AVR开发笔记——熔丝位
发布者:古古斋最新更新时间:2018-05-18 来源: eefocus关键字:AVR  熔丝位 手机看文章 扫描二维码
随时随地手机看文章
1、首先是stm32f10x.h中的HSE_VALUE
#if !defined  HSE_VALUE
 #ifdef STM32F10X_CL
 #define HSE_VALUE    ((uint32_t)12000000)//这里修改为12MHz
//  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */注释掉
 #else
  #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
 #endif /* STM32F10X_CL */
#endif /* HSE_VALUE */
2、修改分频/倍频系数使系统时钟变为72MHz
在system_stm32f10x.c的void SystemInit (void)函数下有一个SetSysClock()继续找static void SetSysClock(void)下的SetSysClockTo72();修改后如下一段代码:
其中被注释掉的部分为原来的代码。
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
//    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
//                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    //HSE =  12 PLL2CLK = (HSE / 3) * 10 = 40 MHz
        RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV3 | RCC_CFGR2_PLL2MUL10 |
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR & RCC_CR_PLL2RDY) == 0)
//    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
//    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
//    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
//                            RCC_CFGR_PLLMULL9);
                                                            RCC_CFGR_PLLMULL6);
#else
//    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
//    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
//                                        RCC_CFGR_PLLMULL));
//    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
                                        RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
关键字:AVR  熔丝位 引用地址:AVR开发笔记——熔丝位
上一篇:AVR 启动时间 设置方法
下一篇:AVR的bootloader的设置
推荐阅读最新更新时间:2024-03-16 16:03
基于AVR单片机的臭氧治疗仪设计方案
臭氧作为一种高效冷杀菌手段,目前已经被广泛应用在各行各业中。具有高效、迅速杀菌作用的臭氧在医院环境消毒、术前消毒等方面应用广泛,其治疗效果优于其它传统杀菌治疗仪。因此研制一种运行稳定、使用方便、便携的臭氧治疗仪产品,为妇科疾病患者提供一种方便有效的在家治疗方式,具有实际意义。 目前市面上的同类型产品都是采用80C51单片机为控制核心的, 虽然也能实现它所需求的功能,但执行速度慢,在长期工作环境中,特别在臭氧治疗仪的内部大功率气泵模块和臭氧发生器的干扰下,系统功耗高和抗干扰性能差,系统性能不稳定等问题便凸现出来。对此本文采用了ATMEL公司的一款AVR高档单片机,对控制系统作了改进,提高了整机的性能。 臭氧产生的原理及方
[单片机]
基于<font color='red'>AVR</font>单片机的臭氧治疗仪设计方案
SD卡接口程序(AVR)
SD卡接口程序/******************************************/ /* SD Code for M32L */ /* By pasyong */ /* 2006-4 */ /* Base ICC6.31A */ /************************************************************/ #include iom32v.h #include macros.h #include 1011.h #define uchar unsigned char #define uint uns
[单片机]
AVR单片机基础介绍
AVR单片机是ATMEL公司研制开发的一种新型单片机,它与51单片机、PIC单片机相比具有一系列的优点: 1:在相同的系统时钟下AVR运行速度最快; 2: 芯片内部的Flsah、EEPROM、SRAM容量较大; 3:所有型号的Flash、EEPROM都可以反复烧写、全部支持在线编程烧写(ISP); 4:多种频率的内部RC振荡器、上电自动复位、看门狗、启动延时等功能,零外围电路也可以工作; 5:每个IO口都可以以推换驱动的方式输出高、低电平,驱动能力强; 6:内部资源丰富,一般都集成AD、DA模数器;PWM;SPI、USART、TWI、I2C通信口;丰富的中断源等。 目前支持AVR单片机编译器的语言主要有
[单片机]
[AVR]高压并行编程---基础知识
一、接线方式及端口定义                      RDY/BSY 判忙标志位。(0:设备正忙 1:等待新的命令) OE 输出使能位 低电平有效 WR 写脉冲 低电平有效 BS 字节选择1(0:选择低位字节 1:选择高位字节) XA XTAL动作位 00加载Flash或者EEPROM地址 01加载数据 10加载命令 11保留 PAGEL 加载程序存储器和EEPROM数据页 DATA 双向数据/命令口 0x80 芯片擦除 0x40 写熔丝位 0x20 写锁定位 0x10 写FLASH 0x11 写EEPROM 0x08 读标示字节和校准字节 0x04 读熔丝位及锁定位 0
[单片机]
[<font color='red'>AVR</font>]高压并行编程---基础知识
使用AVRStudio设置AVR熔丝位及烧写程序
AVR Studio是ATMEL指定用于开发AVR MCU的官方软件,其编程功能最为强大。下面介绍使用AVRStudio烧写程序及熔丝快速入门。   ● 使用AVRISP方式烧写程序及配置熔丝位   对软硬件进行初始配置,并正确设备连接,就可使用AVRISP进行联机了。   打开AVRStudio,点击主窗口中的图标 前面标有Con的那个图标。出现如下图画面: (点击图片放大)   在左边,选择“STK500 or AVRISP”,在右边,选择“Auto”(或具体的COM口),点击“Connect”进行联机。   正常联机后,将弹出如下窗口:   (1)程序编程面板: (点击图片放大) ● Device里面选择好对应
[单片机]
使用AVRStudio设置<font color='red'>AVR</font><font color='red'>熔丝位</font>及烧写程序
AVR基本硬件线路设计与分析
基本的AVR硬件线路,包括以下几部分: 1、复位线路 2、晶振线路 3、AD转换滤波线路 4、ISP下载接口 5、JTAG仿真接口 6、电源 下面以本网站推荐的AVR入门芯片 ATmega16L-8AI 分析上述基本线路。(-8AI表示8M频率的TQFP贴片封装,工业级,更详细的型号含义资料,请参考:AVR芯片入门知识) 复位线路的设计 Mega16已经内置了上电复位设计。并且在熔丝位里,可以控制复位时的额外时间,故AVR外部的复位线路在上电时,可以设计得很简单:直接拉一只10K的电阻到VCC即可(R0)。为了可靠,再加上一只0.1uF的电容(C0)以消除干扰、杂波。 D3(1N4148)的作用有两个:作用
[单片机]
<font color='red'>AVR</font>基本硬件线路设计与分析
AVR M16 8M 的DS18B20头文件
只需调用gettemp();就可以了!出口参数wmh是显示的高位,wml使显示的低位,然后调用你的显示程序就可以了! /************************************************************************* ds18b20头文件 M16 内部8M *************************************************************************/ #define CLR_DIR_1WIRE DDRC&=~BIT(2) //只要修改这里的参数就可以了!呵呵! #define SET_DIR_1WIRE
[单片机]
AVR工具指南(二)
ATMEL公司的AVR单片机,是增强型RISC内载Flash的单片机,芯片上的Flash存储器附在用户的产品中,可随时编程,再编程,使用户的产品设计容易,更新换代方便。AVR单片机采用增强的RISC结构 ,使其具有高速处理能力,在一个时钟周期内可执行复杂的指令,每MHz可实现1MIPS的处理能力。AVR单片机工作电压为2.7-6.0V,可以实现耗电最优化。AVR的单片机广泛应用于计算机外部设备 ,工业实时控制,仪器仪表,通讯设备,家用电器,宇航设备等各个领域。 继续 AVR工具指南(一) 的内容 3. WinCUPL WinCUPL(可编程逻辑通用编译器)是一款可以为SPLD和CPLD创造出非常复杂的逻辑设计的逻辑编译器。该
[单片机]
<font color='red'>AVR</font>工具指南(二)
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
