tiny6410 Linux启动信息
发布者:跳跃龙珠最新更新时间:2021-08-27 来源: eefocus关键字:tiny6410  Linux 手机看文章 扫描二维码
随时随地手机看文章
NAND read: device 0 offset 0x400000, size 0x500000            //0x500000是2G?
.....Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 2.6.38-FriendlyARM (root@jensen) (gcc version 4.5.1 (ctng-1.8.1-FA) ) #13 PREEMPT Mon Jul 18 17:07:42 HKT 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: MINI6410
Memory policy: ECC disabled, Data cache writeback
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
camera: no parent clock specified
S3C64XX: PLL settings, A=532000000, M=532000000, E=24000000             //PLL设置
S3C64XX: HCLK2=266000000, HCLK=133000000, PCLK=66500000
mout_apll: source is fout_apll (1), rate is 532000000
mout_epll: source is epll (1), rate is 24000000
mout_mpll: source is mpll (1), rate is 532000000
mmc_bus: source is mout_epll (0), rate is 24000000
usb-bus-host: source is clk_48m (0), rate is 48000000
uclk1: source is dout_mpll (1), rate is 66500000
spi-bus: source is mout_epll (0), rate is 24000000
audio-bus: source is mout_epll (0), rate is 24000000
irda-bus: source is mout_epll (0), rate is 24000000
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f8000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x5edf8000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5e5f8000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x5dff8000
s3c64xx: 4194304 bytes SDRAM reserved for jpeg at 0x5dbf8000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs  init=/linuxrc console=ttySAC0,115200
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total          //256M内存
Memory: 215160k/215160k available, 46984k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xff600000 - 0xffe00000   (   8 MB)
    vmalloc : 0xd0800000 - 0xf6000000   ( 600 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0168000   (1408 kB)
      .text : 0xc0168000 - 0xc0719d3c   (5832 kB)
      .data : 0xc071a000 - 0xc075f380   ( 277 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptable hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
VIC @f6000000: id 0x00041192, vendor 0x41
VIC @f6010000: id 0x00041192, vendor 0x41
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
s3c64xx_dma_init: Registering DMA channels
PL080: IRQ 73, at d0808000, channels 0..8
PL080: IRQ 74, at d080c000, channels 8..16
S3C6410: Initialising architecture
bio: create slab at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 64 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.23.
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 420
io scheduler noop registered (default)
io scheduler cfq registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: N43 will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
            FB1: map_video_memory: dma=5d780000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
            FB2: map_video_memory: dma=5d7bfc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
Window[1] - FB1: map_video_memory: clear ff680000:0007f800
            FB1: map_video_memory: dma=5cc00000 cpu=ff680000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff6bfc00:0003fc00
            FB2: map_video_memory: dma=5cc3fc00 cpu=ff6bfc00 size=0003fc00
fb1: s3cfb frame buffer device
Window[2] - FB1: map_video_memory: clear ff700000:0003fc00
            FB1: map_video_memory: dma=5d740000 cpu=ff700000 size=0003fc00
fb2: s3cfb frame buffer device
Window[3] - FB1: map_video_memory: clear ff740000:0003fc00
            FB1: map_video_memory: dma=5cc80000 cpu=ff740000 size=0003fc00
fb3: s3cfb frame buffer device
backlight       initialized
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10                //四个串口
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
leds    initialized
buttons initialized
pwm     initialized
adc     initialized
loop: module loaded
S3C NAND Driver, (c) 2008 Samsung Electronics
MLC nand initialized, 2011 ported by FriendlyARM
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 3 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000400000 : "Bootloader"                                //Boot,内核和文件系统存储地址区间
0x000000400000-0x000000c00000 : "Kernel"
0x000000c00000-0x000080000000 : "File System"
UBI: attaching mtd2 to ubi0
UBI: physical eraseblock size:   1048576 bytes (1024 KiB)
UBI: logical eraseblock size:    1032192 bytes
UBI: smallest flash I/O unit:    8192
UBI: VID header offset:          8192 (aligned 8192)
UBI: data offset:                16384
UBI: max. sequence number:       9
UBI: attached mtd2 to ubi0
UBI: MTD device name:            "File System"
UBI: MTD device size:            2036 MiB
UBI: number of good PEBs:        2030
UBI: number of bad PEBs:         6
UBI: number of corrupted PEBs:   0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 2030
UBI: number of PEBs reserved for bad PEB handling: 20
UBI: max/mean erase counter: 2/0
UBI: image sequence number:  1618989453
UBI: background thread "ubi_bgt0d" started, PID 634
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d0930000,d0e00004 IRQ 108 MAC: 08:90:90:90:90:90 (chip)
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 79, io mem 0x74300000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.38-FriendlyARM ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for aircable
usbcore: registered new interface driver aircable
USB Serial support registered for ark3116
usbcore: registered new interface driver ark3116
ark3116:v0.6:USB ARK3116 serial/IrDA driver
USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
usbcore: registered new interface driver belkin
belkin_sa: v1.3:USB Belkin Serial converter driver
[1] [2] [3]
关键字:tiny6410  Linux 引用地址:tiny6410 Linux启动信息
上一篇:NXPLPC ARM 必须知道的知识
下一篇:tiny6410开发板的Linux系统修改IP地址
推荐阅读最新更新时间:2024-11-12 21:10
TQ2440 学习笔记—— 10、嵌入式编程基础知识【arm-linux-ld 选项】
arm-linux-ld 用于将多个目标文件、库文件链接成可执行文件。 介绍 “ -T ” 选项,可以直接使用它来指定代码段、数据段、bss 段的起始地址,也可以用来指定一个链接脚本,在链接脚本中进行更复杂的地址设置。 “ -T ” 选项只用于链接Bootloader、内核等“没有底层软件支持”的软件;链接运行于操作系统之上的应用程序时,无需指定“ -T ” 选项,它们使用默认的方式进行链接。 1、直接指定代码段、数据段、bss段的起始地址 格式如下: -Ttext startaddr -Tdata startaddr -Tbss startaddr 其中的“ startaddr ” 分别表示代码段
[单片机]
TQ2440 学习笔记—— 10、嵌入式编程基础知识【arm-<font color='red'>linux</font>-ld 选项】
linux-2.6.32在mini2440开发板上移植 添加触摸屏驱动程序
在内核中添加触摸屏驱动程序 编者:linux2.6.32并没有带S3C2440触摸屏驱动程序,需要自己实现。而在此的触摸屏驱动程序时作为一个输入设备来实现的。在linux中,对于输入设备而言,内核专为其设计了输入子系统,由核心层处理公共的工作。因为对于输入设备而言,只是中断、读键值/坐标值是与设备相关的,其余的如输入事件的缓冲区的管理以及字符设备驱动的file_operations接口则是输入设备通用的。所以在此是在输入子系统的框架下进行编写触摸屏驱动程序。对于这个驱动的移植以及讲解,参考了网上的一些文章,一部分摒弃了手册。 1 在内核中添加触摸屏驱动程序 Linux-2.6.32.2 内核也没有包含支持S3C2440 的触摸屏
[单片机]
ARMLinux驱动移植RTC(实时时钟)移植
硬件平台:FL2440 内核版本:2.6.28 主机平台:Ubuntu 11.04 内核版本:2.6.39 原创作品,转载请标明出处http://blog.csdn.net/yming0221/article/details/6584285 首先修改内核源码/arch/arm/mach-s3c2410/mach-smdk2410.c 添加红色字体部分 static struct platform_device *smdk2410_devices __initdata = { &s3c_device_usb, &s3c_device_lcd, &s3c_device_wdt, &s3c_device_i2c,
[单片机]
在ubuntu8.10 下建立 ARM-Linux 交叉编译环境
很久都没有写文章了 ,经过了将近半年的奔波,终于可以写点东西了!在广州工作时 ,同事极力推荐我用ubuntu,使用之后的确很爽,并决定以后在ubuntu下工作,完全可以抛弃windows(晕到死)。决定开始 移植Linux到mini2440。首先就是在ubuntu下建立交叉编译工具链。借着在Fedora 下建立ARM-Linux的交叉编译工具的经验,按理说应该是不会有问题的,但是结果是比在Fedora下碰到的问题多得多了。以下先介绍成功编译的过 程,碰到的问题和解决办法后面说。 这次编译过程中对我有重大帮助的资料有: 《 编译Mysql时configure: error: No curses/termcap library fou
[单片机]
NI推出基于Linux的嵌入式设计模块SOM
  NI新推出了一个嵌入式系统开发板,基于Linux平台下的实时操作系统(RTOS),该系统模块SOM基于Xilinx内置双核ARM处理器的Xilinx Zynq全可编程SoC系列。   软件集成度是这类小型硬件开发模块必须关注的,因为它采用LabVIEW软件可重构的I/O(RIO)架构的软件设计标准。   嵌入式系统市场总监Jamie Smith表示,“今天的嵌入式监控和控制应用程序比以往任何时候都更为复杂,严格的上市期限、不断上升的成本为系统给设计者增加了难度。研究表明,与传统设计方法相比,利用LabVIEW RIO架构用仅仅一半的时间来解决复杂的嵌入式设计难题。”   SOM系统开发主板还附带一整套嵌入式操作
[测试测量]
ARM-Linux驱动相关头文件知识点
#include linux/***.h 在linux-2.6.31/include/linux下面寻找源文件 #include asm/***.h 在linux-2.6.31/arch/arm/include/asm下面寻找源文件 #include mach/***.h 在linux-2.6.31/arch/arm/mach-s3c2410/include/mach下面寻找源文件 #include plat/regs-adc.h 在linux-2.6.31/arch/arm/plat-s3c/include/plat下面寻找源文件 ---------------------------------------------
[单片机]
LINUX 内核移植
1. 下载内核源码linux-2.6.34,解压到工作目录下。 2. 首先在内核中增加一个 SOC ,到 /arch/arm/mach-s3c64xx 下将mach-smdk6410.c 复制成 mach-ok6410.c 修改mach-ok6410.c 将里面的 smdk6410 替换为 ok6410 ,将SMDK6410 替换为 OK6410   :1,$s/smdk6410/ok6410/g 修改该目录下的 Makefile obj-$(CONFIG_MACH_OK6410) += mach-ok6410.o 修改该目录下的 Kconfig 增加 config MACH_OK6410 bool OK6410
[单片机]
<font color='red'>LINUX</font> 内核移植
又一Linux手机发货 这配置只能用寒酸形容
据phonearena和donanimhaber报道,早在去年Pine64公司的基于Linux的智能手机PinePhone向开发者发货,报道称目前这款售价也正式向用户推出,价格为149.99美元(约合人民币1028元)。 据了解,PinePhone智能手机搭载了中国全志公司的Allwinner A64四核处理器,拥有2GB内存,16GB存储空间,采用5.95英寸1440 x 720的LCD显示屏,屏幕比例为18:9。摄像方面,搭载500万像素后置摄像头和200万像素前置摄像头。   这款手机具有许多目前少见的功能,采用可拆卸电池设计和3.5mm耳机插孔;手机中还具有用于禁用Wi-Fi、蓝牙的开关。此外,Pinep
[手机便携]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
