ARM mini2440裸奔 跑LCD手写代码
发布者:Huanle最新更新时间:2019-10-28 来源: 51hei关键字:ARM  mini2440裸奔  LCD 手机看文章 扫描二维码
随时随地手机看文章
ARM裸奔跑代码,LCD 实现手写功能,(mini2440)裸奔又进了一步,更一步熟悉ARM体系结构
部分源码预览:
; NAME: 2440INIT.S
; DESC: C start up codes
;       Configure memory, ISR ,stacks
;        Initialize C-variables
; HISTORY:
; 2002.02.25:kwtark: ver 0.0
; 2002.03.20:purnnamu: Add some functions for testing STOP,Sleep mode
; 2003.03.14:DonGo: Modified for 2440.
        GET option.inc
        GET memcfg.inc
        GET 2440addr.inc
BIT_SELFREFRESH EQU        (1<<22)
;Pre-defined constants
USERMODE    EQU         0x10
FIQMODE     EQU         0x11
IRQMODE     EQU         0x12
SVCMODE     EQU         0x13
ABORTMODE   EQU         0x17
UNDEFMODE   EQU         0x1b
MODEMASK    EQU         0x1f
NOINT       EQU         0xc0
;The location of stacks
UserStack        EQU        (_STACK_BASEADDRESS-0x3800)        ;0x33ff4800 ~
SVCStack        EQU        (_STACK_BASEADDRESS-0x2800)        ;0x33ff5800 ~
UndefStack        EQU        (_STACK_BASEADDRESS-0x2400)        ;0x33ff5c00 ~
AbortStack        EQU        (_STACK_BASEADDRESS-0x2000)        ;0x33ff6000 ~
IRQStack        EQU        (_STACK_BASEADDRESS-0x1000)        ;0x33ff7000 ~
FIQStack        EQU        (_STACK_BASEADDRESS-0x0)        ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
        GBLL    THUMBCODE
        [ {CONFIG} = 16
THUMBCODE SETL  {TRUE}
            CODE32
THUMBCODE SETL  {FALSE}
                MACRO
        MOV_PC_LR
                [ THUMBCODE
            bx lr
            mov        pc,lr
        MEND
                MACRO
        MOVEQ_PC_LR
                [ THUMBCODE
        bxeq lr
            moveq pc,lr
        MEND
                MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
        sub        sp,sp,#4        ;decrement sp(to store jump address)
        stmfd        sp!,{r0}        ;PUSH the work register to stack(lr does not push because it return to original address)
        ldr     r0,=$HandleLabel;load the address of HandleXXX to r0
        ldr     r0,[r0]         ;load the contents(service routine start address) of HandleXXX
        str     r0,[sp,#4]      ;store the contents(ISR) of HandleXXX to stack
        ldmfd   sp!,{r0,pc}     ;POP the work register and pc(jump to ISR)
        MEND
        IMPORT  |Image$RO$Base|        ; Base of ROM code
        IMPORT  |Image$RO$Limit|  ; End of ROM code (=start of ROM data)
        IMPORT  |Image$RW$Base|   ; Base of RAM to initialise
        IMPORT  |Image$ZI$Base|   ; Base and limit of area
        IMPORT  |Image$ZI$Limit|  ; to zero initialise
        IMPORT        MMU_SetAsyncBusMode
        IMPORT        MMU_SetFastBusMode        ;
        IMPORT  Main    ; The main entry of mon program
        AREA    Init,CODE,READONLY
        ENTRY
        EXPORT        __ENTRY
__ENTRY
ResetEntry
        ;1)The code, which converts to Big-endian, should be in little endian code.
        ;2)The following little endian code will be compiled in Big-Endian mode.
        ;  The code byte order should be changed as the memory bus width.
        ;3)The pseudo instruction,DCD can not be used here because the linker generates error.
        ASSERT        :DEF:ENDIAN_CHANGE
        [ ENDIAN_CHANGE
            ASSERT  :DEF:ENTRY_BUS_WIDTH
            [ ENTRY_BUS_WIDTH=32
                b        ChangeBigEndian            ;DCD 0xea000007
            [ ENTRY_BUS_WIDTH=16
                andeq        r14,r7,r0,lsl #20   ;DCD 0x0007ea00
            [ ENTRY_BUS_WIDTH=8
                streq        r0,[r0,-r10,ror #1] ;DCD 0x070000ea
            b        ResetHandler
        b        HandlerUndef        ;handler for Undefined mode
        b        HandlerSWI        ;handler for SWI interrupt
        b        HandlerPabort        ;handler for PAbort
        b        HandlerDabort        ;handler for DAbort
        b        .                ;reserved
        b        HandlerIRQ        ;handler for IRQ interrupt
        b        HandlerFIQ        ;handler for FIQ interrupt
;@0x20
        b        EnterPWDN        ; Must be @0x20.
ChangeBigEndian
;@0x24
            DCD        0xee110f10        ;0xee110f10 => mrc p15,0,r0,c1,c0,0
            DCD        0xe3800080        ;0xe3800080 => orr r0,r0,#0x80;  //Big-endian
            DCD        0xee010f10        ;0xee010f10 => mcr p15,0,r0,c1,c0,0
            DCD 0x0f10ee11
            DCD 0x0080e380
            DCD 0x0f10ee01
        [ ENTRY_BUS_WIDTH=8
            DCD 0x100f11ee
            DCD 0x800080e3
            DCD 0x100f01ee
        DCD 0xffffffff  ;swinv 0xffffff is similar with NOP and run well in both endian mode.
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        b ResetHandler
HandlerFIQ      HANDLER HandleFIQ
HandlerIRQ      HANDLER HandleIRQ
HandlerUndef    HANDLER HandleUndef
HandlerSWI      HANDLER HandleSWI
HandlerDabort   HANDLER HandleDabort
HandlerPabort   HANDLER HandlePabort
IsrIRQ
        sub        sp,sp,#4       ;reserved for PC
        stmfd        sp!,{r8-r9}
        ldr        r9,=INTOFFSET
        ldr        r9,[r9]
        ldr        r8,=HandleEINT0
        add        r8,r8,r9,lsl #2
        ldr        r8,[r8]
        str        r8,[sp,#8]
        ldmfd        sp!,{r8-r9,pc}
        LTORG
; ENTRY
ResetHandler
        ldr        r0,=WTCON       ;watch dog disable
[1] [2] [3] [4] [5] [6]
关键字:ARM  mini2440裸奔  LCD 引用地址:ARM mini2440裸奔 跑LCD手写代码
上一篇:arm开关中断汇编接口
下一篇:【嵌入式学习笔记二】烧录制作好的镜像到4412开发板中
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
  • 学习ARM开发(16)
    ARM有很多东西要学习,那么中断,就肯定是需要学习的东西。自从CPU引入中断以来,才真正地进入多任务系统工作,并且大大提高了工作效率。采 ...
  • 学习ARM开发(17)
    因为嵌入式系统里全部要使用中断的,那么我的S3C44B0怎么样中断流程呢?那我就需要了解整个流程了。要深入了解,最好的方法,就是去写程序 ...
  • 学习ARM开发(18)
    上一次已经了解ARM的中断处理过程,并且可以设置中断函数,那么它这样就可以工作了吗?答案是否定的。因为S3C44B0还有好几个寄存器是控制中 ...
  • 嵌入式系统调试仿真工具
    嵌入式硬件系统设计出来后就要进行调试,不管是硬件调试还是软件调试或者程序固化,都需要用到调试仿真工具。 随着处理器新品种、新 ...
  • 最近困扰在心中的一个小疑问终于解惑了~~
    最近在驱动方面一直在概念上不能很好的理解 有时候结合别人写的一点usb的例子能有点感觉,但是因为arm体系里面没有像单片机那样直接讲解引脚 ...
  • 学习ARM开发(1)
  • 学习ARM开发(2)
  • 学习ARM开发(4)
  • 学习ARM开发(6)
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
