一共需要安装两个软件, MPLAB X IDE v5.50和 xc8-v2.32-full-install-windows-x64-installer
为了仿真,也可以安装proteus软件
1 MPLAB X IDE v5.50的安装
软件下载链接:
https://www.microchip.com/en-us/development-tools-tools-and-software/mplab-x-ide#tabs
下载好软件后,一直next即可。
2 xc8-v2.32-full-install-windows-x64-installer的安装
因为单片机型号是PIC16F15323,所以选择XC8
软件下载链接:
https://www.microchip.com/en-us/development-tools-tools-and-software/mplab-xc-compilers
下载好软件后,一直next即可。
3 建立工程
1、双击打开MPLAB X IDE v5.50
2、点击file–选择new project----选择Microchip Embedded—选择standlone project—点击next
3、family选择Mid-range 8-bit MCUs;device选择PIC16F15323。点击next
4、编译器选择XC8,如下图所示。
5、project name自己根据实现功能取名,这里命名为led2。--------选择合适的project location。-------Encoding选择GB2312。------点击finish。
6、新建主函数,具体实现步骤为:
单击右键source files-----选择new----选择main.c----命名为main----点击finish。
7、添加熔丝位配置。具体实现步骤为:
点击production-----点击set configuration bits----点击generate source code to output
8、复制生成的代码到main.c,如下图所示
// PIC16F15323 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = ECH // External Oscillator mode selection bits (EC above 8MHz; PFM set to high power)
#pragma config RSTOSC = EXT1X // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits)
#pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = ON // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable bit (FSCM timer enabled)
// CONFIG2
#pragma config MCLRE = ON // Master Clear Enable bit (MCLR pin is Master Clear function)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config LPBOREN = OFF // Low-Power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = ON // Brown-out reset enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices)
#pragma config ZCD = OFF // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.)
#pragma config PPS1WAY = ON // Peripheral Pin Select one-way control (The PPSLOCK bit can be cleared and set only once in software)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = ON // WDT operating mode (WDT enabled regardless of sleep; SWDTEN ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC // WDT input clock selector (Software Control)
// CONFIG4
#pragma config BBSIZE = BB512 // Boot Block Size Selection bits (512 words boot block size)
#pragma config BBEN = OFF // Boot Block Enable bit (Boot Block disabled)
#pragma config SAFEN = OFF // SAF Enable bit (SAF disabled)
#pragma config WRTAPP = OFF // Application Block Write Protection bit (Application Block not write protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block not write protected)
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration Register not write protected)
#pragma config WRTSAF = OFF // Storage Area Flash Write Protection bit (SAF not write protected)
#pragma config LVP = ON // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR.)
// CONFIG5
#pragma config CP = OFF // UserNVM Program memory code protection bit (UserNVM code protection disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include void main(void) { return; } 9、在main 里面添加功能代码
上一篇:PIC16F877A单片机 (外部中断)
下一篇:PIC16F877A单片机 (中断与定时器Timer2)
推荐阅读最新更新时间:2024-11-09 11:27
