一、前期准备
单片机:STM32F103ZET6
开发环境:MDK5.14
库函数:标准库V3.5
LCD12864模块:淘宝有售
二、实验效果
3.3V LCD12864
5V LCD12864
三、驱动原理
5V和3.3V模块均可以用STM32直接驱动,而不像1602那样5V必须是用5V驱动。注意的是模块上面的PSB脚接VCC,接VCC的话是采用并口传输数据,接GND采用串口传输,串口程序会在以后的博客中跟新。RST脚接VCC,此处没有用到硬件复位,所以直接接VCC,其复位低电平有效。驱动芯片资料,请自行搜索ST7920,里面自带字库。
需要完整工程或者有问题的请加QQ:1002521871,验证:呵呵。
四、驱动代码
LCD12864.h
#ifndef __LCD_12864_H__
#define __LCD_12864_H__
#include "stm32f10x.h"
#include "gpio.h"
#include "delay.h"
//IO Definitions
#define RS PCout(0)
#define RW PCout(1)
#define EN PCout(2)
//#define PSB PCout(3)
//#define RST PCout(4)
#define RS_Pin GPIO_Pin_0
#define RW_Pin GPIO_Pin_1
#define EN_Pin GPIO_Pin_2
//#define PSB_Pin GPIO_Pin_3
//#define RST_Pin GPIO_Pin_4
typedef enum
Command,
Data
}WR_Mode;
#define LINE1 0x80
#define LINE2 0x90
#define LINE3 0x88
#define LINE4 0x98
extern void LCD12864_Show(uint8_t line, uint8_t pos, uint8_t *str);
extern void LCD12864Configuration(void);
extern void LCD_Clr(void);
#endif
LCD12864.c
#include "lcd12864.h"
void LCD_Wait_Ready(void)
uint8_t status;
RS = 0;
RW = 1;
GPIOD->ODR = 0xFF;
do
EN = 1;
DelayMs(5);
status = GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_7);
}while(status & 0x80);
EN = 0;
void LCD_Write_Cmd(uint8_t cmd)
LCD_Wait_Ready();
RS = 0;
RW = 0;
EN = 1;
GPIOD->ODR = cmd;
EN = 0;
void LCD_Write_Dat(uint8_t dat)
LCD_Wait_Ready();
RS = 1;
RW = 0;
EN = 1;
GPIOD->ODR = dat;
EN = 0;
void LCD_Init(void)
LCD_Write_Cmd(0x30);
LCD_Write_Cmd(0x0C);
LCD_Write_Cmd(0x01);
void LCD_Write_Word(uint8_t *str)
while (*str > 0)
LCD_Write_Dat(*str);
str ++;
void LCD_Write_Test(WR_Mode mode, uint8_t word)
switch(mode)
case Command:
LCD_Write_Cmd(word);
break;
case Data:
LCD_Write_Dat(word);
break;
void LCD_Clr(void)
LCD_Write_Test(Command, 0x01);
void LCM_CLR(void)
uint8_t clear[16] = " ";
// "1234567812345678"
LCD_Write_Test(Command, LINE1);
LCD_Write_Word(clear);
LCD_Write_Test(Command, LINE2);
LCD_Write_Test(Command, LINE3);
LCD_Write_Test(Command, line + pos);
LCD_Write_Word(str);
GPIO_InitTypeDef GPIO;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE);
GPIO.GPIO_Pin = RS_Pin | RW_Pin | EN_Pin;//| PSB_Pin | RST_Pin;
GPIO.GPIO_Speed = GPIO_Speed_50MHz;
GPIO.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO);
//Data Port , PD0 ~ PD7
GPIO.GPIO_Pin = 0xFF;
GPIO_Init(GPIOD, &GPIO);
LCD_Init();
LCD_Clr();
设计资源 培训 开发板 精华推荐
- 使用具有可编程电源电压的 ADXRS450 数字速率传感器检测角速度
- AP2114 1A 低噪声 CMOS LDO 固定稳压器的典型应用
- 使用 AD5390、14 位 DAC、12 位 ADC 数据采集系统的通道监控功能
- 灵活、高精度、低漂移、PLC/DCS 模拟输出模块
- 使用 LTC2379CDE-18、18 位、1.6Msps SAR ADC 的典型应用
- LTC3630AHMSE 4V 至 76V 输入至 3.3V 输出、500mA 降压转换器的典型应用电路
- 使用 Analog Devices 的 LT8570IDD-1 的参考设计
- SSL4120带PFC的谐振电源控制IC
- ADR4540 双极性输出电压基准的典型应用
- 智能小车
