硬件设计
代码设计
#include "MAIN.H"
#include "LCD1602.h"
#include "PCF8591.h"
unsigned char code FFW_X[8]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //X反转顺序
unsigned char code FFZ_X[8]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //X正转顺序
unsigned char code FFW_Y[8]={0x10,0x30,0x20,0x60,0x40,0xc0,0x80,0x90}; //Y反转顺序
unsigned char code FFZ_Y[8]={0x90,0x80,0xc0,0x40,0x60,0x20,0x30,0x10}; //Y正转顺序
unsigned char Speed = 30,Direction = 1,X_Y = 0,stop = 1,mode = 0;
unsigned int k, temp;
int Angle = 0;
* 函 数 名 : main
* 函数功能 : 主函数
* 输 入 : 无
* 输 出 : 无
void main(void)
System_Init();
while(1)
temp = Read_PCF(); // 读取AD转换后的数字量
PCF_Output(temp); // DA转换,模拟量输出
//将数字量转换为十进制,*100 + 0.5将小数转换为整数,便于显示和存储
k = (float)temp * 5 / 256 * 100 + 0.5; // 将得到的结果存入数组
Key_Scan();
if(mode == 0)Motor();
if(mode == 1)
Angle = k/61*45;
if(Angle >= 0)
LCD1602_Location(2,7);
LCD1602_Write_Num(Angle);
if(X_Y==0)
GPIO_MOTOR = FFW_Y[k/62];
else
GPIO_MOTOR = FFW_X[k/62];
Delay(20);
void System_Init(void)
Init_PCF();
Init_LCD1602();
LCD1602_Location(1,1);
LCD1602_write_word("Welcome To Use!");
Delay(1000);
LCD1602_Clear();
LCD1602_write_word("Speed:");
LCD1602_Write_Num(Speed);
LCD1602_Location(2,1);
LCD1602_write_word("Angle:");
LCD1602_write_word("Null");
LCD1602_Location(1,11);
LCD1602_write_word("Stop");
LCD1602_Location(2,12);
LCD1602_write_word("X+");
LCD1602_Location(2,15);
LCD1602_write_word("O");
* 函 数 名: Motor
* 函数功能: 电机旋转函数
* 输 入: 无
* 输 出: 无
void Motor()
unsigned char i;
if(Speed>0)
for(i=0;i<8;i++)
if(Direction==1&&X_Y==0&&stop==0) //正转&Y电机&电机没按下停止
GPIO_MOTOR = FFW_Y[i];
if(Direction==2&&X_Y==0&&stop==0) //反转&Y电机&电机没按下停止
GPIO_MOTOR = FFZ_Y[i];
if(Direction==1&&X_Y!=0&&stop==0) //正转&X电机&电机没按下停止
GPIO_MOTOR = FFW_X[i];
if(Direction==2&&X_Y!=0&&stop==0) //反转&X电机&电机没按下停止
GPIO_MOTOR = FFZ_X[i];
Delay(1000/Speed); //调节转速
* 函 数 名 : Delay
* 函数功能 : 延时
* 输 入 : t
* 输 出 : 无
void Delay(unsigned int t)
unsigned int k;
while(t--)
for(k=0; k<80; k++);
* 函 数 名 : Key_Scan
* 函数功能 : 按键
* 输 入 : 无
* 输 出 : 无
void Key_Scan(void)
unsigned int i,j;
if(K1==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K1==0)
if(stop == 1)
stop=0;
LCD1602_write_word("Move");
else
stop=1; //stop为控制电机停止的标志位,但它为1时,电机停止
while((i<300)&&(K1==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K2==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K2==0)
Direction=1; //Direction 转向标志位,为2时为正转
LCD1602_Location(2,13);
LCD1602_write_word("+");
while((i<200)&&(K2==0))//检测按键是否松开
Delay(1);
i++;
i=0;
/********************检测按键K2是否按下***********************/
if(K3==0) //检测按键K2是否按下
Delay(1); //消除抖动
if(K3==0)
Direction=2; //Direction 转向标志位,为2时为反转
LCD1602_write_word("-");
while((i<200)&&(K3==0))//检测按键是否松开
Delay(1);
i++;
i=0;
/********************检测按键K3是否按下***********************/
if(K4==0)//检测按键K3是否按下
Delay(1);//消除抖动
if(K4==0)
if(Speed < 100)
Speed += 5;
LCD1602_Location(1,7);
while((i<200)&&(K4==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K5==0) //检测按键K4是否按下
Delay(1); //消除抖动
if(K5==0)
if(Speed > 0)
Speed -= 5;
while((i<200)&&(K5==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K6==0)//检测按键K1是否按下
Delay(1);//消除抖动
if(K6==0)
// Direction=0; //X_Y 电机的参数 X_Y=0为Y电机 X_Y=1为X电机
if(X_Y==0) //当切换电机时,对Direction=0;对标志位清零,防止上个电机的转向影响本次所控电机
X_Y=1;
LCD1602_write_word("Y");
else
X_Y=0;
LCD1602_write_word("X");
while((i<400)&&(K6==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K7==0)//检测按键K1是否按下
Delay(1);//消除抖动
if(K7==0)
if(Angle >= 0)
if(Direction==1&&stop==1) //正转&Y电机&电机没按下停止
if(j >= 8)j -= 8;
Angle += 45;
if(Angle >= 360)Angle -= 360;
j++;
if(X_Y==0)
GPIO_MOTOR = FFW_Y[j];
else
GPIO_MOTOR = FFW_X[j];
if(Direction==2&&stop==1) //反转&Y电机&电机没按下停止
if(j > 0)
Angle -= 45;
if(Angle <= 0)Angle = 0;
j--;
if(X_Y==0)
else
else
j = 0;
Delay(20);
while((i<2000)&&(K7==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K8==0)//检测按键K1是否按下
Delay(1);//消除抖动
if(K8==0)
mode = 1;
LCD1602_write_word("C");
while((i<500)&&(K8==0))//检测按键是否松开
Delay(1);
i++;
i=0;
if(K9==0)//检测按键K1是否按下
Delay(1);//消除抖动
if(K9==0)
mode = 0;
while((i<500)&&(K9==0))//检测按键是否松开
Delay(1);
i++;
i=0;
链接:https://pan.baidu.com/s/19qBroJVEvd2DRPwfSVv80Q
提取码:kxoc
上一篇:基于51单片机的智能家居控制温度光照气体检测
下一篇:基于AT89c51单片机的流水灯,中断定时,按钮控制
推荐阅读最新更新时间:2024-11-12 11:48
推荐帖子
- 三电阻电流采样与单电阻优越性比较
- FOC方面,市场上也有三电阻电流采样或者单电阻电流采样的方案,那么这两种方案有各有怎样的优劣势呢?首先看三电阻电流采样,根据李方哲介绍,这种方案因为拥有均衡的PWM,有充足的时间去采样,这就使得他们在低速过程中表现比较好,并且没有太多的振动。这是单电阻方案所不能比拟的。据了解,后者在低速的时候,抖动情况非常明显。此外,在刹车控制方面,三电阻的方案也优于单电阻方案。再看单电阻采样,因为这个方案采用的是总线电流采集的方式,那就使得其成本比较低,能很容易地检测到总
- alan000345 RF/无线
- 有没有人用过这个芯片啊,m62429
- 用stm32怎样去用这个芯片,求指导有没有人用过这个芯片啊,m62429m62429这个芯片怎么样,我现在也在用这个芯片,可以调节音量大小的时候会有录音,楼主,用这芯片有没有这个问题?
- mguaj stm32/stm8
- GSM教你理解verilog HDL语言的一些概念
- 一:基本Verilog中的变量有线网类型和寄存器类型。线网型变量综合成wire,而寄存器可能综合成WIRE,锁存器和触发器。二:verilog语句结构到门级的映射1、连续性赋值:assign连续性赋值语句逻辑结构上就是将等式右边的驱动左边的结点。因些连续性赋值的目标结点总是综合成由组合逻辑驱动的结点。Assign语句中的延时综合时都将忽视。2、过程性赋值:过程性赋值只出现在always语句中。阻塞赋值和非阻塞赋值就该赋值本身是没有区别的,只是对后面的语句有不同的影响。建议设计
- 北斗神猴 FPGA/CPLD
- IO pad里面的high-volt tolerant 是什么意思?
- 是新手,刚刚接触PAD,我看有的IOpad介绍里面有“high-volttolerant”这个内容,“high-volttolerant”是什么意思?是说这个IOpad可以在PAD端的电压很高的情况下也能正常工作还是说PAD端的电压的变化范围可以很大?谢谢!!!IOpad里面的high-volttolerant是什么意思? 不知在哪写的,应该是指耐压吧。 比如通常IC的输入信号不允许超过电源电压,但有的3.3V电源的IC,注有“I/O5Vtolerant”
- eeleader FPGA/CPLD
- rs485多机通信
- 直接上位机pc通过串口小助手发送一串数据控制多个单片机执行相应功能如何实现最好能给个实例代码rs485多机通信485有地址的,执行之前判断一下地址先
- 逍遥居士 51单片机
- 拜托诸位帮帮忙!
- 430f149没有RD和WR引脚,扩展液晶时需要这两个信号应如何解决为好?拜托诸位帮帮忙!用别的管脚模拟WR和RD时序thankyouthankyou
- well2003 微控制器 MCU
设计资源 培训 开发板 精华推荐
- TP5400锂电池充电升压模块 雪花灯底座2.0
- 使用 OP497 的 OP497FSZ 简单桥式调节放大器的典型应用电路
- 带有集成电感器的 EP5358LUA 600mA PowerSoC 电压模式同步 PWM 降压的典型应用
- FXLS8974CF 3轴物联网加速度传感器的传感器工具箱开发板
- LTC4055EUF 演示板、USB 电源控制器和锂离子充电器、适配器输入 = 4.5V 至 5.5V、USB 输入 = 4.35V 至 5.5V
- LT8570EMS8E 1MHz 升压转换器从 5V-12V 输入产生 24V 的典型应用
- LT3692AEFE、具有 UVLO/OVLO 和电源良好状态的 3.3V/5A 单路输出的典型应用电路
- LTC3621IMS8E-25 1.2V 输出、同步至 600kHz、强制连续模式同步降压型稳压器的典型应用
- 仪器模拟放大
- LTC4059A,简单小巧的单节锂离子电池充电器
- MM32F103开发板测评等你来
- 【EEWORLD第三十六届】2012年03月社区明星人物揭晓!
- Littelfuse 碳化硅(SiC) MOSFET和肖特基二极管产品介绍及相关应用
- 是德科技服务日研讨会|武汉站——邀请函
- 邀请好友体验WEBENCH,礼品丰厚你有他也有!
- 【迎新迎国庆】dcexpert带你“全栈”动手搞:基于ESP8266可充电的触控创意LED灯
- TI“无线”风光可穿戴现场培训直播,诚邀参与,预注册赢好礼
- 栅极驱动挑花眼?看英飞凌来支招
- 2021 STM32全国巡回研讨会线上直播报名倒计时!
- 【下载有礼】利用泰克新MSO6示波器 Spectrum View功能演示多通道信号频谱分析
- EEWORLD大学堂----WEBENCH 设计导出工具 WEBENCH Export 介绍
- 参与有礼——2015智能汽车/新能源汽车创新技术及方案研讨会
- 称重仪表的零点有漂移怎么办?
- LabView笔记三:基于LabView的三种方法实现掷骰子游戏
- EEWORLD芯币竞价活动——飞凌嵌入式工业级Cortex-A8开发板OK335xS-Ⅱ(已发奖)
- 一周精彩回顾:2018.6.25-7.1
- 【Altera soc 体验之旅】+基于自组网的无线路由设计在FPGA-SOC上的实现
- nrf51822的dual_bank和single_bank升级的故事——论攻城狮之间是多么的缺乏默契......
- 《走过路过,千万不要错过》 定时器中断 动态扫描 。单步可以。一执行 就有问题。。
- 求购:ADI的ADALM1000开发板,有坛友转让吗?
