0x01 /* CAN 0 */
上一篇:c8051f005单片机PWM测试程序
下一篇:c8051f005键盘测试程序
推荐阅读最新更新时间:2024-03-16 15:51
