基于STM32的虚拟多线程
发布者:SereneSoul55最新更新时间:2018-06-10 来源: eefocus关键字:STM32  虚拟多线程 手机看文章 扫描二维码
随时随地手机看文章
基于STM32的虚拟多线程,可以很好的用于裸机程序中,用于模拟小型操作系统的多线程概念。本实例参考了参考TI_BLE协议栈_ZStack协议栈。
#include "Hal_Led/Hal_Led.h"
#include "Hal_delay/delay.h"
#include "Hal_Key/Hal_Key.h"
#include "ringbuffer.h"
#define APP_LED2_BLINK_EVENT   0x0001
#define HAL_LED1_BLINK_EVENT   0x0001
#define TASK_NO_TASK_RUNNING      0xFF
unsigned short Hal_ProcessEvent( unsigned char task_id, unsigned short events );
unsigned short App_ProcessEvent( unsigned char task_id, unsigned short events );
typedef unsigned short  uint16;
typedef unsigned char   uint8;
#define TASK_CNT  2    //定义线程的个数
//定义函数指针
typedef unsigned short (*pTaskEventHandlerFn)( unsigned char task_id, unsigned short events );
//线程函数表
const pTaskEventHandlerFn tasksArr[] =
    Hal_ProcessEvent,
    App_ProcessEvent
const unsigned char tasksCnt = sizeof( tasksArr ) / sizeof( tasksArr[0] );
//uint16 *tasksEvents;
uint16 tasksEvents[TASK_CNT] = {0};  //每个线程有16位位域空间用于设置事件
static uint8 activeTaskID = 0xFF;  //当前任务ID,指示作用
#define SUCCESS                   0x00
#define FAILURE                   0x01
#define INVALID_TASK              0x02
uint8 osal_set_event( uint8 task_id, uint16 event_flag )
    if ( task_id < tasksCnt )
        tasksEvents[task_id] |= event_flag;  // Stuff the event bit(s)
        return ( SUCCESS );
    else
        return ( INVALID_TASK );
* @brief 程序入口
* @param none
* @return none
int main(void)
    unsigned short taskID = 0;
    uint8 idx = 0;
    SystemInit();  //系统时钟初始化
    delayInit(72); //滴答定时器初始化
    Led_Init();    //LED初始化
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    osal_set_event(0, HAL_LED1_BLINK_EVENT);
    osal_set_event(1, APP_LED2_BLINK_EVENT);
    while(1)
        do
            if(tasksEvents[idx])  //轮训获知哪个线程有事件需要进行处理
                break;
        while (++idx < tasksCnt);
        if (idx < tasksCnt)
            uint16 events;
            events = tasksEvents[idx];
            tasksEvents[idx] = 0;                    // 清除事件数组中的事件
            activeTaskID = idx;
            events = (tasksArr[idx])( idx, events ); //调用线程函数
            activeTaskID = TASK_NO_TASK_RUNNING;
            tasksEvents[idx] |= events;  // 添加未处理的事件到本线程的事件组中
        delayMs(1000);
* @brief 应用层处理
* @param none
* @r
    if ( events & HAL_LED1_BLINK_EVENT )
        Led_Reverse(1);
        return events ^ HAL_LED1_BLINK_EVENT;  //清除事件
* @brief 硬件控制线程
* @param none
* @r
    if ( events & APP_LED2_BLINK_EVENT )
        Led_Reverse(2);
        return events ^ APP_LED2_BLINK_EVENT;  //清除事件
关键字:STM32  虚拟多线程 引用地址:基于STM32的虚拟多线程
上一篇:STM32 printf函数打印到串口
下一篇:基于stm32串口环形缓冲队列处理机制—入门级(单字节)
推荐阅读最新更新时间:2024-03-16 16:05
STM32 的 SWD调试模式
SWD:Serial Wire Debug 串行线调试 我们比较常用的是Jlink下载器 ,这种下载器有一个缺点就是使用的Jtag 20PIN接口,太多的PIN会导致一些小型的PCB板很拥挤,也会增加布线的难度。 而使用SWD接口下载调试,只需要要使用4个PIN: GND, RST, SWDIO, SWDCLK ,而且下载速度可以达到10M/s,优势显而易见。 以下转自: http://www.openedv.com/posts/list/187.htm 对于JTAG和SWD的使用区别,觉得下面这篇文章讲的比较清晰了,所以转帖到这里,希望对新手有所帮助。 SWD与JTAG区别及使用情况 上图
[单片机]
<font color='red'>STM32</font> 的 SWD调试模式
stm32基础知识汇总,看有多少是没有深入学习的
  STM32是一种功能比较强大的32位单片机,广泛应用于各种嵌入式设备中,由于它的普及性及丰富的资源,受到广大嵌入式开发者的喜欢,但要想学好用好STM32也并非易事,毕竟,相比8位、16位产品,STM32要复杂得多。   STM32的时钟   其中,高速时钟(HSE和HSI)提供给芯片主体的主时钟.低速时钟(LSE和LSI)只是提供给芯片中的RTC(实时时钟)及独立看门狗使用,图中可以看出高速时钟也可以提供给RTC。内部时钟是在芯片内部RC振荡器产生的,起振较快,所以时钟在芯片刚上电的时候,默认使用内部高速时钟。而外部时钟信号是由外部的晶振输入的,在精度和稳定性上都有很大优势,所以上电之后我们再通过软件配置,转而采用外部时钟信
[单片机]
STM32:stm32f10x_gpio.c中GPIO_Init的分析说明
1 /** 2 *函数功能:初始化引脚模式 3 *参数说明:GPIOx,该参数为GPIO_TypeDef 类型的指针,指向GPIO 端口的地址 4 * GPIO_InitTypeDef:GPIO_InitTypeDef 结构体指针,指向初始化变量 5 */ 6 void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) 7 { 8 uint32_t currentmode =0x00,currentpin = 0x00,pinpos = 0x00,pos = 0x00; 9 uint32_t tmpreg = 0x00, pinmas
[单片机]
嵌入式开发:STM32 FSMC接口驱动TFT-LCD设计
TFT-LCD技术是微电子技术和LCD技术巧妙结合的高新技术。随着人们对图像清晰度、刷新率、保真度的要求越来越高,TFT-LCD的应用范围越来越广。本文提出了一种能直接驱动数字液晶屏的设计方案,方案先介绍了TFT数字彩屏的工作原理,利用STM32处理器的FSMC接口设计的硬件电路和软件程序均能对显示控制芯片进行有效的控制。在实际应用中显示清晰流畅,并且CPU有足够的时间来处理用户程序。该方案能成功应用在电脑横机的人机界面显示中,且其硬件电路结构简单、控制方式灵活、对于其他型号的接口芯片也能提供参考。 0 引言 随着电子产品的不断更新,各种显示界面的开发越来越多,由于TFT彩屏的性价比高,因而被广泛用在各种电子设备上作为显示屏。目前
[单片机]
嵌入式开发:<font color='red'>STM32</font> FSMC接口驱动TFT-LCD设计
基于STM32处理器的定时开关装置设计
本文针对市场上现有的定时开关装置的弊端,设计了一种基于STM32处理器的定时开关装置。该装置利用GSM网络实现远程遥控功能,并通过nRF24L0l+无线通信模块,遥控在一定范围内任意分布的多个开关。系统具有友好的人机交流界面,可设置多组定时时间,以及触摸屏控制、掉电保护和红外遥控等功能。 目前,国内市场上出现了多种定时开关产品,并被广泛应用于家居生活、汽车服务、公共照明和仓库管理等领域。其中大部分产品都只有简单的定时功能;无法实现遥控、显示等高级功能。而少数可遥控的产品也只局限于较近距离的范围内,并未实现远程控制,这些降低了它的便利性和实用性。随着科技的进步,人们向往智能化、节约化的家居生活,各种网络家电应运而生,但其高
[单片机]
基于<font color='red'>STM32</font>处理器的定时开关装置设计
STM32初学笔记3之外部中断
学习的第三部分,我选择了外部中断,因为个人觉得除了时序问题,我们应用的最多的就要数中断了,当然还有一个定时器还没学,呵呵,只能往后放一下了。当然,我不打算花太多时间去搞GPIO,所以就自己看了一下手册,能用就行了。 反正学习这些东西还是根据个人的习惯吧,我学习主要也就是参考ST给的示例程序,反正还是很有用的。今天花了差不多两个小时的时间根据EXTI的示例程序自己编写了一个程序,最后在ALIENTEK上面运行成功,下面将示例代码展示如下: 笔者将跟硬件平台有关的配置放在一个板级支持包的源文件里面,具体请查看: 板级支持包的应用 一文。 一、GPIO的配置 二、嵌入向量中断控制器配置 三、中断服务程序 说
[单片机]
<font color='red'>STM32</font>初学笔记3之外部中断
STM32单片机的复用端口初始化的步骤及方法
STM32有好几个串口。比如说STM32F103ZET6有5个串口,串口1的引脚对应的IO为PA9,PA10.PA9,PA10默认功能是GPIO,所以当PA9,PA10引脚作为串口1的TX,RX引脚使用的时候,那就是端口复用。 复用端口初始化有几个步骤: 1) GPIO端口时钟使能。要使用到端口复用,当然要使能端口的时钟了。 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); 2) 复用的外设时钟使能。比如你要将端口PA9,PA10复用为串口,所以要使能串口时钟。 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
[单片机]
<font color='red'>STM32</font>单片机的复用端口初始化的步骤及方法
意法半导体新型STM32系列获ARM RealView微控制器开发工具包支持
中国上海,2007年6月27日 —— ARM公司(伦敦证交所:ARM;纳斯达克:ARMHY)宣布即日起,RealView微控制器开发工具包将支持意法半导体基于ARM Cortex-M3处理器的全新 STM32F1xx系列器件。    STM32F101 (接入行)和STM32F103 (性能行)将是意法半导体首个基于ARM Cortex-M3处理器的器件系列,兼具卓越的高性能和低功耗,待机功耗仅为2?A。该系列器件拥有高达72MHz的CPU时钟速度、128Kbyte片上闪存ROM及20Kbyte片上RAM,还包括A/D、CAN、USB、SPI、I2C等众多外设及多达80个GPIO。    RealView微控制器开发工具包3.1可
[新品]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
