MSP430F249----UART
发布者:数字之舞最新更新时间:2021-01-14 来源: eefocus关键字:MSP430F249  UART  USCI 手机看文章 扫描二维码
随时随地手机看文章
//   MSP430x24x Demo - USCI_A0, 9600 UART Echo ISR, DCO SMCLK
//   Description: Echo a received character, RX ISR used. Normal mode is LPM0.
//   USCI_A0 RX interrupt triggers TX Echo.
//   Baud rate divider with 1MHz = 1MHz/9600 = ~104.2
//   ACLK = n/a, MCLK = SMCLK = CALxxx_1MHZ = 1MHz
//                MSP430F249
//         /||              XIN|-
//          --|RST          XOUT|-
//            |     P3.4/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P3.5/UCA0RXD|<------------
//  B. Nisarga
//  Texas Instruments Inc.
//  September 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.42A
#include
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  if (CALBC1_1MHZ==0xFF)  // If calibration constant erased
    while(1);                               // do not load, trap CPU!!
  DCOCTL = 0;                               // Select lowest DCOx and MODx settings
  BCSCTL1 = CALBC1_1MHZ;                    // Set DCO
  DCOCTL = CALDCO_1MHZ;
  P3SEL = 0x30;                             // P3.4,5 = USCI_A0 TXD/RXD
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 104;                            // 1MHz 9600; (104)decimal = 0x068h
  UCA0BR1 = 0;                              // 1MHz 9600
  UCA0MCTL = UCBRS0;                        // Modulation UCBRSx = 1
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  //__bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
  __bis_SR_register(GIE);
  while(1)
      int i;
      for(i=10000;i>0;i--);
          while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
        UCA0TXBUF = 'A';                    // TX -> RXed character
        UCA0TXBUF = 'B';                    // TX -> RXed character
//  Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character
关键字:MSP430F249  UART  USCI 引用地址:MSP430F249----UART
上一篇:MSP430F249SPI+TLC549
下一篇:MSP430F249 IIC write and Uart send
推荐阅读最新更新时间:2024-11-11 06:55
实验八--uart
一。环境   系统:ubuntu12.04   开发板:jz2440   编译器:gcc 二。说明 有空补上 三。代码 head.S 1 @****************************************************************************** 2 @ File:head.S 3 @ 功能:设置SDRAM,将程序复制到SDRAM,然后跳到SDRAM继续执行 4 @****************************************************************************** 5
[单片机]
s3c2440学习之路-008 uart实现printf函数
1.基本原理 因为程序目前处于裸板阶段,只能输出字符串,没有C语言的printf函数可以调用。但是在调试程序时,想像C语言一样调用printf来调试,因此只能自己来实现了。 C语言中,printf函数的原型为: int printf(const char *format, ...); 1.1 可变参数 … 参数有2个, “const char *format” 和 “…”,这个“…”就是可变参数,下面先讲解一下如何识别这个可变参数。 参数的传递会顺序的放到栈里面,而printf函数可获取的参数只有 “const char *format” 和 “…”,不过format刚好指向了第1个参数的首地址,因此可以通过form
[单片机]
s3c2440学习之路-008 <font color='red'>uart</font>实现printf函数
MSP430F249ADC
/****************************************************************** ** ** File : ADC.c | Analog to Digital converter | ** Version : 1.0 ** Description : led 7 segment display Analog to Digital converter ** Author : LightWu
[单片机]
学51单片机-UART口发送一个字符
UART口,又叫做通用异步收发传输器(Universal Asynchronous Receiver/Transmitter),是单片机常用功能的一部分,也是早期台式电脑必备的一个硬件接口。 当年我调试UART口的时候,用的还是超级终端,现在都用串口助手了,比我们当时方便多了。 UART口按位发送和接收字节,虽然相比于并口,慢了很多,但是在有限的IO资源面前,这种方式是非常可取的。 UART口主要用于ASCII码的传输,传输过程遵循ANSI/EIA-232标准。ASCII码是啥?看下表: 就是说,当我想发送字符“A”的时候,我要向串口发送十进制数65,或者十六进制数41。 驱动电
[单片机]
学51单片机-<font color='red'>UART</font>口发送一个字符
单片机IO口模拟UART串口通信
为了让大家充分理解 UART 串口通信的原理,我们先把 P3.0 和 P3.1 当做 IO 口来进行模拟实际串口通信的过程,原理搞懂后,我们再使用寄存器配置实现串口通信过程。 对于 UART 串口波特率,常用的值是 300、600、1200、2400、4800、9600、14400、19200、28800、38400、57600、115200 等速率。IO 口模拟 UART 串行通信程序是一个简单的演示程序,我们使用串口调试助手下发一个数据,数据加 1 后,再自动返回。 串口调试助手,这里我们直接使用 STC-ISP 软件自带的串口调试助手,先把串口调试助手的使用给大家说一下,如图 11-6 所示。第一步要选择串口助手菜单,第二步
[单片机]
单片机IO口模拟<font color='red'>UART</font>串口通信
stm8 uart2 串口接收中断协议解码+定时器中断
协议解码的时候,如果上位机发送数据不完整或者有错误,通过定时器中断将之接收的不完整数据清楚。定时的时间长短可有定时器觉得,ms为单位。 //初始化位毫秒单位 void Timer_Init() { TIM1_PSCRH = (unsigned char) ( ( (F_CPU / 1000) - 1) 8); /* 16M系统时钟经预分频f=fck/(PSCR+1) */ TIM1_PSCRL = (unsigned char) ( (F_CPU / 1000) - 1); /* PSCR=0x3E7F,f=16M/(0x3E7F+1)=1000Hz,每个计数周期1ms */ TIM1_ARRH = 0;
[单片机]
STM32--UART异步通信学习
字符发送的过程描述:在UART的发送过程中先将数据输入到发送数据寄存器中(TDR)此时(TXE)被硬件置1,之后TDR寄存器将数据串行移入到发送移位寄存器中,将数据在TX端口发送,此时(TC)被硬件置1。 发送与接收是逆过程。 UART发送配置步骤: 1.通过USART_CR1寄存器上置位UE来激活USART。 2.编程USART_CR1的M位来定义字长。 3.在USART_CR2中编程停止位的位数。 4.如果采用多缓冲器通信,配置USART_CR3中的DMA使能位(DMAT)。按多缓冲器通信中的描述配置DMA寄存器。 5.利用USART_BRR寄存器选择要求的波特率。 6. 设
[单片机]
【STM32】HAL库 STM32CubeMX教程四---UART串口通信详解
前言: 今天我们学习STM32CubeMX串口的操作,以及HAL库串口的配置,我们会详细的讲解各个模块的使用和具体功能,并且基于HAL库实现Printf函数功能重定向,UART中断接收,本系列教程将HAL库与STM32CubeMX结合在一起讲解,使您可以更快速的学会各个模块的使用 所用工具: 1、芯片: STM32F407ZET6 2、STM32CubeMx软件 3、IDE: MDK-Keil软件 4、STM32F1xx/STM32F4xxHAL库 5、串口: 使用USART1 PA9,PA10 知识概括: 通过本篇博客您将学到: STM32CubeMX创建串口例程 HAL库UATR函数库
[单片机]
【STM32】HAL库 STM32CubeMX教程四---<font color='red'>UART</font>串口通信详解
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
