前沿
关于STM32采样问题,相信很多人曾遇到过这样的问题,无论是关于ADC底层相关的配置还是ADC采样方案的抉择,或者是ADC软硬件滤波算法,这里博主就自己曾做过的训练题为引申,探讨ADC采样过程中的问题。
1.ADC的认识
1.1 ADC初始化参数
/* Exported types ------------------------------------------------------------*/
* @brief ADC Init structure definition
typedef struct
uint32_t ADC_Resolution; /*!< Configures the ADC resolution dual mode. This parameter can be a value of @ref ADC_resolution */
FunctionalState ADC_ScanConvMode; /*!< Specifies whether the conversion is performed in Scan (multichannels)or Single (one channel) mode.
This parameter can be set to ENABLE or DISABLE */
FunctionalState ADC_ContinuousConvMode; /*!< Specifies whether the conversion is performed in Continuous or Single mode.
This parameter can be set to ENABLE or DISABLE. */
uint32_t ADC_ExternalTrigConvEdge; /*!< Select the external trigger edge and enable the trigger of a regular group.
@ref ADC_external_trigger_edge_for_regular_channels_conversion */
uint32_t ADC_ExternalTrigConv; /*!< Select the external event used to trigger the start of conversion of a regular group.
@ref ADC_extrenal_trigger_sources_for_regular_channels_conversion */
uint32_t ADC_DataAlign; /*!< Specifies whether the ADC data alignment is left or right. This parameter can be
a value of @ref ADC_data_align */
uint8_t ADC_NbrOfConversion; /*!< Specifies the number of ADC conversions that will be done using the sequencer for
regular channel group.This parameter must range from 1 to 16. */
}ADC_InitTypeDef;
涉及的相关参数:ADC分辨率(6/8/10/12位)、扫描或非扫描模式、连续或不连续转换、触发方式、对齐方式等。
这里值得注意的是规则组转化序列不能超过16。
1.2 ADC通用初始化参数
* @brief ADC Common Init structure definition
typedef struct
uint32_t ADC_Mode; /*!< Configures the ADC to operate in
independent or multi mode.
This parameter can be a value of @ref ADC_Common_mode */
uint32_t ADC_Prescaler; /*!< Select the frequency of the clock
to the ADC. The clock is common for all the ADCs.
This parameter can be a value of @ref ADC_Prescaler */
uint32_t ADC_DMAAccessMode; /*!< Configures the Direct memory access
mode for multi ADC mode.
@ref ADC_Direct_memory_access_mode_for_multi_mode */
uint32_t ADC_TwoSamplingDelay; /*!< Configures the Delay between 2 sampling phases.
@ref ADC_delay_between_2_sampling_phases */
}ADC_CommonInitTypeDef;
这里涉及相关ADC单独/多重模式选择,两采样阶段采样间隔,DMA使能/失能,ADC分屏系数(注意ADC的时钟频率不超过36Mhz)
1.3 ADC相关配置库函数
/* Function used to set the ADC configuration to the default reset state *****/
void ADC_DeInit(void);
/* Initialization and Configuration functions *********************************/
void ADC_Init(ADC_TypeDef* ADCx, ADC_InitTypeDef* ADC_InitStruct);
void ADC_StructInit(ADC_InitTypeDef* ADC_InitStruct);
void ADC_CommonInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);
void ADC_CommonStructInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);
void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState);
/* Analog Watchdog configuration functions ************************************/
void ADC_AnalogWatchdogCmd(ADC_TypeDef* ADCx, uint32_t ADC_AnalogWatchdog);
void ADC_AnalogWatchdogThresholdsConfig(ADC_TypeDef* ADCx, uint16_t HighThreshold,uint16_t LowThreshold);
void ADC_AnalogWatchdogSingleChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel);
/* Temperature Sensor, Vrefint and VBAT management functions ******************/
void ADC_TempSensorVrefintCmd(FunctionalState NewState);
void ADC_VBATCmd(FunctionalState NewState);
/* Regular Channels Configuration functions ***********************************/
void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
void ADC_SoftwareStartConv(ADC_TypeDef* ADCx);
FlagStatus ADC_GetSoftwareStartConvStatus(ADC_TypeDef* ADCx);
void ADC_EOCOnEachRegularChannelCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
void ADC_ContinuousModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
void ADC_DiscModeChannelCountConfig(ADC_TypeDef* ADCx, uint8_t Number);
void ADC_DiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
uint16_t ADC_GetConversionValue(ADC_TypeDef* ADCx);
uint32_t ADC_GetMultiModeConversionValue(void);
/* Regular Channels DMA Configuration functions *******************************/
void ADC_DMACmd(ADC_TypeDef* ADCx, FunctionalState NewState);
void ADC_DMARequestAfterLastTransferCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
void ADC_MultiModeDMARequestAfterLastTransferCmd(FunctionalState NewState);
/* Injected channels Configuration functions **********************************/
void ADC_InjectedChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
void ADC_InjectedSequencerLengthConfig(ADC_TypeDef* ADCx, uint8_t Length);
void ADC_SetInjectedOffset(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel, uint16_t Offset);
void ADC_ExternalTrigInjectedConvConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConv);
void ADC_ExternalTrigInjectedConvEdgeConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConvEdge);
void ADC_SoftwareStartInjectedConv(ADC_TypeDef* ADCx);
FlagStatus ADC_GetSoftwareStartInjectedConvCmdStatus(ADC_TypeDef* ADCx);
void ADC_AutoInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
void ADC_InjectedDiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
uint16_t ADC_GetInjectedConversionValue(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel);
上一篇:STM32 关于ADC采交直流问题探讨(二)
下一篇:STM32F4开发板----ADC(005)
推荐阅读最新更新时间:2024-11-12 02:59
设计资源 培训 开发板 精华推荐
- MCP43XXEV,MCP4251 数字电位器器件评估板
- LTC3624IDD-2 可调输出电压、2A 同步降压型稳压器、同步至 500kHz、强制连续模式的典型应用
- 具有基于 LT1236 的低漂移满量程微调的 CMOS DAC
- LTC2295IUP 演示板,MUX 双路 ADC,VDD=+3.0V,10Msps,14Bit,1MHz < AIN< 70MHz
- LT8335EDDB 5V 至 12V 输入、-12V 反相转换器的典型应用电路
- ADR5041B 2.5 Vout 精密微功率分流模式电压基准的典型应用,用于 ±15 V 输出和堆叠 ADR5045 器件
- 4012-434-PDK,用于 Si4012 和 Si4355 434-MHz 射频收发器的 EZRadio 单向链路开发套件
- L7818C 固定输出稳压器的典型应用
- ADP5034-1-EVALZ,ADP5034 微电源管理单元评估板
- LT3496EUFD 演示电路,升压或降压-升压模式三路输出 LED 驱动器 @ 200mA/通道
- 关注、评论赢好礼!《美光2022台北国际电脑展主题演讲精选:智能边缘与智能制造专辑》
- 乐鑫ESP32-Korvo音频开发板免费测评试用
- 有奖直播 | 瑞萨新一代视觉 AI MPU 处理器 RZ/V2H:高算力、低功耗、实时控制
- TI C2000TM的信号链实时性评测和使用教程
- TE Connectivity利用传感和连接解决方案,赋能电动汽车发展 参与有好礼!
- LYTSwitch-1 LED驱动器 天生小体积,应用高效率,围观有好礼!
- PI LYTSwitch™-6系列IC 让你了解不知道的秘密看专题赢好礼!
- 万用表,红外测温仪等你来拆!—— EEWorld拆你来玩拆解(第二期)
- ST直播主题:高度灵活的、易用的、可定制化的协议栈--BlueNRG-LP 协议栈介绍
