msp430g2553硬件IIC
发布者:脑力激荡最新更新时间:2020-04-29 来源: eefocus关键字:msp430g2553  硬件IIC  从器件地址 手机看文章 扫描二维码
随时随地手机看文章
#include "msp430g2553.h"
#include "uart.h"
unsigned char RX_Data;
void I2C_Init(unsigned char SA);//I2C初始化,SA为从器件地址
void I2C_ReadData(unsigned char address);//I2C读出某一地址的数据
unsigned char I2C_WriteData(unsigned char address,unsigned char data);//I2C向某一地址写入数据
void delay(void);
  P1SEL |= (BIT6 + BIT7);
  P1SEL2|= (BIT6 + BIT7);
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 |= UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 30;                             // fSCL = SMCLK/80 = ~100kHz
  UCB0BR1 = 0;
  UCB0CTL0 &= ~UCSLA10; // 7位地址模式
  UCB0I2CSA = SA;                         // Slave Address is 2ch
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  delay();
    while( UCB0CTL1& UCTXSTP );
    UCB0CTL1 |= UCTR;                // 写模式
    UCB0CTL1 |= UCTXSTT;             // 发送启动位
    UCB0TXBUF = address;           // 发送字节地址
    // 等待UCTXIFG=1与UCTXSTT=0 同时变化等待一个标志位即可
    while((IFG2 & UCB0TXIFG)==0)
        if( UCB0STAT& UCNACKIFG )      // 若无应答 UCNACKIFG=1
            return 1;
    UCB0TXBUF = data;          // 发送字节内容
    while((IFG2 & UCB0TXIFG)==0);     // 等待UCTXIFG=1
    UCB0CTL1 |= UCTXSTP;
    while(UCB0CTL1& UCTXSTP);       // 等待发送完成
    return 0;
unsigned char I2C_WriteNData( unsigned char address, unsigned char *pWbuf, unsigned char len)
    unsigned char i;
            return 1;
  for( i= 0; i < len; i++)
    UCB0TXBUF = *pWbuf++;      // 发送寄存器内容
    while(UCB0CTL1& UCTXSTP);   // 等待UCTXIFG=1
  return 0;
    UCB0CTL1 |= UCTR ;
    UCB0CTL1 |= UCTXSTT;             // I2C TX, start condition
    UCB0TXBUF = address;////eeprom low addr
    UCB0CTL1 &= ~UCTR;             // I2C RX,
    while(UCB0CTL1&UCTXSTT);
    while((IFG2&UCB0RXIFG)==0);
    RX_Data = UCB0RXBUF;
    while(UCB0CTL1 & UCTXSTP);
unsigned char  I2C_ReadNData(unsigned char address, unsigned char *pRead, unsigned char len )
    unsigned char i;
    UCB0CTL1 |= UCTXSTT; // 发送启动位和写控制字节
    UCB0CTL1 &= ~UCTR; // 读模式
    UCB0CTL1 |= UCTXSTT; // 发送启动位和读控制字节
    while(UCB0CTL1& UCTXSTT); // 等待UCTXSTT=0
    // 若无应答 UCNACKIFG = 1
    for( i= 0; i< len -1 ; i++)
        while((IFG2&UCB0RXIFG)==0);  // 读取字节内容,不包括最后一个字节内容
        *pRead++= UCB0RXBUF;
    UCB0CTL1 |= UCTXSTP; // 在接收最后一个字节之前发送停止位
    while((IFG2&UCB0RXIFG)==0); // 读取最后一个字节内容
    *pRead = UCB0RXBUF;
    return 0;
void delay(void)
  unsigned int i,n;
  for(i=0;i<100;i++)
    for(n=0;n<0xff;n++);
int main( void )
    unsigned char ReadBuf[10];
    unsigned char temp = 1;
    // Stop watchdog timer to prevent time out reset
    WDTCTL = WDTPW + WDTHOLD;
    BCSCTL1=CALBC1_1MHZ;
    DCOCTL=CALDCO_1MHZ;
    Uart_Init();
    P1DIR |= BIT0;
    P1OUT |= BIT0;
    I2C_Init(0x51);//1010 000X>>1
    //I2C_WriteData(0x02,5);
    _EINT();
    //I2C_Init(0x51);//1010 000X>>1
    //I2C_ReadData(tUart.RecBuf[0]-0x30);
    while(1)
        if(tUart.RecFlag)
            tUart.RecFlag = 0;
            tUart.Len = 0;
            I2C_WriteData(0x03,temp++);
            I2C_ReadNData(0x02, ReadBuf, 8 );
            UartSendStr(ReadBuf);
            //UartSendByte(RX_Data);
关键字:msp430g2553  硬件IIC  从器件地址 引用地址:msp430g2553硬件IIC
上一篇:MSP430FR2433 LaunchPad板子energy trace技术测量电流电压
下一篇:基于MSP430F149的超声波测距
推荐阅读最新更新时间:2024-11-22 11:49
MSP430G2553时钟外部晶振配置说明
摘要:关于MSP430G2553的时钟分类以及ACLK,MCLK和SMCLK的时钟源以下均不会做具体解释,在百度或者CSDN能搜到好多相关的说明文章。本文主要论证一下ACLK,MCLK和SMCLK可选作为时钟源的LFXT1CLK的频率是多少。在BAIDU以及TAOBAO中搜索不到下图电路板中的无源晶振,所以想要自己动手对其进行推导。(2553的技术文档介绍中该晶振为32kHz晶振) 主要思路: 配置相关时钟寄存器,将外部晶振LFXT1CLK作为SMCLK的时钟源,SMCLK作为定时器A的时钟源,配置定时器使相应引脚输出PWM波,根据PWM波的频率,最终推导出LFXT1CLK对应的外部无源晶振的频率。 小试牛刀 本步主要
[单片机]
<font color='red'>MSP430G2553</font>时钟外部晶振配置说明
stm32硬件i2c stm32硬件iic缺陷如何解决
STM32单片机具有IIC接口,IIC接口具有多主机功能、主设备功能、C地址检测、产生和检测7位/10位地址和广播呼叫和支持不同的通讯速度。 STM硬件I2C的状态标签如下: 发送器/接收器模式标志、字节发送结束标志、中先忙标志、错误标志 STM硬件有9个寄存器。 STM32硬件I2C的CLK在50kHz及以下情况下工作,短时间内不会出现任何情况下的卡住。 STM32硬件I2C的CLK在常用的100kHz和400kHz下工作,一小时内大概率出现卡住现象。 STM32硬件I2C的CLK在任何频率下工作,在读取或发送数据时不允许有其他中断事件干扰,否则将有卡住现象。 总的来说,STM32硬件I2C是个坑,对正常工作的环境要求非常高
[单片机]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
