今天下午看了一下MSP430的看门狗的基本用法
看门狗是为了防止程序跑飞而设定的,但是由于看门狗是一个类似于定时器,因此可以把他当作定时器来使用
示例代码:用看门狗定时器使一个led闪烁
#include void main( void ) { // Stop watchdog timer to prevent time out reset WDTCTL = WDT_MDLY_32;//宏定义 IE1 |=WDTIE; //允许看门狗定时器中断 P2DIR |= BIT7; _BIS_SR(LPM0_bits+GIE);//在这里的话将cpu进入低功耗模式 } #pragma vector = WDT_VECTOR __interrupt void watchdag_timer(void) { P2OUT ^=BIT7;//异或操作基本上是取反操作 } 注意这里有一个比较好的宏定义:WDTCTL = WDT_MDLY_32;进入该宏定义会发现类似的宏定义有很多 /* WDT-interval times [1ms] coded with Bits 0-2 */ /* WDT is clocked by fSMCLK (assumed 1MHz) */ #define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */ #define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms " */ #define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms " */ #define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */ /* WDT is clocked by fACLK (assumed 32KHz) */ #define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms " */ #define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */ #define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */ #define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */ /* Watchdog mode -> reset after expired time */ /* WDT is clocked by fSMCLK (assumed 1MHz) */ #define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */ #define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms " */ #define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms " */ #define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */ /* WDT is clocked by fACLK (assumed 32KHz) */ #define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms " */ #define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */ #define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */ #define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */ 这里我们可以根据通常的需要,选择合适的定时时间 说到定时时间,这里又不得不讲一下中断函数,在IAR这个编译环境中,一般中断函数的写法是 #pragma vector = 中断向量 __interrupt void 中断函数名(void) { 用户程序; } 注意,中断向量可以在430的头文件中查找,中断函数的声明必须是void 中断函数名(void),这是因为中断函数没有返回值,也没有中断的形式参数 但是本人又在网站上看到另外一种用switch来写的,就是一个中断源对应几个中断向量,这种写法目前我还没有见过源码,所以不好总结
上一篇:MSP430F5538A watchdog
下一篇:MSP430看门狗的使用
设计资源 培训 开发板 精华推荐
- PAM8302A 2.5W无滤波器D类单声道音频放大器典型应用
- LTM9003 的典型应用 - 12 位数字预失真接收器子系统
- MTRCKTSBN5604P: 采用恩智浦MPC5604P MCU的3相无传感器BLDC开发套件
- SI5342-D-EVB,基于 Si5342 任意频率、任意输出、抖动衰减时钟乘法器的评估板,修订版 D
- 具有基准电压源的 LT1086CT 低压差稳压器的典型应用
- L6480 Discovery:探索L6480电机控制器的开发工具
- LM2594ASCBCKGEVB:降压开关稳压器评估板
- 用于汽车应用的 LT3973HDD-5 3.3V 降压转换器的典型应用
- 使用 Microchip Technology 的 SY89534L 的参考设计
- LT6604CUFF-10 双路匹配、5 阶、10MHz 低通滤波器的典型应用电路
