12864的引脚图:
由图可知PSB一开始要拉高,可以接到电源上,VCC接5v电源,VSS接地,要是12864产生背光,将BLA接5v电源,BLK接地。其余引脚可以自定义接到STM32的IO上。
在接STM32的IO后,程序中应首先要对IO进行初始化,进行端口使能等操作,12864有其自带的中文字库,在程序中对字库初始化,同时写好传送数据指令的函数,输出显示内容,下面是关于12864的代码:
#include "stm32f10x.h"
#include "delay.h"
#include "stm32f10x_gpio.h"
#define V0 PCout(1)
#define RS PCout(3)
#define WRD PAout(8)
#define E PAout(9)
#define DB0 PAout(0)
#define DB1 PAout(1)
#define DB2 PAout(2)
#define DB3 PAout(3)
#define DB4 PAout(4)
#define DB5 PAout(5)
#define DB6 PAout(6)
#define DB7 PAout(7)
#define NC PEout(10)
#define RES PEout(12)
#define VOUT PBout(14)
void _Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOE, ENABLE); //使能PB,PE端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9; //LED0-->PB.5 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_3;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_Init(GPIOE, &GPIO_InitStructure);
unsigned int temp ;
void TransferData(char data1,unsigned char DI) //传送数据或者命令,当DI=0是,传送命令,当DI=1,传送数据.
WRD=0;
RS=DI;
delay_ms(1);
temp = (temp&0xff00)|data1 ;
GPIO_Write(GPIOA,temp) ;
E=1;
delay_ms(1);
E=0;
void initinal(void) //LCD字库初始化程序
delay_ms(40);
RES=0; //复位
delay_ms(1);
RES=1; //复位置高
delay_ms(10);
TransferData(0x30,0); //Extended Function Set :8BIT设置,RE=0: basic instruction set, G=0 :graphic display OFF
delay_ms(100);
TransferData(0x30,0); //Function Set
delay_ms(37);
TransferData(0x08,0); //Display on Control
delay_ms(100);
TransferData(0x10,0); //Cursor Display Control光标设置
delay_ms(100);
TransferData(0x0C,0); //Display Control,D=1,显示开
delay_ms(100);
TransferData(0x01,0); //Display Clear
delay_ms(10);
TransferData(0x06,0); //Enry Mode Set,光标从右向左加1位移动
delay_ms(100);
void lcd_mesg(unsigned char *adder1 ,unsigned char locate,unsigned int number)
unsigned char i;
TransferData(locate,0); //Set Graphic Display RAM Address
delay_ms(100);
for(i=0;i TransferData(*adder1,1); adder1++; } } int main(void) { delay_init(); _Init(); initinal() ; while(1) { lcd_mesg("日照香炉生紫烟,",0x80,16) ; lcd_mesg("遥看瀑布挂前川。",0x90,16) ; lcd_mesg("飞流直下三千尺,",0x88,16) ; lcd_mesg("疑是银河落九天。",0x98,16) ; // TransferData (0x01,0) ; //清屏 } } 仿真下载后:
设计资源 培训 开发板 精华推荐
- MC33074ADR2G 高顺从电压至灌电流转换器的典型应用
- 使用 NXP Semiconductors 的 ISP1105W 的参考设计
- 使用 Microchip Technology 的 LX7169 的参考设计
- DER-353 - 9.5 W,隔离反激式,TRIAC可调光,PFC LED驱动器
- 用于三相交流电机的 200W、24V 交流转直流单输出电源
- 12V触摸调光灯
- SY89464U,用于 GB 以太网交换机的时钟缓冲器的评估板
- S32K14WEVB-Q064: S32K144W评估板
- 使用 NXP Semiconductors 的 TDA2582 的参考设计
- AM1S-0307SZ 1W DC-DC转换器典型应用
