1,硬件I2C
HAL_I2C_Mem_Write(&hi2c1,0x88,0,I2C_MEMADD_SIZE_8BIT,0,0,0X10);//写
HAL_I2C_Master_Receive(&hi2c1,0x89,(uint8_t*)datatemp,4,0x10);//读
2 软件I2C
#ifndef __MYI2C_H__
#define __MYI2C_H__
#include "stm32f1xx_hal.h"
#include "main.h"
#include "stdint.h"
#define CPU_FREQUENCY_MHZ 72
#define MYI2C_SCL_PIN I2C_SCL_Pin
#define MYI2C_SCL_PORT I2C_SCL_GPIO_Port
#define MYI2C_SDA_PIN I2C_SDL_Pin
#define MYI2C_SDA_PORT I2C_SDL_GPIO_Port
#define SDA_Dout_LOW() HAL_GPIO_WritePin(MYI2C_SDA_PORT,MYI2C_SDA_PIN,GPIO_PIN_RESET)
#define SDA_Dout_HIGH() HAL_GPIO_WritePin(MYI2C_SDA_PORT,MYI2C_SDA_PIN,GPIO_PIN_SET)
#define SDA_Data_IN() HAL_GPIO_ReadPin(MYI2C_SDA_PORT,MYI2C_SDA_PIN)
#define SCL_Dout_LOW() HAL_GPIO_WritePin(MYI2C_SCL_PORT,MYI2C_SCL_PIN,GPIO_PIN_RESET)
#define SCL_Dout_HIGH() HAL_GPIO_WritePin(MYI2C_SCL_PORT,MYI2C_SCL_PIN,GPIO_PIN_SET)
#define SCL_Data_IN() HAL_GPIO_ReadPin(MYI2C_SCL_PORT,MYI2C_SCL_PIN)
#define SDA_Write(XX) HAL_GPIO_WritePin(MYI2C_SDA_PORT,MYI2C_SDA_PIN,(XX?GPIO_PIN_SET:GPIO_PIN_RESET))
void I2C_Init(void);
void I2C_Start(void);
void I2C_Stop(void);
void I2C_Send_Byte(uint8_t txd);
uint8_t I2C_Read_Byte(uint8_t ack);
void I2C_NAck(void);
void I2C_Ack(void);
uint8_t I2C_Wait_Ack(void);
void delay_xus(__IO uint32_t nTime);
#define Delay_us(xx) delay_xus(xx)
#endif
#include "myi2c.h"
int old_val,new_val,val;
if(nTime > 900)
for(old_val = 0; old_val < nTime/900; old_val++)
delay_xus(900);
nTime = nTime%900;
old_val = SysTick->VAL;
new_val = old_val - CPU_FREQUENCY_MHZ*nTime;
if(new_val >= 0)
do
val = SysTick->VAL;
while((val < old_val)&&(val >= new_val));
else
new_val +=CPU_FREQUENCY_MHZ*1000;
do
val = SysTick->VAL;
while((val <= old_val)||(val > new_val));
void SDA_Output(void)
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.Pin = MYI2C_SDA_PIN;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed =GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(MYI2C_SDA_PORT,&GPIO_InitStruct);
void SDA_Input(void)
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
void SCL_Output(void)
GPIO_InitStruct.Pin = MYI2C_SCL_PIN;
HAL_GPIO_Init(MYI2C_SCL_PORT,&GPIO_InitStruct);
void SCL_Input(void)
void I2C_Init(void)
SCL_Output();
SDA_Output();
SCL_Dout_HIGH();
SDA_Dout_HIGH();
//产生IIC起始信号
SDA_Output();
SDA_Dout_HIGH();
SCL_Dout_HIGH();
Delay_us(4);
SDA_Dout_LOW();
Delay_us(4);
SCL_Dout_LOW();
//产生IIC停止信号
void I2C_Stop(void)
SDA_Output();
SCL_Dout_LOW();
SDA_Dout_LOW();
Delay_us(4);
SCL_Dout_HIGH();
SDA_Dout_HIGH();
Delay_us(4);
uint8_t ucErrTime=0;
SDA_Input();
SDA_Dout_HIGH();Delay_us(1);
SCL_Dout_HIGH();Delay_us(1);
while(SDA_Data_IN())
ucErrTime++;
if(ucErrTime>250)
I2C_Stop();
return 1;
SCL_Dout_LOW();//时钟输出0
return 0;
//产生ACK应答
void I2C_Ack(void)
SCL_Dout_LOW();
SDA_Output();
SDA_Dout_LOW();
Delay_us(2);
SCL_Dout_HIGH();
Delay_us(2);
SCL_Dout_LOW();
//不产生ACK应答
void I2C_NAck(void)
SCL_Dout_LOW();
SDA_Output();
SDA_Dout_HIGH();
Delay_us(2);
SCL_Dout_HIGH();
Delay_us(2);
SCL_Dout_LOW();
//IIC发送一个字节
//返回从机有无应答
//1,有应答
//0,无应答
uint8_t t;
//拉低时钟开始数据传输
SDA_Output();
SCL_Dout_LOW();
for(t=0;t<8;t++)
SDA_Write((txd&0x80)>>7);
txd<<=1;
Delay_us(5); //对TEA5767这三个延时都是必须的
SCL_Dout_HIGH();
Delay_us(5);
SCL_Dout_LOW();
//Delay_us(2);
//读1个字节,ack=1时,发送ACK,ack=0,发送nACK
unsigned char i,receive=0;
//SDA设置为输入
SDA_Input();
for(i=0;i<8;i++ )
SCL_Dout_LOW();
Delay_us(5);
SCL_Dout_HIGH();
receive<<=1;
if(SDA_Data_IN())receive++;
Delay_us(5);
if(!ack)I2C_NAck();//发送nACK
else I2C_Ack(); //发送ACK
return receive;
上一篇:I2C上拉电阻问题分析(基于stm32 HAL库)
下一篇:stm32 hal 模拟i2c
推荐阅读最新更新时间:2024-11-06 10:04
设计资源 培训 开发板 精华推荐
- LT3464、具有集成肖特基二极管的微功率 SOT-23 升压
- EVAL-ADF7020DBZ1,ADF7020 ISM 频段收发器评估板
- 使用 ROHM Semiconductor 的 BD46252 的参考设计
- DC1816B,具有 LT3799EMSE-1 离线隔离式反激式 LED 驱动器和 PFC、90-305VAC 输入至 36Vout (nom) @ 3A 的演示板
- 用于 12V 应用的 LTC4367IMS8-1 过压电源控制器的典型应用
- LTC3646EDE-1 28V 输出、500kHz 工作频率同步降压转换器的典型应用电路
- 具有宽输入电压的 LT8410-1 34V 输出升压转换器的典型应用电路
- LT8330IS6 4V 至 16V 输入、-5V 反相转换器的典型应用电路
- 继电器模块
- LTC3859AMPUHF 高效率、三路 24V/1V/1.2V 同步降压/升压转换器的典型应用电路,采用 12V 输入电压
