之前做的舵机云台自动瞄色块的装置 现在已经拆掉了,所以没有图片
就是类似19年国赛电磁的发挥部分要求
单片机源程序如下:
#include "control.h"
u8 key = 0;
u8 mode = 0;
u8 sign = 0;
u16 mode_r = 0;
u16 mode_p = 0;
void TIM1_UP_IRQHandler(void) //TIM1中断
if(TIM_GetITStatus(TIM1,TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM 中断源
TIM_ClearITPendingBit(TIM1,TIM_IT_Update); //清除TIMx的中断待处理位:TIM 中断源
key = KEY_Scan();
mode = click_N_Double(50);
if(key == 1)
LED0 = 1;
mode_r++;
if(mode_r <= 6)
roll = 1500 + 110 * mode_r; //9.9度
if(mode_r > 6)
roll = 1500 - 110 * (mode_r - 6);
if(mode_r > 12)
roll = 1500;
mode_r = 0;
delay_ms(100);
LED0 = 0;
if(key == 2)
LED1 = 1;
mode_p++;
if(mode_p <= 3)
pitch = 1000 + 110 * mode_p; //9.9度
if(mode_p > 3)
pitch = 1000 - 110 * (mode_p - 3); //9.9度
if(mode_p > 6)
pitch = 1000;
mode_p = 0;
delay_ms(100);
LED1 = 0;
if(key == 3)
LED0 = 1;
LED1 = 1;
TIM_SetCompare1(TIM4,roll);
TIM_SetCompare2(TIM4,pitch);
delay_ms(100);
LED0 = 0;
LED1 = 0;
if(mode == 2)
sign = 1;
if(sign == 1)
autoaid();
void autoaid(void)
delay_ms(100);
if(OpenMV_Rx_BUF[0] < 140)
roll += 33;
if(roll >= 2160)
roll -= 33;
if(OpenMV_Rx_BUF[0] > 180)
roll -= 33;
if(roll <= 840)
roll += 33;
if(OpenMV_Rx_BUF[1] < 90)//0x5F 95
pitch += 33;
if(pitch >= 1440)
pitch -= 33;
if(OpenMV_Rx_BUF[1] > 140)//0x87 135
pitch -= 33;
if(pitch <= 670)
pitch += 33;
import sensor, image, time
from pyb import UART
import json
threshold = [(32, 60, 127, 41, -128, 127)]
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames(time = 2000 )
sensor.set_auto_whitebal(False)
#关闭白平衡。白平衡是默认开启的,在颜色识别中,需要关闭白平衡。
clock = time.clock()
uart = UART(3, 115200)
uart.init(115200, bits=8, parity=None, stop=1) #8位数据位,无校验位,1位停止位、
while(True):
clock.tick()
img = sensor.snapshot()
blob = img.find_blobs(threshold, area_threshold=300)
if blob: #如果找到了目标颜色
# print(blob)
# uart.write("B3 B3 ") #一帧数据的帧头
FH = bytearray([0xb3,0xb3])
uart.write(FH)
for b in blob:
#迭代找到的目标颜色区域
img.draw_rectangle(b[0:4]) # rect
img.draw_cross(b[5], b[6]) # cx, cy
x = b.cx()
y = b.cy()
#area = b.area()
if x >= 256:
x -= 70
if x < 256:
print(x, y,'n')
data = bytearray([x,y])
uart.write(data)
上一篇:STM32F030C8配置使用NRF24L01
下一篇:简化和加快最终产品开发速度,STM32 探索套件问市
推荐阅读最新更新时间:2024-10-29 08:25
