STM32 LED跑马灯-库函数
发布者:caijt最新更新时间:2021-12-03 来源: eefocus关键字:LED  跑马灯  库函数 手机看文章 扫描二维码
随时随地手机看文章
一,GPIO知识回顾
1,四种输入模式:
    输入浮空
    输入上拉
    输入下拉
    模拟输入
2,四种输出模式:
    开漏输出
    开漏复用输出
    推挽输出
    推挽复用输出
3,三种最大输出速度
    2MHz
    10MHz
    50MHz
每组GPIO共16个IO口,含下7个寄存器
GPIOx_CRL  : 端口配置低寄存器
GPIOx_CRH  : 端口配置高寄存器
GPIOx_IDR  : 端口输入寄存器
GPIOx_ODR  : 端口输出寄存器
GPIOx_BSRR : 端口位设置/清除寄存器
GPIOx_BRR  : 端口位清除寄存器
GPIOx_LCKR : 端口配置锁存寄存器
二,LED硬件连接:
这里写图片描述
LED0连接PB5引脚
LED1连接PE5引脚
三,LED跑马灯实现流程
1,使能GPIO时钟
     使用IO口前先要使能相应的GPIO时钟
2,初始化IO口 GPIO_Init()
     配置IO口的引脚工作方式(最大速度,输入/输出模式)
3,操作IO口输出高低电平
     控制响应IO口输出高电平或低电平
四,源码分析
1,GPIO初始化函数
stm32f10x_gpio.h头文件中找到GPIO_Init函数声明
void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct);
stm32f10x_gpio.c中找到GPIO_Init函数的实现
  * @brief  Initializes the GPIOx peripheral according to the specified
  *         parameters in the GPIO_InitStruct.
  * @param  GPIOx: where x can be (A..G) to select the GPIO peripheral.
  * @param  GPIO_InitStruct: pointer to a GPIO_InitTypeDef structure that
  *         contains the configuration information for the specified GPIO peripheral.
  * @retval None
  uint32_t currentmode = 0x00, currentpin = 0x00, pinpos = 0x00, pos = 0x00;
  uint32_t tmpreg = 0x00, pinmask = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GPIO_MODE(GPIO_InitStruct->GPIO_Mode));
  assert_param(IS_GPIO_PIN(GPIO_InitStruct->GPIO_Pin));
/*---------------------------- GPIO Mode Configuration -----------------------*/
  currentmode = ((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x0F);
  if ((((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x10)) != 0x00)
    assert_param(IS_GPIO_SPEED(GPIO_InitStruct->GPIO_Speed));
    /* Output mode */
    currentmode |= (uint32_t)GPIO_InitStruct->GPIO_Speed;
/*---------------------------- GPIO CRL Configuration ------------------------*/
  /* Configure the eight low port pins */
  if (((uint32_t)GPIO_InitStruct->GPIO_Pin & ((uint32_t)0x00FF)) != 0x00)
    tmpreg = GPIOx->CRL;
    for (pinpos = 0x00; pinpos < 0x08; pinpos++)
      pos = ((uint32_t)0x01) << pinpos;
      /* Get the port pins position */
      currentpin = (GPIO_InitStruct->GPIO_Pin) & pos;
      if (currentpin == pos)
        pos = pinpos << 2;
        /* Clear the corresponding low control register bits */
        pinmask = ((uint32_t)0x0F) << pos;
        tmpreg &= ~pinmask;
        /* Write the mode configuration in the corresponding bits */
        tmpreg |= (currentmode << pos);
        /* Reset the corresponding ODR bit */
        if (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_IPD)
          GPIOx->BRR = (((uint32_t)0x01) << pinpos);
        else
          /* Set the corresponding ODR bit */
          if (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_IPU)
            GPIOx->BSRR = (((uint32_t)0x01) << pinpos);
    GPIOx->CRL = tmpreg;
/*---------------------------- GPIO CRH Configuration ------------------------*/
  /* Configure the eight high port pins */
  if (GPIO_InitStruct->GPIO_Pin > 0x00FF)
    tmpreg = GPIOx->CRH;
      pos = (((uint32_t)0x01) << (pinpos + 0x08));
      currentpin = ((GPIO_InitStruct->GPIO_Pin) & pos);
        pos = pinpos << 2;
        /* Clear the corresponding high control register bits */
        tmpreg &= ~pinmask;
          GPIOx->BRR = (((uint32_t)0x01) << (pinpos + 0x08));
          GPIOx->BSRR = (((uint32_t)0x01) << (pinpos + 0x08));
    GPIOx->CRH = tmpreg;
GPIO_Init函数两个入参为GPIO_TypeDef和GPIO_InitTypeDef两个结构体指针
GPIO_TypeDef参数:
stm32f10x.h中找到GPIO_TypeDef结构体声明
  * @brief General Purpose I/O
  * 定义了GPIO的7个寄存器
typedef struct
  __IO uint32_t CRL;    // 端口配置低寄存器
  __IO uint32_t CRH;    // 端口配置高寄存器
  __IO uint32_t IDR;    // 端口输入寄存器
  __IO uint32_t ODR;    // 端口输出寄存器
  __IO uint32_t BSRR;   // 端口位设置/清除寄存器
  __IO uint32_t BRR;    // 端口位清除寄存器
  __IO uint32_t LCKR;   // 端口配置锁存寄存器
} GPIO_TypeDef;
GPIO_TypeDef有效性判断:
/** @defgroup GPIO_Exported_Types
  * GPIOA->GPIOG
#define IS_GPIO_ALL_PERIPH(PERIPH) (((PERIPH) == GPIOA) ||
                                    ((PERIPH) == GPIOB) ||
                                    ((PERIPH) == GPIOC) ||
                                    ((PERIPH) == GPIOD) ||
                                    ((PERIPH) == GPIOE) ||
                                    ((PERIPH) == GPIOF) ||
                                    ((PERIPH) == GPIOG))
GPIO_InitTypeDef参数:
stm32f10x_gpio.h中找到GPIO_InitTypeDef结构体声明
  * @brief  GPIO Init structure definition
  * GPIO_InitTypeDef结构体-设置IO口,速度,工作模式
typedef struct
  uint16_t GPIO_Pin;             /*!< Specifies the GPIO pins to be configured.
This parameter can be any value of @ref GPIO_pins_define */
  GPIOSpeed_TypeDef GPIO_Speed;  /*!< Specifies the speed for the selected pins.
This parameter can be a value of @ref GPIOSpeed_TypeDef */
  GPIOMode_TypeDef GPIO_Mode;    /*!< Specifies the operating mode for the selected pins.
This parameter can be a value of @ref GPIOMode_TypeDef */
}GPIO_InitTypeDef;
GPIO_InitStruct->GPIO_Speed有效性校验
  * @brief  Output Maximum frequency selection
typedef enum
  GPIO_Speed_10MHz = 1,
  GPIO_Speed_2MHz,
  GPIO_Speed_50MHz
}GPIOSpeed_TypeDef;
#define IS_GPIO_SPEED(SPEED) (((SPEED) == GPIO_Speed_10MHz) || ((SPEED) == GPIO_Speed_2MHz) ||
                              ((SPEED) == GPIO_Speed_50MHz))
GPIO_InitStruct->GPIO_Mode有效性校验
  * @brief  Configuration Mode enumeration
  * 八种输入/输出模式
typedef enum
{ GPIO_Mode_AIN = 0x0,          // 模拟输入
  GPIO_Mode_IN_FLOATING = 0x04, // 浮空输入
  GPIO_Mode_IPD = 0x28,         // 下拉输入
  GPIO_Mode_IPU = 0x48,         // 上拉输入
  GPIO_Mode_Out_OD = 0x14,      // 开漏输出
  GPIO_Mode_Out_PP = 0x10,      // 推挽输出
  GPIO_Mode_AF_OD = 0x1C,       // 复用开漏输出
  GPIO_Mode_AF_PP = 0x18        // 复用推挽输出
}GPIOMode_TypeDef;
#define IS_GPIO_MODE(MODE) (((MODE) == GPIO_Mode_AIN) ||
                            ((MODE) == GPIO_Mode_IN_FLOATING) ||
                            ((MODE) == GPIO_Mode_IPD) ||
                            ((MODE) == GPIO_Mode_IPU) ||
                            ((MODE) == GPIO_Mode_Out_PP) ||
                            ((MODE) == GPIO_Mode_AF_OD) ||
                            ((MODE) == GPIO_Mode_AF_PP))
GPIO_InitStruct->GPIO_Pin有效性校验
/** @defgroup GPIO_pins_define
  * GPIO_Pin_0->GPIO_Pin_15
#define GPIO_Pin_0                 ((uint16_t)0x0001)  /*!< Pin 0 selected */
[1] [2]
关键字:LED  跑马灯  库函数 引用地址:STM32 LED跑马灯-库函数
上一篇:新建工程模板-库函数
下一篇:STM32 SysTick定时器和delay延迟函数
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
