代码:
#include 实验效果:
typedef unsigned char u8;
typedef unsigned int u16;
/********端口定义*********/
#define DATA P0
sbit seg_sel = P1^4;
sbit bit_sel = P1^5;
sbit start = P3^2;
sbit store = P3^3;
sbit diskey = P3^4;
sbit reset = P3^5;
sbit led = P1^0;
/********变量定义*********/
u16 tem_ms;
u8 n_ten_ms,n_sec,n_min;
u8 run_flag;//当run_flag为1,代表开始计数
u8 temp_buf[5][3];
u8 arr_pt;
u8 code seg_tab[]={
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e
u8 code bit_tab[]={
0x10,0x20,0x40,0x80,
0x01,0x02,0x04,0x08
void delay(unsigned int y)
unsigned int x,z;
for(x=y; x>0; x--)
for(z=110; z>0; z--);
void display_led(u8 which_bit, u8 which_number)
bit_sel = 1;//Q[7..0]=D[7..0]
DATA = bit_tab[which_bit];
bit_sel = 0;//BIT[7..0]=0x80
seg_sel = 1;//Q[7..0]=D[7..0]
DATA = seg_tab[which_number];
seg_sel = 0;
void display(u8 which_bit, u8 which_number)
u8 x,y;
x = which_number/10;//分离十位
y = which_number%10;//分离个位
if (which_bit == 1)
display_led(1, x);
delay(2);
display_led(0, y);
delay(2);
if (which_bit == 2)
display_led(4, x);
delay(2);
display_led(3, y);
delay(2);
if (which_bit == 3)
display_led(7, x);
delay(2);
display_led(6, y);
delay(2);
void reflash (void)
display(1, n_ten_ms);
display(2, n_sec);
display(3, n_min);
void main (void)
TMOD = 0x01;//设置定时/计数器T0
TH0 = (65535-10000) / 256;
TL0 = (65535-10000) % 256;
EA = 1;//开放总中断
ET0 = 1;//开放定时器0的溢出中断
//TR0 = 1;
while (1)
if (start == 0)
delay(5);
if (start == 0)
run_flag = ~run_flag;
} while(!start);
if (run_flag)
TR0 = 1; //开始计数
else if (!run_flag)
TR0 = 0;
if (diskey == 0)
delay (5);
if (diskey == 0)
arr_pt --;
n_ten_ms = temp_buf[arr_pt][0];
n_sec = temp_buf[arr_pt][1];
n_min = temp_buf[arr_pt][2];
} while (!diskey);
if (reset == 0)
delay(5);
if (reset == 0)
n_ten_ms = 0;
n_sec = 0;
n_min = 0;
} while(!reset);
if (store == 0)
delay(5);
if (store == 0)
if ((arr_pt >=0) && (arr_pt< 5))
temp_buf[arr_pt][0] = n_ten_ms;
temp_buf[arr_pt][1] = n_sec;
temp_buf[arr_pt][2] = n_min;
arr_pt++;
} while(!store);
reflash();
void t0_server(void) interrupt 1
n_ten_ms++;
if (n_ten_ms >= 100)
n_ten_ms = 0;
n_sec++;
if (n_sec >= 60)
n_sec = 0;
n_min++;
if (n_min >= 60)
n_min = 0;
电路图:
上一篇:延时Led灯
下一篇:1602液晶显示实验
设计资源 培训 开发板 精华推荐
- LTC6244 的典型应用 - 双路 50MHz、低噪声、轨到轨、CMOS 运算放大器
- ZTL432 大电流并联稳压器的典型应用
- AM2M-1212DH30-NZ ±12 Vout、2W 双路输出 DC-DC 转换器的典型应用
- 使用 NXP Semiconductors 的 TDA8580 的参考设计
- MAXREFDES1178:采用MAX17690,MAX17606和MAX5969B的PoE供电设备和同步12V / 600mA无光反激式DC-DC转换器
- FEVSPIN32G4VB
- 基于LED7707的LCD面板背光演示板
- LTC1174-5 高效降压转换器的典型应用电路
- 使用 Diodes Incorporated 的 ZXRE4041ERSTOB 的参考设计
- 经典老功放后级 2n3055
