51单片机 16X192点阵程序动态显示汉字
发布者:闪耀的星空最新更新时间:2021-12-22 来源: eefocus关键字:51单片机 手机看文章 扫描二维码
随时随地手机看文章
在这里插入图片描述
在这里插入图片描述
程序参考源代码如下:
#include
sbit ST=P3^5;
sbit E1=P3^4;
sbit MR=P3^7;
char cashe[12];
char code wd[12][16]={undefined
{0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF},
{0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/“无”,0/
/* (16 X 16 , 宋体 )*/
{0xDF,0xDF,0xDF,0xCF,0x57,0x58,0x5F,0xDF,0xDE,0xDE,0xDE,0xDD,0xDD,0xDB,0xDB,0xD7},
{0x7F,0x6F,0x73,0x77,0x7F,0x01,0x5F,0x5F,0xDF,0xDF,0xDF,0xDF,0xDD,0xDD,0xE1,0xFF},/“忧”,1/
{0xFE,0xFE,0xFE,0xC0,0xDE,0xDE,0xC0,0xDE,0xDE,0xDE,0xC0,0xDE,0xFE,0xFE,0xFF,0xFF},
{0xFF,0xFF,0xFF,0x07,0xF7,0xF7,0x07,0xF7,0xF7,0xF7,0x07,0xF7,0xFD,0xFD,0x01,0xFF},/“电”,2/
{0xFF,0xC0,0xFF,0xFF,0xFF,0xFE,0xFE,0xFE,0x00,0xFE,0xFE,0xFE,0xFE,0xFE,0xFA,0xFD},
{0xFF,0x0F,0xDF,0xBF,0x7F,0xFF,0xFF,0xFB,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/“子”,3/
{0xFF,0x83,0xBB,0xAB,0xAA,0xAA,0xA9,0xAB,0xAB,0xAA,0xEE,0xD7,0xDB,0xBB,0x7F,0xFF},
{0x7F,0x3F,0x7F,0x01,0xFD,0xFD,0xBD,0xBD,0x5D,0xED,0x05,0xED,0xFD,0xFD,0xEB,0xF7},/“购”,4/
{0xEF,0xEF,0xAF,0xAE,0x82,0xAD,0x6B,0xEB,0xE6,0xCD,0x2B,0xEF,0xEE,0xED,0xEB,0xFF},
{0x7F,0x7F,0x7F,0x03,0xAB,0xAB,0x6B,0x6B,0xDB,0xDB,0xBB,0x7B,0xFB,0xFB,0xD7,0xEF},/“物”,5/
void del(int i)//============================//延时程序
{while(i–);}
aline() =======================发送一行的显示程序
{undefined
char i=0;
TI=0;
for(i=0;i<12;i++)
{SBUF=cashe[i];while(~TI);TI=0;} //将缓存中的信息转存入595的存储器中,到此不显示
main()
{undefined
int m=0,n=0;
TI=0;
SM0=0;
SM1=0;
E1=0;
while(1)
for(m=0;m<16;m++) //共有16行 循环16次显示这16行 串行的595送出行的数据
{ //由74hc154选中要显示的行
for(n=0;n<12;n++) //这个for循环用来向缓存数组中装载要显示的内容
{cashe[11-n]=wd[n][m];} //将第m个字的第n行信息装载 ,因为595串接 数据第一个进去的会在最后一个595中,最后进去的会在第一个595中
aline(); //将缓存中的一行信息载入595缓存中
ST=0;ST=1; //595产生上升沿 输出595锁存的数据
P2=m; //选中要显示的行输出数据
del(100);//延时一段时间,以造成视觉暂存效应
关键字:51单片机 引用地址:51单片机 16X192点阵程序动态显示汉字
上一篇:4利用移位函数操作点亮流水灯
下一篇:51单片机串口通信数码管显示
推荐阅读最新更新时间:2024-10-23 15:52
程序参考源代码如下: #include AT89X52.H sbit ST=P3^5; sbit E1=P3^4; sbit MR=P3^7; char cashe ; char code wd ={undefined {0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF}, {0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/“无”,0/ /* (16 X 16 , 宋体 )*/ {0xDF,
[单片机]
<font color='red'>51单片机</font> <font color='red'>16X192</font><font color='red'>点阵</font>程序<font color='red'>动态显示</font><font color='red'>汉字</font>
基于Proteus与汇编语言的汉字点阵动态显示
  0 引言   Proteus ISIS是英国Labcenter公司开发的电路分析与实物仿真软件。它可以仿真、分析各种模拟器件和集成电路,该软件的特点是:a.实现了单片机仿真和 SPICE电路仿真相结合。具有模拟电路、数字电路仿真、单片机及其外围电路的仿真、各种虚拟仪器,如示波器等功能。b.支持主流单片机系统的仿真。c.提供软件调试功能。在硬件仿真系统中具有全速、单步、设置断点等调试功能;同时支持第三方的软件编译和调试环境,如Keil C51 uVision2等软件。d.具有强大的原理图绘制功能。Proteus软件的使用彻底改变了传统单片机学习和开发方式,初学者可以在没有实验硬件条件下进行仿真实验,开发者可以直接用Prote
[嵌入式]
单片机驱动16X192点阵程序及proteus仿真
下面是16X192点阵取模软件的设置截图 下面是16X192点阵的仿真原理图: 单片机源程序: #include AT89X52.H sbit ST=P3^5; sbit E1=P3^4; sbit MR=P3^7; char cashe ; char code wd ={ {0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF}, {0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/* 无 ,0*/
[单片机]
单片机驱动<font color='red'>16X192</font><font color='red'>点阵</font>程序及proteus仿真
基于AT89C51单片机的LED汉字点阵滚动显示屏设计
LED显示屏是利用发光二极管点阵模块或像素单元组成的平面式显示屏幕。它具有发光率高、使用寿命长、组态灵活、色彩丰富以及对室内外环境适应能力强等优点。并广泛的用于公交汽车、商店、体育场馆、车站、学校、银行、高速公路等公共场所的信息发布和广告宣传。LED显示屏发展较快,本文讲述了基于AT89C51单片机16×16LED汉字点阵滚动显示的基本原理、硬件组成与设计、程序编写与调试、Proteus软件仿真等基本环节和相关技术 1 硬件电路组成及工作原理 本产品采用以AT89C51单片机为核心芯片的电路来实现,主要由AT89C51芯片、时钟电路、复位电路、列扫描驱动电路(74HCl54)、16×16LED点阵5部分组成,如图1所示。其中,
[单片机]
基于AT89C<font color='red'>51单片机</font>的LED<font color='red'>汉字</font><font color='red'>点阵</font>滚动显示屏设计
51单片机教程:8*8 点阵显示字符、数字、简单汉字
点阵显示实验 一、什么是点阵? 我们用之前的方法一个IO口只能控制一个led,如果需要用更少的IO口控制更多的led怎么办呢,于是就有了点阵。 8X8点阵共由64个发光二极管组成,且每个发光二极管是放置在行线和列线的交叉点上,当对应的某一行置1电平,某一列置0电平,则相应的二极管就亮;如要将第一个点点亮,则1脚接高电平a脚接低电平,则第一个点就亮了; 二、点阵原理图 可以看到点阵是由led按照一定的排列组成 实物图: 我们可以打开protues,用led模仿一下点阵结构,了解一下原理 三、测试点阵 1、 proteus里点阵是MATRIX,选择8*8就行了 发现没有引脚标识,只能自己测试一下了、 先接一个电源试
[单片机]
<font color='red'>51单片机</font>教程:8*8 <font color='red'>点阵</font>显示字符、数字、简单<font color='red'>汉字</font>
51单片机,点阵显示汉字(C语言)
#include #include #define uint unsigned int #define uchar unsigned char sbit SH_595=P2^1; sbit DATA_595=P2^0; sbit ST_CP_595=P2^2;//74HC595(12)-ST_CP上升沿-移位寄存器的数据进入数据存储寄存器 输出锁存器的时钟信号端口 sbit MR_595=P2^3; //74HC595(10)-MR 为0将移位寄存器的数据清0 sbit E1_154=P2^4;//74HC154(18)-E1为0开列(col)输出 显示允许 控制信号端口 uchar keynum; uchar tem
[单片机]
51单片机 16X16点阵循环滚动显示汉字
一、效果展示 二、所用材料 1.16X16点阵 Proteus并不提供16X16的点阵,只能我们自己通过4个8X8的组装为16X16的点阵。 由此可知8*8变成16*16 列需要这样连接: 行需要这样连接: 再把四个放在一起即可: 2.74hc595 详细介绍见我上一篇文章 https://blog.csdn.net/qq_41639829/article/details/82151706 这里需要用到级联,也不算太难,就相当于原来是输入8个数,这需要输入16个,然后再输出,前八个输入的就被自动挤到级联的下一个595中了! 3.stc89c52 三、原理 1.静态显示 同8位的静态显示一
[单片机]
<font color='red'>51单片机</font> 16X16<font color='red'>点阵</font>循环滚动显示<font color='red'>汉字</font>
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
