LCD12864液晶显示的SHT11温湿度传感器程序
发布者:Bby1978最新更新时间:2016-01-22 来源: eefocus关键字:LCD12864  液晶显示  SHT11  温湿度传感器 手机看文章 扫描二维码
随时随地手机看文章
注意:低版本的keil软件不能编译成功,因为无法处理浮点运算。
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define noACK 0
#define ACK   1
#define STATUS_REG_W 0x06
#define STATUS_REG_R 0x07
#define MEASURE_TEMP 0x03
#define MEASURE_HUMI 0x05
#define RESET        0x1e
enum {TEMP,HUMI};
typedef union //定义共用同类型
unsigned int i;
float f;
} value;
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
sbit SCK = P1^0;
sbit DATA = P1^1;
uchar table2[]="SHT11 温湿度检测";
uchar table3[]="温度为:      ℃";
uchar table4[]="湿度为:";
uchar table5[]=".";
uchar wendu[6];
uchar shidu[6];
void delay(int z)
int x,y;
for(x=z;x>0;x--)
for(y=125;y>0;y--);
void delay_50us(uint t)
uint j;
for(;t>0;t--)
for(j=19;j>0;j--);
void delay_50ms(uint t)
uint j;
for(;t>0;t--)
for(j=6245;j>0;j--);
void write_12864com(uchar com)
lcdrs=0;
lcdrw=0;
delay_50us(1);
P0=com;
lcden=1;
delay_50us(10);
lcden=0;
delay_50us(2);
void write_dat(uchar dat)
lcdrs=1;
lcdrw=0;
delay_50us(1);
P0=dat;
lcden=1;
delay_50us(10);
lcden=0;
delay_50us(2);
void init12864lcd(void)
delay_50ms(2);
write_12864com(0x30);
delay_50us(4);
delay_50us(4);
write_12864com(0x0f);
delay_50us(4);
write_12864com(0x01);
delay_50us(240);
write_12864com(0x06);
delay_50us(10);
write_12864com(0x0c);
delay_50us(10);
void display1(void)
uchar i;
write_12864com(0x80);
for(i=0;i<18;i++)
write_dat(table2[i]);
delay_50us(1);
void display2(void)
uchar i;
write_12864com(0x90);
for(i=0;i<18;i++)
write_dat(table3[i]);
delay_50us(1);
void display3(void)
uchar i;
write_12864com(0x88);
for(i=0;i<8;i++)
write_dat(table4[i]);
delay_50us(1);
void displaywendu(void)
uchar i;
write_12864com(0x94);
for(i=0;i<3;i++)
write_dat(wendu[i]);
delay_50us(1);
for(i=0;i<1;i++)
write_dat(table5[i]);
delay_50us(1);
for(i=4;i<5;i++)
delay_50us(1);
void displayshidu(void)
uchar i;
write_12864com(0x8C);
for(i=0;i<3;i++)
write_dat(shidu[i]);
delay_50us(1);
for(i=0;i<1;i++)
delay_50us(1);
for(i=4;i<5;i++)
delay_50us(1);
//写字节程序
char s_write_byte(unsigned char value)
unsigned char i,error=0;
for (i=0x80;i>0;i>>=1)             //高位为1,循环右移
if (i&value) DATA=1;          //和要发送的数相与,结果为发送的位
    else DATA=0;
    SCK=1;
    _nop_();_nop_();_nop_();        //延时3us
    SCK=0;
DATA=1;                           //释放数据线
SCK=1;
error=DATA;                       //检查应答信号,确认通讯正常
SCK=0;
DATA=1;
return error;                     //error=1 通讯错误
//读字节程序
char s_read_byte(unsigned char ack)
unsigned char i,val=0;
DATA=1;                           //释放数据线
for(i=0x80;i>0;i>>=1)             //高位为1,循环右移
SCK=1;
    if(DATA) val=(val|i);             //读一位数据线的值
    SCK=0;
DATA=!ack;                        //如果是校验,读取完后结束通讯;
SCK=1;
SCK=0;
DATA=1;                           //释放数据线
return val;
//启动传输
void s_transstart(void)
    DATA=1; SCK=0;                   //准备
    _nop_();
  SCK=1;
    _nop_();
    DATA=0;
    _nop_();
  SCK=0;
    SCK=1;
    _nop_();
  DATA=1;
  _nop_();
    SCK=0;
//连接复位
void s_connectionreset(void)
unsigned char i;
DATA=1; SCK=0;                    //准备
for(i=0;i<9;i++)                  //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
SCK=1;
    SCK=0;
s_transstart();                   //启动传输
//软复位程序
char s_softreset(void)
unsigned char error=0;
s_connectionreset();              //启动连接复位
error+=s_write_byte(RESET);       //发送复位命令
//温湿度测量
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
unsigned error=0;
unsigned int i;
switch(mode)                      //选择发送命令
case TEMP : error+=s_write_byte(MEASURE_TEMP); break;   //测量温度
           case HUMI : error+=s_write_byte(MEASURE_HUMI); break;   //测量湿度
    default     : break;
for (i=0;i<65535;i++) if(DATA==0) break;        //等待测量结束
if(DATA) error+=1;                              // 如果长时间数据线没有拉低,说明测量错误
*(p_value) =s_read_byte(ACK);     //读第一个字节,高字节 (MSB)
*(p_value+1)=s_read_byte(ACK);     //读第二个字节,低字节 (LSB)
*p_checksum =s_read_byte(noACK); //read CRC校验码
return error; // error=1 通讯错误
//温湿度值标度变换及温度补偿
void calc_sth10(float *p_humidity ,float *p_temperature)
const float C1=-4.0;              // 12位湿度精度 修正公式
const float C2=+0.0405;           // 12位湿度精度修正公式
const float C3=-0.0000028;        // 12位湿度精度修正公式
const float T1=+0.01;             // 14位温度精度 5V条件  修正公式
const float T2=+0.00008;          // 14位温度精度 5V条件  修正公式
float rh=*p_humidity;             // rh:      12位 湿度
float t=*p_temperature;           // t:       14位温度
float rh_lin;                     // rh_lin: 湿度 linear值
float rh_true;                    // rh_true: 湿度 ture值
float t_C;                        // t_C   : 温度 ℃
t_C=t*0.01 - 40;                  //补偿温度
rh_lin=C3*rh*rh + C2*rh + C1;     //相对湿度非线性补偿
rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //相对湿度对于温度依赖性补偿
if(rh_true>100)rh_true=100;       //湿度最大修正
if(rh_true<0.1)rh_true=0.1;       //湿度最小修正
*p_temperature=t_C;               //返回温度结果
*p_humidity=rh_true;              //返回湿度结果
void main(void)
unsigned int temp,humi;
value humi_val,temp_val; //定义两个共同体,一个用于湿度,一个用于温度
unsigned char error;    //用于检验是否出现错误
unsigned char checksum; //CRC
init12864lcd();
display1();
display2();
display3();
while(1)
error=0;   //初始化error=0,即没有错误
error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //温度测量
error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //湿度测量
    if(error!=0) s_connectionreset();                 ////如果发生错误,系统复位
    else
humi_val.f=(float)humi_val.i;                   //转换为浮点数
      temp_val.f=(float)temp_val.i;                   //转换为浮点数
      calc_sth10(&humi_val.f,&temp_val.f);            //修正相对湿度及温度
    temp=temp_val.f*10;
      humi=humi_val.f*10;
      wendu[0]=temp/1000+'0';     //温度百位
      wendu[1]=temp00/100+'0';     //温度十位
    wendu[2]=temp0/10+'0'; //温度个位
      wendu[3]=0x2E; //小数点
    wendu[4]=temp+'0'; //温度小数点后第一位
displaywendu();
shidu[0]=humi/1000+'0';     //湿度百位
      shidu[1]=humi00/100+'0';     //湿度十位
    shidu[2]=humi0/10+'0'; //湿度个位
      shidu[3]=0x2E; //小数点
    shidu[4]=humi+'0'; //湿度小数点后第一位
displayshidu();
delay(800);                             //等待足够长的时间,以现行下一次转换
关键字:LCD12864  液晶显示  SHT11  温湿度传感器 引用地址:LCD12864液晶显示的SHT11温湿度传感器程序
上一篇:基于51单片机 红绿灯数码管程序
下一篇:51单片机程序——按键控制LED灯
推荐阅读最新更新时间:2024-03-16 14:45
DSP与智能彩色液晶显示器接口设计
近年来,随着低价格、高性能DSP芯片的出现,DSP已越来越多地被应用于高速信号采集、语音处理、图像分析处理等领域中,并显示出巨大的优越性。智能彩色液晶显示器具有显示直接美观、便于操作的特点,被用作各种便携式系统的显示前端。它一般采用工业级的高频CPU可以自行对接收的命令和数据进行处理因而能够提高用户端接口的软件开发效率。 一般的液晶显示往往采用单片机控制但在系统需要大量高速实时数据的情况下,单片机由于受处理速度的限制就显得力不从心而且一般的液晶显示仍采用烦琐的点阵操作来显示汉字和图形,而这又增加了软件开发的难度。为了解决这些问题,本文将提出一种基于DSP控制的智能彩色液晶显示器的接口设计方法,从而有效地解决了上述问
[应用]
MSP430F235 Proteus仿真软件中液晶显示器实验
单片机源程序如下: #include msp430f235.h #define uchar unsigned char #define uint unsigned int #define SET_RS P5OUT|=BIT0 #define RST_RS P5OUT&=~BIT0 #define SET_RW P5OUT|=BIT1 #define RST_RW P5OUT&=~BIT1 #define SET_E P5OUT|=BIT2 #define RST_E P5OUT&=~BIT2 void delay_us(uint ms) { uint i,j; for(i=0;i ms;i++) for(j=0;j 1
[单片机]
MSP430F235 Proteus仿真软件中<font color='red'>液晶显示</font>器实验
京东方订购应材设备 加速大尺寸液晶显示器件的生产
     集微网消息,应用材料公司今天宣布其薄膜沉积设备已被中国顶级半导体显示产品供应商BOE(京东方科技集团股份有限公司)选中,用于世界上第一条10.5代TFT-LCD生产线。BOE(京东方)订购多台CVD和PVD设备,使用的玻璃基板可以切割多达6块75英寸的液晶电视面板——有史以来最大的用于显示面板生产的玻璃基板。这一最新订单建立在应用材料公司和BOE(京东方)之间长期合作的基础上,并将扩展应用材料公司在显示行业驱动创新的领导地位。 “实现产能迅速开出和高水准的良率是首要目标,应用材料公司实力雄厚,可以为我们提供有力的技术支持。我们共事多年,彼此合作非常愉快,所以第一条第10.5代TFT-LCD生产线我们选择了应用材料公司的设
[手机便携]
LCD12864经典驱动(详细注释)
#include bsp.h /* RW = 1 :读数据 RW = 0 : 写数据 RS = 1 :数据D0-D7与显示RAM交互 RS = 0 :数据D0-D7与指令寄存器交互 E = 1 :读写是能有效(即可以读写)操作的基础 E :下降沿:锁定数据 CS1 = 0:选择LCD的前64位显示 CS2 = 0:选择LCD的后64位显示 */ /* *LCD检测忙函数 *在RS=0,RW=1模式下 */ void chekbusy12864(void) { uchar dat; //定义uchar变量,接收数据 EX0 = 0; //禁止外部中断0
[单片机]
基于单片机的温湿度监控系统设计
0 引言 在日常生活中温湿度监控系统应用很广泛,例如:粮库、机房、档案馆、特殊材料加工工场等场所,都必须严格控制环境的温度及相对湿度,使其保持在一定的范围内。硝基软片生产线对于温湿度有着特殊的要求,需要装有温湿度在线监控系统,由用户根据环境要求设定系统的温湿度阈值;系统实时地测量显示环境的温湿度值,实现温湿度自动控制,使其在较宽的温度范围内具有较高的测试精度,同时还可以根据用户设定报警阈值报警,一旦发现环境温湿度超限,立即报警。为此,我们设计了一款测量精度高、结构简单使用、工作稳定可靠的基于单片机的温湿度监控与自动控制升降系统,并受到了硝基软片生产客户的好评。 1 设计方案 温湿度监控系统满足以下要求: 1)按照国家
[单片机]
基于单片机的<font color='red'>温湿度</font>监控系统设计
基于51单片机电子万年历设计 lcd12864+24c02+ds1302
作品名称:基于51单片机电子万年历设计 作评功能:1:实现ds1302的读写 2:lcd12864的显示 3:24c02的读写 4:更改日期,时间 5:整点报时,闹钟的功能 6:阴阳历的转换 硬件部分:普中开发板(程序内明确标明接线方式) 软件部分:原创 1:代码规范:易于更改 2:封装良好,可以直接移植。 单片机源程序如下: #include reg51.h //此文件中定义了单片机的一些特殊功能寄存器 #include lcd12864.h #include ds1302.h #include 24c
[单片机]
基于51单片机电子万年历设计 <font color='red'>lcd12864</font>+24c02+ds1302
基于C51单片机对液晶显示的实验设计
程序一:在液晶屏上显示一个1 //在液晶屏上显示一个字符 #include #define uchar unsigned char #define uint unsigned int //端口设置 sbit lcden=P3^4; sbit lcdrs=P3^5; //延迟函数,大约1秒 void delay(uint z) { uint x,y; for(x=z;x》0;x--) for(y=110;y》0;y--); } //写命令 void write_com(uchar com) { lcdrs=0;//写命令 P0=com; delay(5)
[单片机]
基于C51单片机对<font color='red'>液晶显示</font>的实验设计
STM8控制LCD12864液晶屏实验
第一部分 并口传输显示中英文 主要是以下几个函数: 首先:写一个LCD_write函数来给LCD发送数据.根据时序图,发送数据是RW要置0,E要产生下降沿,RS置1为数据,RS置0为命令,由于是并口传输PSB置1. 其次:能够给LCD发命令后,我们就要使用LCD_init函数发送初始化命令。初始化命令至少包括:1、设置显示,2、功能设定,3、初始化清屏3个部分。 写命令时注意每个命令都有自己的运行时间,记得保证足够延时。 第三:写一个LCD_display函数可以分行分列显示内容。 void LCD_write(u8 data,u8 cmd_flag); void LCD_init(void); void LCD_
[单片机]
STM8控制<font color='red'>LCD12864</font>液晶屏实验
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
更多每日新闻
随便看看
