串口应该都很熟悉了,具体通信原理我就不提了,这个百度上都很多讲的,然后就直接看函数了。
void Uart_SendByte(int data)//这个函数是发送整型数据,参数为data
if(whichUart==0)//这个是选中串口0
if(data=='')//然后判断数据不为空
/*寄存器的原始宏定义,
#define rUTRSTAT0 (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status*/
while(!(rUTRSTAT0 & 0x2));/*这个就是查询串口0的状态寄存器,第1位是发送缓冲器是否为空
第二位是Transmit buffer empty
0 = The buffer register is not empty
1 = Empty 这里检查为0的话就是还没发送完全,当置1的时候表示发完了,程序继续执行*/
Delay(10); //because the slow response of hyper_terminal
WrUTXH0('');
while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
Delay(10);
WrUTXH0(data);
else if(whichUart==1)
if(data=='')
while(!(rUTRSTAT1 & 0x2));
rUTXH1 = '';
while(!(rUTRSTAT1 & 0x2)); //Wait until THR is empty.
Delay(10);
rUTXH1 = data;
else if(whichUart==2)
if(data=='')
while(!(rUTRSTAT2 & 0x2));
rUTXH2 = '';
while(!(rUTRSTAT2 & 0x2)); //Wait until THR is empty.
Delay(10);
rUTXH2 = data;
搞了这么久我还不知道如何确定ARM的大端或是小端格式,这个是在启动代码里设置的,现在还没看,mini2440的串口代码和华恒2410的串口发送代码一样的。注释如上。
主函数中的关键代码:
* Function Name : Main()
* Create Date : 2011/12/10
* Author/Corporation : 涛行天下
* Description : Find a proper thread in thread array
* Param : ThreadNo : someParam description
ThreadStaus : someParam description
* Global Variable : DISP_wuiSegmentAppID
* File Static Variable : naucThreadNo
* Function Static Variable : None
* Revision History
* No. Date Revised by Item Description
* V0.0 2011/12/10 涛行天下 ... ....
void Main(void)
U8 count_num = 0;
char *mode;
int i;
U8 key;
U32 mpll_val = 0 ;
//U32 divn_upll = 0 ;
#if ADS10
// __rt_lib_init(); //for ADS 1.0
#endif
Port_Init();//端口初始化
Isr_Init();//中断初始化
i = 2 ; //don't use 100M!
//boot_params.cpu_clk.val = 3;
//确定频率
switch ( i )
case 0: //200
key = 12;
mpll_val = (92<<12)|(4<<4)|(1);
break;
case 1: //300
key = 13;
mpll_val = (67<<12)|(1<<4)|(1);
break;
case 2: //400
key = 14;
mpll_val = (92<<12)|(1<<4)|(1);
break;
case 3: //440!!!
key = 14;
mpll_val = (102<<12)|(1<<4)|(1);
break;
default:
key = 14;
break;
//init FCLK=400M, so change MPLL first
ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3);
ChangeClockDivider(key, 12);
cal_cpu_bus_clk();
consoleNum = 0; // Uart 1 select for debug.选择串口号
Uart_Init( 0,115200 );//初始化串口参数以及时钟源
Uart_Select( consoleNum );//选择串口号
Beep(2000, 100);//蜂鸣器
Uart_SendByte('');//打印信息
Uart_SendByte('H');
while(1)
Uart_SendByte(count_num);
Uart_SendByte(' ');
count_num ++;
Delay(500);
从而让ARM一直向PC机发送从0-255数据,在PC机中显示结果如下:
这个看不了十六进制的数,我搞了个串口助手来显示:
上面那个是用mini2440实现的,那个通过UBOOT可以直接烧写程序,不过到了华恒的板子我就不知道为啥了,这个苦闷了我好久,今天在进入PPCBOOT中利用erase命令把那个linux系统檫除了,然后进入ppcboot命令行形式才可以jtag调试,不知道为啥,这次终于进了一次调试结果出来了。
下面出一张计数的图,感觉下成就感吧,虽然底层函数还没完全弄懂!
现在总结这些步骤吧,最开始在上电的时候不要立马启动系统,先要进入PPCBOOT模式命令行,然后再启动AXD调试器。
通过H-JATG软件可以看到是小端格式的,但是具体怎么设置暂时还不清楚,
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
rUTXH0即是写UTXH0的意思,UTXH0是第一个串口的发送缓冲寄存器!
2011/12/13日
还是阿南的程序给力啊,华恒板子带的程序没啥用
2011/12/21日
感慨日子过的飞快啊!可是我却没啥长进,先上程序吧:
;//呼叫主应用程序
b UART
UART
ldr r0, =GPHCON ;//设置RxD0,TxD0引脚
ldr r1, =0x2afaaa
str r1, [r0]
ldr r0, =GPHUP
ldr r1, =0x7ff
str r1, [r0] ; // The pull up function is disabled GPH[10:0]
ldr r0, =UFCON0 ;//禁用FIFO
ldr r1, =0x0
str r1, [r0]
ldr r0, =UMCON0 ;//禁用AFC
ldr r1, =0x0
str r1, [r0]
ldr r0, =ULCON0 ;//设置线寄存器
ldr r1, =0x3 ; //UART LINE CONFIG 正常模式,无奇偶校验,一个停止位,8个数据位
str r1, [r0]
ldr r0, =UCON0 ;//设置Uart0控制器
ldr r1, =0x245;//RX边沿触发,TX电平触发,禁用延时中断,使用RX 错误中断,正常操作模式,中断请求或表决模式
str r1, [r0]
ldr r0, =UBRDIV0 ;//设置波特率为115200
ldr r1, =0x1a ;//int(50700000 / 16 / 115200) - 1 = 26
str r1, [r0]
mov r1, #100
Delay
sub r1, r1, #0x1
bne Delay
;//开中断
ldr r0, =INTMSK
ldr r1, [r0]
and r1, r1, #0xefffffff
str r1, [r0]
MOV R5 , #127 ;//设置要打印的字符的个数
MOV R1 , #0x0 ;//设置要打印的字符
LOOP
LDR R3 , =UTRSTAT0
LDR R2 , [R3]
TST R2 ,#0x04 ;//判断发送缓冲区是否为空
BEQ LOOP ;//为空则执行下边的语句,不为空则跳转到LOOP
LDR R0 , =UTXH0
STR R1 ,[R0] ;//向数据缓冲区放置要发送的数据
ADD R1, R1, #1
SUB R5 ,R5, #0x01 ;//计数器减一
CMP R5 ,#0x0
BNE LOOP
LOOP2 B LOOP2
这个紧跟随这启动代码后面的一部分用汇编编的串口发送程序,设置相关寄存器,然后往PC端发送数据。
上一篇:ARM一些总结
下一篇:关于ARM的21个常用概念
推荐阅读最新更新时间:2024-11-20 18:30
设计资源 培训 开发板 精华推荐
- 采用 9V 碱性电池的 LTC3245IDE 高效 3.3V 微控制器电源的典型应用电路
- AM2G-2418SH30Z 18V 2瓦DC-DC转换器的典型应用
- LTC6262HTS8 SAR ADC 驱动器、运算放大器的典型应用
- NB6N14SMNGEVB,时钟/数据接收器评估板
- ADR3430 3V 输出微功率、高精度电压基准的典型应用
- 使用 Grayhill 的 SA-1111 的参考设计
- 使用 onsemi 的 KA79L05AZTA 的参考设计
- LTC3615IUF 双路 3A 同步降压型 DC/DC 转换器在主从机中的典型应用,用于使用 2MHz 外部时钟实现一致跟踪输出
- 使用 ROHM Semiconductor 的 BU4346 的参考设计
- -12V, 5V, 12V 交流转直流多路输出电源
- 【技术直播】 MPS、Nexperia、泰克专家齐聚,畅谈新能源汽车动力设计注意要点
- ADI•世健工业嘉年华——工业趴主题征文及投票活动!
- 阅读并了解是德科技汽车电子、物联网(IOT) 精彩专题,答题赢好礼!
- 《瑞萨电子低功耗MCU实战手册》来了,快去下载赢取好礼!
- 艾睿电子线上研讨会:英特尔FPGA深度学习加速技术 7月30日上午10:00-11:30 期待您的莅临!
- 是德科技“印象测试”微视频征集令
- 打卡最后一周,解锁TI汽车解决方案。解锁的数量决定奖品的质量!
- 【EE团】抢先体验 ST最新STM32F0308-DISCOVERY开发工具!
- 今日竞拍:TI SimpleLink Wifi CC3220S
