51单片机之LCD1602的驱动程序
发布者:温柔微笑最新更新时间:2018-06-25 来源: eefocus关键字:51单片机  LCD1602  驱动程序 手机看文章 扫描二维码
随时随地手机看文章
  1. #include
  2. #include "./delay/delay.h"
  3.
  4. #define LCDPORT P0
  5. #define LCD_WRITE_DATA   1
  6. #define LCD_WRITE_COM    0
  7. sbit RS = P2^4;
  8. sbit RW = P2^5;
  9. sbit E = P2^6;
  10. unsigned char flag = 1;
  11. unsigned char shi = 23, fen = 59, miao = 50;
  12.
  13. void lcd1602_write(unsigned char byte, unsigned char flag)
  14. {
  15.         if(flag)
  16.         {
  17.                 RS = 1;                    //选择输入的数据为数据
  18.         }
  19.         else
  20.         {
  21.                 RS = 0;                      //选择输入的数据为命令
  22.         }
  23.         RW = 0;                           //写
  24.         E = 1;                            //选中lcd
  25.         LCDPORT = byte;
  26.         delay_ms(5);
  27.         E = 0;                          //失能LCD      高电平有效
  28.
  29. }
  30.
  31. void lcd_init()
  32. {
  33.         delay_ms(15);
  34.       lcd1602_write(0x38,LCD_WRITE_COM);     //设置8位数据接口,两行指令,5*8点阵字符
  35.       delay_ms(5);
  36.       lcd1602_write(0x38,LCD_WRITE_COM);
  37.       delay_ms(5);
  38.       lcd1602_write(0x38,LCD_WRITE_COM);
  39.       delay_ms(5);
  40.       lcd1602_write(0x38,LCD_WRITE_COM);
  41.       delay_ms(5);
  42.       lcd1602_write(0x08,LCD_WRITE_COM);            //关闭显示,关闭光标和闪烁
  43.       delay_ms(5);
  44.       lcd1602_write(0x01,LCD_WRITE_COM);          //清屏
  45.       delay_ms(5);
  46.       lcd1602_write(0x06,LCD_WRITE_COM);        //设置指针方式,画面不平移
  47.       delay_ms(5);
  48.       lcd1602_write(0x0c,LCD_WRITE_COM);        //设置指针方式,画面不平移
  49.       delay_ms(5);
  50. }
  51. void lcd_dis_char(unsigned char x, unsigned char y, unsigned char *s)
  52. {
  53.         if(0 == x)
  54.         {
  55.              lcd1602_write(y + 0x80,LCD_WRITE_COM);
  56.
  57.         }
  58.         else if(1 == x)
  59.         {
  60.              lcd1602_write(y + 0xc0,LCD_WRITE_COM);
  61.         }
  62.         while(*s)
  63.         {
  64.
  65.             lcd1602_write(*s, LCD_WRITE_DATA);
  66.             s++;
  67.         }
  68. }
  69.
  70. void time0_init()
  71. {
  72.         EA = 1;
  73.       TMOD |= 0x01;
  74.       TH0 = (65536 - 20000) / 255;
  75.       TL0 = (65536 - 20000) % 255;
  76.       ET0 = 1;
  77.       TR0 = 1;
  78. }
  79.
  80. void time0_isr() interrupt 1
  81. {
  82.       static unsigned char i = 0;
  83.         TH0 = (65536 - 20000) / 255;
  84.       TL0 = (65536 - 20000) % 255;
  85.       i++;
  86.       if(50 == i)
  87.         {
  88.                 i = 0;
  89.               miao++;
  90.               if(60 == miao)
  91.                 {
  92.                         miao = 0;
  93.                       fen++;
  94.                       if(60 == fen)
  95.                         {
  96.                                 fen = 0;
  97.                               shi++;
  98.                               if(24 == shi)
  99.                                 {
  100.                                         shi = 0;
  101.                                 }
  102.                         }
  103.                 }
  104.         }
  105. }
  106.
  107. void lcd_diaplay_time()      //时间的显示函数
  108. {
  109.         lcd1602_write(0x80 + 7, LCD_WRITE_COM);
  110.       lcd1602_write((shi / 10) + 0x30,LCD_WRITE_DATA);
  111.       lcd1602_write((shi % 10) + 0x30,LCD_WRITE_DATA);
  112.         lcd1602_write(':',LCD_WRITE_DATA);
  113.         lcd1602_write((fen / 10) + 0x30,LCD_WRITE_DATA);
  114.         lcd1602_write((fen % 10) + 0x30,LCD_WRITE_DATA);
  115.         lcd1602_write(':',LCD_WRITE_DATA);
  116.         lcd1602_write((miao / 10) + 0x30,LCD_WRITE_DATA);
  117.         lcd1602_write((miao % 10) + 0x30,LCD_WRITE_DATA);
  118.
  119. }
  120.
  121. void lcd_dis_hex()        //显示字符或数字
  122. {
  123.         unsigned char temp = 0x2b;
  124.       lcd1602_write(0x80,LCD_WRITE_COM);
  125.       lcd1602_write((temp / 16) + 0x30,LCD_WRITE_DATA);
  126.       lcd1602_write((temp % 16) + 0x37,LCD_WRITE_DATA);
  127. }
  128.
  129.
  130.
  131. void main()
  132. {
  133.       time0_init();
  134.     lcd_init();
  135.       lcd_dis_hex();
  136.
  137.
  138.         lcd_dis_char(0,2,"time:");
  139.
  140.       while(1)
  141.         {
  142.                     lcd_diaplay_time();
  143.
  144.
  145.         }
  146.
  147. }
关键字:51单片机  LCD1602  驱动程序 引用地址:51单片机之LCD1602的驱动程序
上一篇:51单片机的LCD显示
下一篇:基于51单片机的LCD1602液晶驱动实现
推荐阅读最新更新时间:2024-03-16 16:06
51单片机FFT运算转换程序 adc数据
#include STC12C5A.H #define uchar unsigned char #define uint unsigned int #define channel 0x01 //设置AD通道为 P1.1 //--------------------------------------------------------------------- sbit SDA_R=P1^2; sbit SDA_R_TOP=P1^3; sbit SDA_G=P1^4; sbit SDA_G_TOP=P1^5; sbit STCP=P1^6; sbit SHCP=P1^7;
[单片机]
基于51单片机的两路温度控制器的设计方案
  1.引言   目前,温度控制器存在的问题是如何缩减成本,减少功耗,温度测量的准确性和多路温度的同时显示。本方案设计的实现基于C51单片机的两路温度控制器,做到成本最低化,精确度高,两路温度的显示和控制,能在温度超出设定的最高温度时启动电风扇进行降温,在温度低于设定的最低温度时启动蜂鸣器报警,能够用户设定最高最低温。   2.系统结构   温度控制器系统包括以下几个主要部分:温度传感器,报警电路,LED显示电路,键盘控制,89C51控制部分。如图所示:   本系统设计实现:启动温度控制器后,绿灯亮起,四位LED数码显示器上前两位为温度传感器1所测的环境温度,后两位为温度传感器2所测的环境温度。   3.硬件结构
[单片机]
基于<font color='red'>51单片机</font>的两路温度控制器的设计方案
51单片机特殊功能寄存器有哪些_功能是什么
  51单片机是对所有兼容Intel 8031指令系统的单片机的统称。该系列单片机的始祖是Intel的8004单片机,后来随着Flash rom技术的发展,8004单片机取得了长足的进展,成为应用最广泛的8位单片机之一,其代表型号是ATMEL公司的AT89系列,它广泛应用于工业测控系统之中。很多公司都有51系列的兼容机型推出,今后很长的一段时间内将占有大量市场。51单片机是基础入门的一个单片机,还是应用最广泛的一种。需要注意的是51系列的单片机一般不具备自编程能力。   51单片机特殊功能寄存器   1、21个寄存器介绍   51系列单片机内部主要有四大功能模块,分别是I/O口模块、中断模块、定时器模块和串口通信模块(串行I/O口
[单片机]
<font color='red'>51单片机</font>特殊功能寄存器有哪些_功能是什么
从零开始51单片机教程 —— 16 单片机位操作指令
前面那些流水灯的例程,我们已经习惯了 位 一位就是一盏灯的亮和灭,而我们学的指令却全都是用 字节 来介绍的:字节的移动、加法、减法、逻辑运算、移位等等。用字节来处理一些数学问题,比如说:控制冰箱的温度、电视的音量等等很直观,能直接用数值来表在。可是如果用它来控制一些开关的打开和合上,灯的亮和灭,就有些不直接了,记得我们上次课上的流水灯的例程吗?我们知道送往P1口的数值后并不能马上知道哪个灯亮和来灭,而是要化成二进制才知道。工业中有很多场合需要处理这类开关输出,继电器吸合,用字节来处理就显示有些麻烦,所以在8031单片机中特意引入一个位处理机制。 位寻址区 在8031中,有一部份RAM和一部份SFR是具有位寻址功能的,也就是说
[单片机]
基于51单片机的超声波测距模块设计
超声波测距的模块,51单片机接上12864液晶,HC-SR04超声波模块,就可以了,具体程序没怎么看,超声波模块的硬件也不晓得。 超声波测距51单片机12864液晶显示源程序: #include #include //引脚定义 sbitRX=P1 ^ 1; sbitTX=P1 ^ 2; sbitCS=P3 ^ 3;//片选 高电平有效 单片LCD使用时可固定高电平 sbitSID=P3 ^ 4;//数据 sbitSCLK=P3 ^ 5;//时钟 //Function Definition 函数声明 void Delay(int num); void Init_DS18B20(void); unsigned char ReadO
[单片机]
51单片机入门——单片机最小系统
1.什么是最小系统 单片机最小系统也称为单片机最小应用系统,是指使用最少的原件组成单片机可以工作的系统。 2.最小系统的三要素 单片机最小系统的三要素为:电源、晶振和复位电路。 2.1.电源 任何电子设备都需要供电,目前主流单片机的电源分别为5V和3.3V这两个标准。 选用STC89C52,它需要5V的供电系统,上图是使用USB口输出的5V直流直接供电的,从图中可以看出,供电电路在40引脚和20引脚的位置上,40引脚接的是+5V,通常也称为VCC或VDD,代表电源正极,20引脚接GND,代表电源负极。 2.2.晶振 晶振,又叫晶体振荡器,从这个名字上就可以看出,它注定一生都要不停的振荡。它起到的作用是为单片机系统提
[单片机]
<font color='red'>51单片机</font>入门——单片机最小系统
AT89S51单片机的定时/计数器T0的应用
1.实验任务 用AT89S51单片机的定时/计数器T0产生一秒的定时时间,作为秒计数时间,当一秒产生时,秒计数加1,秒计数到60时,自动从0开始。硬件电路如下图所示 2.电路原理图 图4.15.1 3.系统板上硬件连线 (1).把“单片机系统”区域中的P0.0/AD0-P0.7/AD7端口用8芯排线连接到“四路静态数码显示模块”区域中的任一个a-h端口上;要求:P0.0/AD0对应着a,P0.1/AD1对应着b,……,P0.7/AD7对应着h。 (2).把“单片机系统”区域中的P2.0/A8-P2.7/A15端口用8芯排线连接到“四路静态数码显示模块”区域中的任一个a-h端口上;要求:P2.0/A8对应着a,P2.1/A9
[单片机]
AT89S<font color='red'>51单片机</font>的定时/计数器T0的应用
AT89C2051单片机制作的六位数显多路定时电子钟
这里介绍的电子钟,电路可称得上极简,它仅使用单片的20引脚单片机完成电子钟的全部功能,而笔者见到的其它设计方案均采用二片以上的多片IC实现。 一片20引脚的单片机STC2032(引脚排列与AT89C2051完全相同)为电子钟主体,其显示笔画数据从P1口分时输出,P3口则输出对应的六位选通信号。由于LED数码管点亮时耗电较大,故不能使用AT89C2051单片来完成,但是可以可以用STC89C2032来完成。另外,本站制作时用超高亮的发光二极管代替昂贵的大数码管,成本低,效果独特。 本电子钟设计有三个轻触式按键,这里我们分别命名为:模式设定键K1、加调整键K2、减调整键K3。由于STC89C2032内部已经集成有复位电阻,所以,
[单片机]
AT89C20<font color='red'>51单片机</font>制作的六位数显多路定时电子钟
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
