STM32 >> 矩阵键盘(代码风格优美,简明易懂)
发布者:SereneSoul55最新更新时间:2019-08-29 来源: eefocus关键字:STM32  矩阵键盘  代码 手机看文章 扫描二维码
随时随地手机看文章
本文有关矩阵键盘的使用原理适用于所有微机控制器,同时也适用于所有规格的矩阵键盘。
key.h
  * @file    bsp_key.h
  * @author  Waao
  * @version V1.0.0
  * @date    23-Jan-2019
  * @brief   This file contains some board support package's definition for the KEY.
  * @attention
  * None
#ifndef __BSP_KEY_H_
#define __BSP_KEY_H_
#include
#include
#include
// Column1, Column2, Column3, Column4
#define C1_PIN             GPIO_Pin_2
#define C1_GPIO_PORT       GPIOE
#define C1_GPIO_CLK        RCC_AHB1Periph_GPIOE
#define C2_PIN             GPIO_Pin_3
#define C2_GPIO_PORT       GPIOE
#define C2_GPIO_CLK        RCC_AHB1Periph_GPIOE
#define C3_PIN             GPIO_Pin_4
#define C3_GPIO_PORT       GPIOE
#define C3_GPIO_CLK        RCC_AHB1Periph_GPIOE
#define C4_PIN             GPIO_Pin_5
#define C4_GPIO_PORT       GPIOE
#define C4_GPIO_CLK        RCC_AHB1Periph_GPIOE
// Row1, Row2, Row3, Row4
#define R1_PIN             GPIO_Pin_12
#define R1_GPIO_PORT       GPIOB
#define R1_GPIO_CLK        RCC_AHB1Periph_GPIOB
#define R2_PIN             GPIO_Pin_13
#define R2_GPIO_PORT       GPIOB
#define R2_GPIO_CLK        RCC_AHB1Periph_GPIOB
#define R3_PIN             GPIO_Pin_14
#define R3_GPIO_PORT       GPIOB
#define R3_GPIO_CLK        RCC_AHB1Periph_GPIOB
#define R4_PIN             GPIO_Pin_15
#define R4_GPIO_PORT       GPIOB
#define R4_GPIO_CLK        RCC_AHB1Periph_GPIOB
// detect and output
#define DETECT_C1          GPIO_ReadInputDataBit(C1_GPIO_PORT, C1_PIN)
#define DETECT_C2          GPIO_ReadInputDataBit(C2_GPIO_PORT, C2_PIN)
#define DETECT_C3          GPIO_ReadInputDataBit(C3_GPIO_PORT, C3_PIN)
#define DETECT_C4          GPIO_ReadInputDataBit(C4_GPIO_PORT, C4_PIN)
#define DETECT_R1          GPIO_ReadInputDataBit(R1_GPIO_PORT, R1_PIN)
#define DETECT_R2          GPIO_ReadInputDataBit(R2_GPIO_PORT, R2_PIN)
#define DETECT_R3          GPIO_ReadInputDataBit(R3_GPIO_PORT, R3_PIN)
#define DETECT_R4          GPIO_ReadInputDataBit(R4_GPIO_PORT, R4_PIN)
// Keys
#define S1                 0x77
#define S2                 0xB7
#define S3                 0xD7
#define S4                 0xE7
#define S5                 0x7B
#define S6                 0xBB
#define S7                 0xDB
#define S8                 0xEB
#define S9                 0x7D
#define S10                0xBD
#define S11                0xDD
#define S12                0xED
#define S13                0x7E
#define S14                0xBE
#define S15                0xDE
#define S16                0xEE
void GPIO_RCC_Config(void);
void ROCI_GPIO_Config(void);
void RICO_GPIO_Config(void);
void KEY_GPIO_ConfigAndDetect(void);
#endif
有关输入输出管脚的选择可以多试验几组,有的管脚即使你配置成上拉输入,当你松开按键之后依然不会返回高电平,我在此就因为这个问题被卡了一阵子
关于我的矩阵键盘检测的原理简明阐述如下:
首先设置为行输出低电平,列上拉输入(即无外部干扰时保持高电平);
检测到按键按下,此时通过检测列的电平情况从而得知哪一列有按键被按下;
然后确定有按键被按下后,设置为列输出低电平,行上拉输入;
通过检测行的电平情况从而得知哪一行有按键被按下;
最后通过“不平行的两条直线相交于一点”原理,推知具体被按下的按键。
key.c
  * @file    bsp_key.c
  * @author  Waao
  * @version V1.0.0
  * @date    23-Jan-2019
  * @brief   This file contains some board support package's functions for the KEY.
  * @attention
  * None
#include
  * @brief  Initialize the RCC of the 8 GPIO line.
  * @param  None
  * @retval None
RCC_AHB1PeriphClockCmd(C1_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(C2_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(C3_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(C4_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(R1_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(R2_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(R3_GPIO_CLK, ENABLE);
RCC_AHB1PeriphClockCmd(R4_GPIO_CLK, ENABLE);
  * @brief  Initialize the Row out Column in.
  * @param  None
  * @retval None
GPIO_InitTypeDef GPIO_Structure;
//============ Column =============
GPIO_Structure.GPIO_Mode = GPIO_Mode_IN;
GPIO_Structure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Structure.GPIO_OType = GPIO_OType_PP;
GPIO_Structure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Structure.GPIO_Pin = C1_PIN;
GPIO_Init(C1_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = C2_PIN;
GPIO_Init(C2_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = C3_PIN;
GPIO_Init(C3_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = C4_PIN;
GPIO_Init(C4_GPIO_PORT, &GPIO_Structure);
//============== Row ===============
GPIO_Structure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_Structure.GPIO_PuPd = GPIO_PuPd_DOWN;
GPIO_Structure.GPIO_Pin = R1_PIN;
GPIO_Init(R1_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = R2_PIN;
GPIO_Init(R2_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = R3_PIN;
GPIO_Init(R3_GPIO_PORT, &GPIO_Structure);
GPIO_Structure.GPIO_Pin = R4_PIN;
GPIO_Init(R4_GPIO_PORT, &GPIO_Structure);
GPIO_ResetBits(R1_GPIO_PORT, R1_PIN);
GPIO_ResetBits(R2_GPIO_PORT, R2_PIN);
GPIO_ResetBits(R3_GPIO_PORT, R3_PIN);
GPIO_ResetBits(R4_GPIO_PORT, R4_PIN);
  * @brief  Initialize the Row in Column out.
  * @param  None
  * @retval None
//============== Row ==================
//============ Column ================
GPIO_ResetBits(C1_GPIO_PORT, C1_PIN);
GPIO_ResetBits(C2_GPIO_PORT, C2_PIN);
GPIO_ResetBits(C3_GPIO_PORT, C3_PIN);
GPIO_ResetBits(C4_GPIO_PORT, C4_PIN);
  * @brief  Configure the GPIO, and detect whether the key was pressed down
  * @param  None
  * @retval None
u8 TEMP_COMBINE = 0, TEMP_ROCI = 0, TEMP_RICO = 0;
GPIO_RCC_Config();
printf("nWhy so serious ?tThe game just begin!");
while(1)
ROCI_GPIO_Config();
TEMP_ROCI = (u8)(((u8)DETECT_C1) << 3) |
(((u8)DETECT_C2) << 2) |
(((u8)DETECT_C3) << 1) |
(((u8)DETECT_C4) << 0);
if(TEMP_ROCI != 0x0f)
Delay(1000); // Eliminate the shaking. The parameter's unit is 10us
if(TEMP_ROCI != 0x0f) // Ensure one of the keys was pressed down indeed.
RICO_GPIO_Config();
TEMP_RICO = (u8)(((u8)DETECT_R1) << 3) |
(((u8)DETECT_R2) << 2) |
(((u8)DETECT_R3) << 1) |
(((u8)DETECT_R4) << 0);
TEMP_COMBINE = (u8)((TEMP_ROCI << 4) | TEMP_RICO); // Combine the two situation and we can know which key was pressed down.
switch(TEMP_COMBINE)
case S1:
printf("nS1 was pressed down!");
break;
case S2:
printf("nS2 was pressed down!");
break;
case S3:
printf("nS3 was pressed down!");
break;
case S4:
printf("nS4 was pressed down!");
break;
[1] [2]
关键字:STM32  矩阵键盘  代码 引用地址:STM32 >> 矩阵键盘(代码风格优美,简明易懂)
上一篇:STM32F429 >> 22. FMC_扩展外部SDRAM(Code)
下一篇:STM32学习笔记1-----初识stm32F429IGT6
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
