N76e003单片机内部没有EEPROM,但是可以使用 APROM模拟EEPROM功能,代码如下:
eeprom.h
1 #ifndef _EEPROM_H_
2 #define _EEPROM_H_
4 //EEPROM 指令
5 #define BYTE_PROGRAM_AP 0x21 //APROM 字节编程(数据写入)
6 #define PAGE_ERASE_AP 0x22 //APROM 页擦除 (128字节)
7 #define BYTE_Read_AP 0x00 //APROM 字节读 (数据字节)
10 // EEPROM起始地址
11 #define EEPROM_START_ADDRESS 0x0200
13 void Eeprom_Unlock(void);
14 void Eeprom_Locked(void);
15 void Eeprom_IAP_process(void);
16 void Eeprom_Erase_page(unsigned short address,unsigned char Data);
17 void Eeprom_Byte_write(unsigned short address,unsigned char Data);
18 unsigned char Eeprom_Erase_read(unsigned short address);
19
21 #endif /* _EEPROM_H_ */
eeprom.c
1 #include 2 #include "eeprom.h" 3 #include "data.h" 4 5 volatile unsigned char code Data_Flash[128] _at_ EEPROM_START_ADDRESS; //不被优化 6 7 /************************************************************************** 8 Function: Eeprom_Unlock 9 Description: 解锁 Eeprom 10 Input: no 11 Output: no 12 Return: no 13 **************************************************************************/ 14 void Eeprom_Unlock(void){ 15 //开启 在线编程模式(LDROM和APROM) 16 TA = 0xAA; //CHPCON受TA保护 17 TA = 0x55; 18 CHPCON |= 0x01; //IAPEN = 1, 启用IAP模式(CHPCON芯片控制寄存器) 19 //开启 编程程序模式(APROM) 20 TA = 0xAA; //IAPUEN受TA保护 21 TA = 0x55; 22 IAPUEN |= 0x01; //APUEN = 1, 启用APROM更新(更新使能) 23 } 24 /************************************************************************** 25 Function: Eeprom_Locked 26 Description: 解锁 Eeprom 27 Input: no 28 Output: no 29 Return: no 30 **************************************************************************/ 31 void Eeprom_Locked(void) 32 { 33 //关闭 编程程序模式(APROM) 34 TA = 0xAA; //IAPUEN受TA保护 35 TA = 0x55; 36 IAPUEN &= ~0x01; //APUEN = 0,禁用APROM更新 37 //关闭 在线编程模式(LDROM和APROM) 38 TA = 0xAA; //CHPCON受TA保护 39 TA = 0x55; 40 CHPCON &= ~0x01; //IAPEN = 0,禁用IAP模式 41 } 42 /************************************************************************** 43 Function: Eeprom_IAP_process 44 Description: IAP 处理 45 Input: no 46 Output: no 47 Return: no 48 **************************************************************************/ 49 void Eeprom_IAP_process(void){ 50 bit EA_status; 51 //IAP 执行 52 EA_status = EA; 53 EA = 0; 54 TA = 0xAA; 55 TA = 0x55; 56 IAPTRG |= 0x01; //IAP 执行(设置该位为1开始执行IAP。该指令后,CPU保持程序计数器(PC) ,IAP硬件自动管理控制该过程。IAP完成后,程序计数器继续执行下一个指令。IAPGO位自动清零,保持为0。在触发IAP动作前,如果中断打开应该临时关闭因为硬件限制。) Eeprom_Unlock(); //Eeprom 上锁 57 EA = EA_status; 58 } 59 /************************************************************************** 60 Function: Eeprom_Erase_page 61 Description: 擦除页面 Eeprom 62 Input: - address 指定擦除页面的绝对地址 63 - Data Eeprom擦除后的数据 64 Output: no 65 Return: no 66 **************************************************************************/ 67 void Eeprom_Erase_page(unsigned short address,unsigned char Data) 68 { 69 unsigned char High_address = address >> 8; //取高位 70 unsigned char Low_address = address; //取低位 71 Eeprom_Unlock(); //Eeprom 解锁 72 //擦除页面 73 IAPCN = PAGE_ERASE_AP; //页擦除 74 IAPAH = High_address; //页面地址高8位 75 IAPAL = Low_address; //页面地址低8位 76 IAPFD = Data; //擦除数据值 77 //IAP 执行 78 Eeprom_IAP_process(); //执行上面设置 79 Eeprom_Locked(); //Eeprom 上锁 80 } 81 /************************************************************************** 82 Function: Eeprom_Byte_write 83 Description: 字节编程 Eeprom 84 Input: - address 指定更改数据的绝对地址 85 - Data Eeprom写入的数据 86 Output: no 87 Return: no 88 **************************************************************************/ 89 void Eeprom_Byte_write(unsigned short address,unsigned char Data) 90 { 91 unsigned char High_address = address >> 8; //取高位 92 unsigned char Low_address = address; //取低位 93 Eeprom_Unlock(); //Eeprom 解锁 94 //字节编程 95 IAPCN = BYTE_PROGRAM_AP; //字节编程 96 IAPAH = High_address; //字节编程地址高8位 97 IAPAL = Low_address; //字节编程地址低8位 98 IAPFD = Data; //写入的数据 99 //IAP 执行 100 Eeprom_IAP_process(); //执行上面设置 101 Eeprom_Locked(); //Eeprom 上锁 102 } 103 /************************************************************************** 104 Function: Eeprom_Erase_read 105 Description: 字节读 Eeprom 106 Input: - address 指定读出数据的绝对地址 107 Output: no 108 Return: IAPFD 读出的数据 109 **************************************************************************/ 110 unsigned char Eeprom_Erase_read(unsigned short address){ 111 unsigned char High_address = address >> 8; //取高位 112 unsigned char Low_address = address; //取低位 113 //字节读 114 IAPCN = BYTE_Read_AP; //字节读 115 IAPAH = High_address; //字节读地址高8位 116 IAPAL = Low_address; //字节读地址低8位 117 //IAP 执行 118 Eeprom_IAP_process(); //执行上面设置 119 return IAPFD; 120 }
上一篇:单片机成长之路(51基础篇) - 023 N76e003 系统时钟切换到外部
下一篇:(51基础篇) - 021 STC89C51系列单片机 内部EEPROM 驱动
推荐阅读最新更新时间:2024-11-12 03:16
设计资源 培训 开发板 精华推荐
- 使用 Analog Devices 的 LTC2415CGN 的参考设计
- MIC94345-SYCS 3.3V 输出电压、500mA LDO 采用纹波阻断技术的典型应用
- UsbSafe²:一个开放的、可编程的加密狗,用于保护 USB 设备免受 USB 主机和充电器的影响
- USB_B_USB_C
- 咸鱼墨迹空气果AirNutFun改ESP8266主控
- SD-MODE
- 用户界面 - 基于 CY8C24423 PSoC 的电阻式触摸屏控制器
- TLE 4263 5V 低压降稳压器的典型应用
- 使用 ROHM Semiconductor 的 BD49K37G-TL 的参考设计
- ADP1712-EVALZ,随 ADP1712 可调输出电压选项器件提供的评估板具有额外的 R1 和 R2 电阻来设置输出电压
- Waymo打造最大弱势道路使用者交通事故数据集 可帮助指导自动驾驶系统研发
- 车载显示,大步向前
- 新专利:未来福特汽车或将配备亮度管理系统
- 科学家研发基于AI的身份验证工具 可保护车辆免受网络攻击威胁
- Microchip推出广泛的IGBT 7 功率器件组合,专为可持续发展、电动出行和数据中心应用而设计
- 面向未来驾驶体验 博世推出新型微电子技术
- 英飞凌与马瑞利合作 利用AURIX™ TC4x MCU系列推动区域控制单元创新
- 5C超充,该怎么卷?
- 《2025年度中国汽车十大技术趋势》正式揭晓!你最看好哪个?
- Microchip推出新型VelocityDRIVE™软件平台和车规级多千兆位以太网交换芯片,支持软件定义汽车
