以前一直搞不明明白,2440 的中断向量表为什么会是在 _ISR_STARTADDRESS=0x33FF_FF00?cpu是这么跳转到这个位置的? 在零地址的终端向量表有做什么用。
今天有空,仔细研究了下,终于看清楚了。
注意一下代码:
ENTRY
;1)The code, which converts to Big-endian, should be in little endian code.
;2)The following little endian code will be compiled in Big-Endian mode.
; The code byte order should be changed as the memory bus width.
;3)The pseudo instruction,DCD can't be used here because the linker generates error.
ASSERT :DEF:ENDIAN_CHANGE
[ ENDIAN_CHANGE
ASSERT :DEF:ENTRY_BUS_WIDTH
[ ENTRY_BUS_WIDTH=32
b ChangeBigEndian ;DCD 0xea000007
[ ENTRY_BUS_WIDTH=16
andeq r14,r7,r0,lsl #20 ;DCD 0x0007ea00
[ ENTRY_BUS_WIDTH=8
streq r0,[r0,-r10,ror #1] ;DCD 0x070000ea
b ResetHandler
b HandlerUndef ;handler for Undefined mode
b HandlerSWI ;handler for SWI interrupt
b HandlerPabort ;handler for PAbort
b HandlerDabort ;handler for DAbort
b . ;reserved
b HandlerIRQ ;handler for IRQ interrupt
b HandlerFIQ ;handler for FIQ interrupt ENTRY
[ ENDIAN_CHANGE
[ ENTRY_BUS_WIDTH=8
b ResetHandler
b . ;reserved
以上代码就是中断向量,这个不用怀疑。
MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
sub sp,sp,#4 ;decrement sp(to store jump address)
stmfd sp!,{r0} ;PUSH the work register to stack(lr does't push because it return to original address)
ldr r0,=$HandleLabel;load the address of HandleXXX to r0
ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX
str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR)
MEND
这个是宏定义
LTORG
HandlerFIQ HANDLER HandleFIQ
HandlerIRQ HANDLER HandleIRQ
HandlerUndef HANDLER HandleUndef
HandlerSWI HANDLER HandleSWI
HandlerDabort HANDLER HandleDabort
HandlerPabort HANDLER HandlePabort
中断向量函数, 注意:HandlerIRQ HANDLER HandleIRQ 会根据上面的宏展开。
AREA RamData, DATA, READWRITE
^ _ISR_STARTADDRESS ; _ISR_STARTADDRESS=0x33FF_FF00
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
定义在 0x33FF_FF00 位置的中断向量表。
基本上代码的流程是,每次中断到达后,还是执行 0 地址的中断向量表,中断向量调用HandlerIRQ HANDLER HandleIRQ,HandlerIRQ HANDLER HandleIRQ 展开后,实际执行 HandleIRQ # 4。
另外需要注意的是,mmu 的设置 MMU_SetMTT(0x00000000,0x07f00000,(int)__ENTRY,RW_CNB); 保证 (int)__ENTRY 的位置永远在 0x00000000;
上一篇:keil5(MDK5)配置S3C2440裸机开发调试环境
下一篇:S3C2440体系架构
推荐阅读最新更新时间:2024-03-16 16:04
