arm7 力天电子 lpc2148 GPIO之花样流水灯
发布者:lambda21最新更新时间:2019-05-14 来源: eefocus关键字:arm7  lpc2148  GPIO  花样流水灯 手机看文章 扫描二维码
随时随地手机看文章
力天电子的lpc2148开发板,一共有四个流水灯。它们与SN74HC595D相连,然后接到2148处理器上。先点亮两边的两个(16,19),然后再点亮中间的两个(17,18),熄灭的时候先熄灭两边的,再熄灭中间的。程序如下图所示:
#include
#define         SCLK  0x01<<24
#define         MISO  0x01<<5
#define         MOSI  0x01<<6
#define         RCK   0x01<<7
void Delayn(unsigned long n);
void HC595_Init(void);
void Write595(void);
unsigned int HC595_DATA = 0;
//初始化595接口
  IO0DIR |= MOSI|RCK;
  IO1DIR |= SCLK;
  IO1CLR |= SCLK;
  IO0DIR |= RCK;
  HC595_DATA = 0xFFFFFFFF;  Write595();
//写字节
void WriteByte(unsigned char data)
  unsigned char i;
  //IO0CLR = RCK;
  for(i=0;i<8;i++)
    if(data&0x01)      IO0SET=MOSI;
    else      IO0CLR=MOSI;
    IO1SET=SCLK;
    data>>=1;
    IO1CLR=SCLK;
  //IO0SET = RCK;
//刷新595的数据
void Write595(void)
  IO0CLR = RCK;
  WriteByte(HC595_DATA&0xff);
  WriteByte((HC595_DATA&0xff00)>>8);
  WriteByte((HC595_DATA&0xff0000)>>16);
  WriteByte((HC595_DATA&0xff000000)>>24);
  IO0SET = RCK;
main(void)
  //初始化74HC595
  HC595_Init();
  //主循环
  while(1)
    HC595_DATA &=~(1<<16);Write595();
    HC595_DATA &=~(1<<19);Write595();
    Delayn(1000000);
    HC595_DATA &=~(1<<17);Write595();
    HC595_DATA &=~(1<<18);Write595();
    Delayn(1000000);
    HC595_DATA |=(1<<16);Write595();
    HC595_DATA |=(1<<19);Write595();
    Delayn(1000000);
    HC595_DATA |=(1<<17);Write595();
    HC595_DATA |=(1<<18);Write595();
    Delayn(1000000);
//延时周期数
  while(n--);
关键字:arm7  lpc2148  GPIO  花样流水灯 引用地址:arm7 力天电子 lpc2148 GPIO之花样流水灯
上一篇:arm7 力天电子lpc2148 GPIO之按键输入试验
下一篇:arm7 力天电子lpc2148 GPIO之二单路LED控制实验
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
