s3c2440时钟+nandflash拷贝至SDRAM+开启mmu
发布者:Xinmei最新更新时间:2021-09-24 来源: eefocus关键字:s3c2440  时钟  nandflash  SDRAM 手机看文章 扫描二维码
随时随地手机看文章
涉及6个文件
head.S,init.c,main.c,makefile,nand.c,out.lds
head.S
.text
.global _start
_start:
    b   Reset
HandleUndef:
    b   HandleUndef
HandleSWI:
    b   HandleSWI
HandlePrefetchAbort:
    b   HandlePrefetchAbort
HandleDataAbort:
    b   HandleDataAbort
HandleNotUsed:
    b   HandleNotUsed
    b   HandleIRQ
HandleFIQ:
    b   HandleFIQ
Reset:
ldr r0, =0x53000000
mov r1, #0x0
str r1, [r0] @disable watchdog
msr cpsr_c, #0xd2 @IRQ mode,ARM mode,IRQ disable
ldr sp, =3072
msr cpsr_c, #0xd3 @Supervisor mode,ARM mode,IRQ disable
ldr sp, =1024*4 @set up stack,4K
msr cpsr_c, #0x53 @Supervisor mode,ARM mode,IRQ enable
ldr sp, =4096
bl clock_init
bl memsetup
bl nand_init
       ldr r0, =0x30000000 @target address(sdram),nand_read 1parameter
       mov r1, #4096 @start address,nand_read 2parameter
       mov r2, #2048*2 @size copy to sdram,nand_read 3parameter
bl nand_read
bl  create_page_table
bl  mmu_init
ldr sp, =0xB4000000 @pstack go to sdram
ldr lr, =halt_loop
ldr pc, =main
halt_loop:
b halt_loop
HandleIRQ:
sub lr, lr, #4
stmdb sp!, {r0-r12,lr}
ldr lr, =int_return
ldr pc, =TIMER_Handle
int_return:
ldmia sp!, { r0-r12,pc }^
init.c
#define BWSCON (*(volatile unsigned long *)0x48000000)
#define BANKCON0 (*(volatile unsigned long *)0x48000004)
#define BANKCON1 (*(volatile unsigned long *)0x48000008)
#define BANKCON2 (*(volatile unsigned long *)0x4800000C)
#define BANKCON3 (*(volatile unsigned long *)0x48000010)
#define BANKCON4 (*(volatile unsigned long *)0x48000014)
#define BANKCON5    (*(volatile unsigned long *)0x48000018)
#define BANKCON6    (*(volatile unsigned long *)0x4800001C)
#define BANKCON7    (*(volatile unsigned long *)0x48000020)
#define REFRESH       (*(volatile unsigned long *)0x48000024)
#define BANKSIZE     (*(volatile unsigned long *)0x48000028)
#define MRSRB6 (*(volatile unsigned long *)0x4800002C)
#define MRSRB7 (*(volatile unsigned long *)0x48000030)
#define CLKDIVN (*(volatile unsigned long *)0x4C000014)
#define MPLLCON (*(volatile unsigned long *)0x4C000004)
#define S3C2440_MPLL_400MHZ 0x5C011
void memsetup()
BWSCON=0x22011110;
BANKCON0=0x00000700;//sram
BANKCON1=0x00000700;//rom
BANKCON2=0x00000700;
BANKCON3=0x00000700;
BANKCON4=0x00000700;
BANKCON5=0x00000700;
BANKCON6=0x00018005;//sdram
BANKCON7=0x00018005;
REFRESH=0x008C04F4;
BANKSIZE=0x000000B1;
MRSRB6=0x00000030;
MRSRB7=0x00000030;
void clock_init()
CLKDIVN=0x05;
__asm__(
    "mrc    p15, 0, r1, c1, c0, 0n"
    "orr    r1, r1, #0xc0000000n"
    "mcr    p15, 0, r1, c1, c0, 0n"
      MPLLCON=S3C2440_MPLL_400MHZ;
void create_page_table(void)
#define MMU_FULL_ACCESS     (3 << 10)
#define MMU_DOMAIN          (0 << 5)
#define MMU_SPECIAL         (1 << 4)
#define MMU_CACHEABLE       (1 << 3)
#define MMU_BUFFERABLE      (1 << 2)
#define MMU_SECTION         (2)
#define MMU_SECDESC         (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL | MMU_SECTION)
#define MMU_SECDESC_WB      (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL |
                             MMU_CACHEABLE | MMU_BUFFERABLE | MMU_SECTION)
#define MMU_SECTION_SIZE    0x00100000
    unsigned long virtuladdr, physicaladdr;
    unsigned long *mmu_tlb_base = (unsigned long *)0x30000000;
    virtuladdr = 0;
    physicaladdr = 0;
    *(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC_WB;//0~4096 the same
    virtuladdr = 0x56000000;
    physicaladdr = 0x56000000;
    *(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC;
    virtuladdr = 0x4A000000;
    physicaladdr = 0x4A000000;
    virtuladdr = 0x51000000;
    physicaladdr = 0x51000000;
    /*SDRAM to 0xB0000000~0xB4000000*/
    virtuladdr = 0xB0000000;
    physicaladdr = 0x30000000;
    while (virtuladdr < 0xB4000000)
        virtuladdr += 0x100000;
        physicaladdr += 0x100000;
 * 启动MMU
void mmu_init(void)
    unsigned long ttb = 0x30000000;
__asm__(
    "mov    r0, #0n"
    "mcr    p15, 0, r0, c7, c7, 0n"
    "mcr    p15, 0, r0, c7, c10, 4n"
    "mcr    p15, 0, r0, c8, c7, 0n"
    "mov    r4, %0n"
    "mcr    p15, 0, r4, c2, c0, 0n"
    "mvn    r0, #0n"
    "mcr    p15, 0, r0, c3, c0, 0n"
    "mrc    p15, 0, r0, c1, c0, 0n"
    "bic    r0, r0, #0x3000n"
    "bic    r0, r0, #0x0300n"
    "bic    r0, r0, #0x0087n"
    "orr    r0, r0, #0x0002n"
    "orr    r0, r0, #0x0004n"
    "orr    r0, r0, #0x1000n"
    "orr    r0, r0, #0x0001n"
    "mcr    p15, 0, r0, c1, c0, 0n"
    : "r" (ttb) );
main.c
led1 f4,led2 f5,led3 f6,int0 f0
#define GPFCON (*(volatile unsigned long *)0x56000050)
#define GPFDAT (*(volatile unsigned long *)0x56000054)
#define GPF4_OUT (1<<(4*2))
#define GPF5_OUT (1<<(5*2))
#define GPF6_OUT (1<<(6*2))
#define GPF4_CON_MSK (3<<(4*2))
#define GPF5_CON_MSK (3<<(5*2))
#define GPF6_CON_MSK (3<<(6*2))
#define GPF4_DAT_MSK (1<<(4))
#define GPF5_DAT_MSK (1<<(5))
#define GPF6_DAT_MSK (1<<(6))
#define TIMER0_MSK (1<<(10))
#define TCFG0 (*(volatile unsigned long *)0x51000000)
#define TCON (*(volatile unsigned long *)0x51000008)
#define TCNTB0 (*(volatile unsigned long *)0x5100000C)
#define INTOFFSET (*(volatile unsigned long *)0x4A000014)
#define SRCPND (*(volatile unsigned long *)0X4A000000)
#define INTMSK (*(volatile unsigned long *)0X4A000008)
#define PRIORITY (*(volatile unsigned long *)0x4A00000C)
#define INTPND (*(volatile unsigned long *)0X4A000010)
void init_timer0()
SRCPND=0x0;
INTMSK=~TIMER0_MSK;
TCFG0=0xff;
TCNTB0=0xffff;
TCON=0xa;
TCON=0x9;
void led_set_out()
GPFCON&=~(GPF4_CON_MSK|GPF5_CON_MSK|GPF6_CON_MSK);
    GPFCON|=GPF4_OUT|GPF5_OUT|GPF6_OUT;
GPFDAT&=~(GPF4_DAT_MSK);
GPFDAT&=~(GPF5_DAT_MSK);
GPFDAT&=~(GPF6_DAT_MSK);
GPFDAT|=(1<<4);
GPFDAT|=(1<<5);
GPFDAT|=(1<<6);
void led_reset(int ledn)
if(ledn==1)
GPFDAT|=(1<<4);
else if(ledn==2)
GPFDAT|=(1<<5);
else
GPFDAT|=(1<<6);
void led_set(int ledn)
if(ledn==1)
else if(ledn==2)
else
void TIMER_Handle()
int i;
led_set(1);
for(i=0;i<1000000;i++);
led_reset(1);
SRCPND=1< INTPND=1<}
int main()
int i;
led_set_out();
init_timer0();
while(1)
led_reset(2);
for(i=0;i<10000000;i++);
led_set(2);
return 0;
makefile
out.bin : head.S  main.c nand.c init.c
arm-linux-gcc -c -o head.o head.S
arm-linux-gcc -c -o main.o main.c
arm-linux-gcc -c -o nand.o nand.c
arm-linux-gcc -c -o init.o init.c
arm-linux-ld -Tout.lds head.o main.o nand.o init.o -o out_elf
arm-linux-objcopy -O binary -S out_elf out.bin
arm-linux-objdump -D -m arm  out_elf > out.dis
#rm -f out.dis out_elf *.o
clean:
rm -f out.dis out.bin out_elf *.o
nand.c
#define LARGER_NAND_PAGE
#define GSTATUS1        (*(volatile unsigned int *)0x560000B0)
#define BUSY            1
#define NAND_SECTOR_SIZE    512
#define NAND_BLOCK_MASK     (NAND_SECTOR_SIZE - 1)
#define NAND_SECTOR_SIZE_LP    2048
#define NAND_BLOCK_MASK_LP     (NAND_SECTOR_SIZE_LP - 1)
typedef unsigned int S3C24X0_REG32;
/* NAND FLASH (see S3C2410 manual chapter 6) */
typedef struct {
    S3C24X0_REG32   NFCONF;
    S3C24X0_REG32   NFCMD;
    S3C24X0_REG32   NFADDR;
    S3C24X0_REG32   NFDATA;
    S3C24X0_REG32   NFSTAT;
    S3C24X0_REG32   NFECC;
} S3C2410_NAND;
/* NAND FLASH (see S3C2440 manual chapter 6, www.100ask.net) */
typedef struct {
[1] [2] [3]
关键字:s3c2440  时钟  nandflash  SDRAM 引用地址:s3c2440时钟+nandflash拷贝至SDRAM+开启mmu
上一篇:s3c6410 系统时钟
下一篇:ARM的step内存到SDRAM内存代码复制程序调试之罪魁祸首 ADR与LDR
推荐阅读最新更新时间:2024-10-20 14:27
涉及6个文件 head.S,init.c,main.c,makefile,nand.c,out.lds head.S .text .global _start _start: b Reset HandleUndef: b HandleUndef HandleSWI: b HandleSWI HandlePrefetchAbort: b HandlePrefetchAbort HandleDataAbort: b HandleDataAbort HandleNotUsed: b HandleNotUsed b HandleIRQ HandleFIQ: b HandleFIQ R
[单片机]
S3C2440SDRAM NorFlash NandFlash连线分析
一、SDRAM(HY57V561620F)连线分析 1、 S3C2440 有27根地址线ADDR ,8根片选信号ngcs0-ngcs7,对应bank0-bank7,当访问bankx 的地址空间,ngcsx引脚为低电平,选中外设。 2^27=128MByte, 8*128Mbyte = 1Gbyte,所以S3C2440 总的寻址空间是1Gbyte。但市面上很少有32位宽度的单片SDRAM,一般选择2片16位SDRAM 扩展得到32位SDRAM. 2、这里选择的SDARM是HY57V561620F,4Mbit * 4bank *16I/O,共32Mbyte。 首先了解下SDRAM 的寻址原理。 SDRAM 内部是一个存储阵列,
[单片机]
<font color='red'>S3C2440</font>与<font color='red'>SDRAM</font> NorFlash <font color='red'>NandFlash</font>连线分析
06-S3C2440学习之移植2012u-boot到S3C2440(移植过程一)新建单板+修改时钟+SDRAM+UART
移植u-boot-2012.04之建新单板_时钟_SDRAM_UART (1)新建单板目录,以及配置头文件 tar xjf u-boot-2012.04.01.tar.bz2 cd u-boot-2012.04.01 cd board/samsung/ cp smdk2410 smdk2440 –rf cd ../.. cd /include/configs/ cp smdk2410.h smdk2440.h (2) 修改 boards.cfg: 仿照 smdk2410 arm arm920t - samsung s3c24x0 添加: smdk244
[单片机]
06-S3C2440学习之移植2012u-boot到<font color='red'>S3C2440</font>(移植过程一)新建单板+修改<font color='red'>时钟</font>+<font color='red'>SDRAM</font>+UART
S3C2440移植uboot之新建单板_时钟_SDRAM_串口
文章目录 1.新建单板 1.1 将2410的单板文件夹拷贝成2440: 1.2 将2410的头文件拷贝成2440 2.修改boards.cfg,使uboot支持2440单板: 3.修改uboot系统时钟 4.烧写修改后的uboot 5.烧写uboot,发现串口已有数据,但是乱码 5.1进入archarmcpuarm920ts3c24x0Speed.c下的get_HCLK ()函数: 5.2编译测试 5.3所以就直接去掉该文件,不让编译器编译即可,步骤如下所示: 加粗样式 1.新建单板 1.1 将2410的单板文件夹拷贝成2440: cd /work/system/u-boot-2012.04.01/board/sam
[单片机]
<font color='red'>S3C2440</font>移植uboot之新建单板_<font color='red'>时钟</font>_<font color='red'>SDRAM</font>_串口
Mini2440 SDRAM、NAND、MMU
1. SDRAM 当加电默认从NAND启动时,先将4K代码复制到Steppingstone内RAM执行,在执行Steppingstone代码时,会将剩余的代码复制到SDRAM执行,但是使用SDRAM必须先对其有关SDRAM的寄存器进行初始化,以便能使用SDRAM 主要包括寄存器: BWSCON、BANKCON0~7、REFRESH、BANKSIZE、MRSRB6~7 这些寄存器要根据相应的单板进行设置,如下为Mini2440默认设置 0x22011110, //BWSCON span style= font-family:Comic Sans MS;font-size:12px; /span 0x0000070
[单片机]
Mini2440 <font color='red'>SDRAM</font>、NAND、<font color='red'>MMU</font>
零死角玩转2440下NandFlash拷贝并跳转到SDRAM的(启动过程)
先上张图: 第一步:当S3C2440被配置成从Nand Flash启动时, S3C2440的Nand Flash控制器会在 S3C2440上电时自动把NandFlash上的前4K代码搬移到Boot Internal SRAM,然后系统从起始地址是0x0000_0000的Boot Internal SRAM启动,在这4K代码中我们必须完成CPU的核心配置,把NandFlash上的代码全部拷贝到SDRAM中去,然后跳转到SDRAM中去执行剩余的代码(进入操作系统等等); 第1步: 这一步主要完成的是把NandFlash上的代码拷贝到SDRAM的过程: (1)先判断是从nor启动还是从nand启动 ldr
[单片机]
零死角玩转2440下<font color='red'>NandFlash</font>拷贝并跳转到<font color='red'>SDRAM</font>的(启动过程)
ARM9_S3C2440学习(五)norflash启动,nandflash启动,SDRAM总结
S3C2440的启动时读取的第一条指令是在0x00上,分为成nand flash和nor flash上启动。 nand flash:适合大容量数据存储,类似硬盘; nor flash:适合小容量的程序或数据存储,类似小硬盘; sdram:主要用于程序执行时的程序存储、执行或计算,类似内存。 Nor flash的有自己的地址线和数据线,可以采用类似于memory的随机访问方式,在nor flash上可以直接运行程序,所以nor flash可以直接用来做boot,采用nor flash启动的时候会把地址映射到0x00上。 Nand flash是IO设备,数据、地址、控制线都是共用的,需要软件区控制读取时序,所以不能像nor
[单片机]
原来程序是这样从NandFlash拷贝并跳转到SDRAM
重新看了一下FL2440的BootLoader,终于把程序是怎样从Nandflash拷贝并跳转到SDRAM的过程弄清楚了,在这边做一下笔记。先上张图: 1.当S3C2440被配置成从Nand Flash启动时, S3C2440的Nand Flash控制器会在 S3C2440上电时自动把NandFlash上的前4K代码搬移到Boot Internal SRAM,然后系统从起始地址是0x0000_0000的Boot Internal SRAM启动,在这4K代码中我们必须完成CPU的核心配置,把NandFlash上的代码全部拷贝到SDRAM中去,然后跳转到SDRAM中去执行剩余的代码(进入操作系统等等); 2.这一步完成的是把N
[单片机]
原来程序是这样从<font color='red'>NandFlash</font>拷贝并跳转到<font color='red'>SDRAM</font>的
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
