STM32F0 系列产品基于超低功耗的 ARM Cortex-M0 处理器内核,整合增强的技术和功能,瞄准超低成本预算的应用。该系列微控制器缩短了采用 8 位和 16 位微控制器的设备与采用 32 位微控制器的设备之间的性能差距,能够在经济型用户终端产品上实现先进且复杂的功能。本文为大家介绍stm32矩阵键盘原理图及程序
stm32矩阵键盘原理图
stm32矩阵键盘程序介绍
主要实现:扫描矩阵键盘,将检测到的数据通过spi 通信发送到数码管显示。
主要步骤:
1:初始化时钟
void RCC_Configuration(void)
//----------使用外部RC晶振-----------
RCC_DeInit(); //初始化为缺省值
RCC_HSEConfig(RCC_HSE_ON); //使能外部的高速时钟
while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //等待外部高速时钟使能就绪
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
FLASH_SetLatency(FLASH_Latency_2); //Flash 2 wait state
RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ
RCC_PLLCmd(ENABLE); //Enable PLLCLK
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock
while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system clock source
2:配置管脚
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//开启GPIOD外设时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//D0~D3
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//上拉输入
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//D4~D7
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
//初始化管脚电平
GPIO_SetBits(GPIOD, GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3);
GPIO_ResetBits(GPIOD, GPIO_Pin_4 | GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_SPI1, ENABLE); //开启SPI1和GPIOA外设时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//设置SPI的四个引脚模式
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //设置GPIO A1管脚 用于锁存74HC595输出
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI数据模式 双线双向全双工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI工作模式 主模式
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI数据大小
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //设置时钟的极性
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //设置时钟的相位
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; //NSS脚硬件置位
SPI_InitStructure.SPI_BaudRatePrescaler =SPI_BaudRatePrescaler_64;//预分频值
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;// 数据从高位传输
SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值
SPI_I2S_DeInit(SPI1); //将外设SPI1寄存器重设为缺省值;
SPI_Init(SPI1, &SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE);//使能SPI1外设
3:编写矩阵键盘扫描函数KEY.c
u8 shu=16;
void KeyScan(void)
u8 i;
if((GPIO_ReadInputData(GPIOD) & 0x0f) != 0x0f )
Delay_MS(20);
GPIO_SetBits(GPIOD, GPIO_Pin_4 | GPIO_Pin_5| GPIO_Pin_6);
GPIO_ResetBits(GPIOD, GPIO_Pin_7);
switch(GPIO_ReadInputData(GPIOD) & 0x0f)
case 0x07: shu=0; break;
case 0x0b: shu=1; break;
case 0x0d: shu=2; break;
case 0x0e: shu=3; break;
GPIO_SetBits(GPIOD, GPIO_Pin_4 | GPIO_Pin_5| GPIO_Pin_7);
GPIO_ResetBits(GPIOD, GPIO_Pin_6);
case 0x07: shu=4; break;
case 0x0b: shu=5; break;
case 0x0d: shu=6; break;
case 0x0e: shu=7; break;
GPIO_SetBits(GPIOD, GPIO_Pin_4 | GPIO_Pin_6| GPIO_Pin_7);
GPIO_ResetBits(GPIOD, GPIO_Pin_5);
case 0x07: shu=8; break;
case 0x0b: shu=9; break;
case 0x0d: shu=10; break;
case 0x0e: shu=11; break;
GPIO_SetBits(GPIOD, GPIO_Pin_7 | GPIO_Pin_5| GPIO_Pin_6);
GPIO_ResetBits(GPIOD, GPIO_Pin_4);
case 0x07: shu=12; break;
case 0x0b: shu=13; break;
case 0x0d: shu=14; break;
case 0x0e: shu=15; break;
while((i《50)&&((GPIO_ReadInputData(GPIOD) & 0x0f) != 0x0f))
i++;
Delay_MS(10);
4: SPI传送数据函数
void Display_Data(u8 data)
u8 i=data;
PAOut(1)=0;
SPI_I2S_SendData(SPI1,DSY_CODE[i]);
Delay_MS(2);
PAOut(1)=1;
Delay_MS(1000);
5:主函数
#include“stm32f10x_lib.h”
#include
#include“Exboard.h”
u8 DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff};
int main(void)
{ //u8 i;
RCC_Configuration();
GPIO_Configuration();
//EXTI_Configuration();
//NVIC_Configuration();
while(1)
KeyScan();
Display_Data(shu);
附录:Exboard.h
#ifndef _EXBOARD_H
#define _EXBOARD_H
#endif
#define GPIOA_IDR (GPIOA_BASE+0x08)
#define GPIOA_ODR (GPIOA_BASE+0x0c)
#define GPIOB_IDR (GPIOB_BASE+0x08)
#define GPIOB_ODR (GPIOB_BASE+0x0c)
#define GPIOC_IDR (GPIOC_BASE+0x08)
#define GPIOC_ODR (GPIOC_BASE+0x0c)
#define GPIOD_IDR (GPIOD_BASE+0x08)
#define GPIOD_ODR (GPIOD_BASE+0x0c)
#define GPIOE_IDR (GPIOE_BASE+0x08)
#define GPIOE_ODR (GPIOE_BASE+0x0c)
#define GPIOF_IDR (GPIOF_BASE+0x08)
#define GPIOF_ODR (GPIOF_BASE+0x0c)
#define GPIOG_IDR (GPIOG_BASE+0x08)
#define GPIOG_ODR (GPIOG_BASE+0x0c)
#define BitBang(Addr,BitNum) *((volatile unsigned long*)(((Addr&0xf0000000)+ 0x2000000)+(((Addr&0xfffff)《《5)+(BitNum《《2))))
#define PAIn(n) BitBang(GPIOA_IDR,n)
#define PAOut(n) BitBang(GPIOA_ODR,n)
#define PBIn(n) BitBang(GPIOB_IDR,n)
#define PBOut(n) BitBang(GPIOB_ODR,n)
#define PCIn(n) BitBang(GPIOC_IDR,n)
#define PCOut(n) BitBang(GPIOC_ODR,n)
#define PDIn(n) BitBang(GPIOD_IDR,n)
#define PDOut(n) BitBang(GPIOD_ODR,n)
#define PEIn(n) BitBang(GPIOE_IDR,n)
#define PEOut(n) BitBang(GPIOE_ODR,n)
#define PFIn(n) BitBang(GPIOF_IDR,n)
#define PFOut(n) BitBang(GPIOF_ODR,n)
#define PGIn(n) BitBang(GPIOG_IDR,n)
#define PGOut(n) BitBang(GPIOG_ODR,n)
#define KEY1 PEIn(0)
#define LED1 PDOut(13)
#define KEY2 PCIn(13)
#define LED2 PGOut(14)
void Delay_MS(u16 dly);
void RCC_Configuration(void);
void GPIO_Configuration(void);
//void EXTI_Configuration(void);
//void NVIC_Configuration(void);
extern void KeyScan(void);
void Display_Data(u8 data);
extern u8 shu;
上一篇:stm32寄存器版矩阵键盘库函数(附详细注释)
下一篇:STM32的GPIO输出编程实例之点亮三色LED
推荐阅读最新更新时间:2024-11-09 20:53
设计资源 培训 开发板 精华推荐
- KSZ8775CLX-EVAL,用于 KSZ8775CLX 以太网交换机的评估板,用于以太网 LAN 和 WAN 接口
- DC2174A-B,用于 LTC3882EUJ 双相单输出 PMBU 降压的演示板,7V = VIN = 14V,0.5V = VOUT0 = 2V @ 70A
- LTC1734,具有 0mA、200mA、500mA 或 700mA 输出电流的可编程电流源
- 使用 ROHM Semiconductor 的 BD5260 的参考设计
- 使用 Analog Devices 的 LTC1148 的参考设计
- CH340G方案验证板
- 基于STIB1560DM2T-L SLLIMM第二系列MOSFET IPM的1500 W电机控制电源板
- AM1S-0518SH30Z 1W DC-DC转换器典型应用
- LT1076CR 基本正降压转换器的典型应用
- SMOL DAPLink
