一、环境介绍
1.1 宿主机
Ubuntu 1404 32 位
1.2 嵌入式平台
ATMEL AT91SAM9X25
1.3 交叉工具链
arm-none-linux-gnueabi
openssh-7.5-p1移植所需源码包下载地址
二、交叉编译
2.1 先编译 openssh-7.5-p1 依赖的模块
2.1.1 zlib
tar xvf zlib-1.2.11.tar.xz
cd zlib-1.2.11/
export CC=arm-none-linux-gnueabi-gcc
./configure --prefix=$PWD/tmp
make CC=arm-none-linux-gnueabi-gcc AR=arm-none-linux-gnueabi-ar LD=arm-none-linux-gnueabi-ld ANLIB=arm-none-linux-gnueabi-ranlib
make install
2.1.2 openssl
tar xvf openssl-1.0.2o.tar.gz
cd openssl-1.0.2o/
./Configure --prefix=$PWD/tmp os/compiler:arm-none-linux-gnueabi-gcc
make
make install
2.2 openssh
不执行 make install, 因为安装是在当前系统部署
bash
tar xvf openssh-7.5p1.tar.gz
cd openssh-7.5p1/
./configure --host=arm-none-linux-gnueabi --build=i686-linux --prefix=$PWD/tmp --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc/ssh --libexecdir=/usr/libexec --with-privsep-user=sshd --with-privsep-path=/var/empty -with-libs --with-zlib=/home/gino/work/jiaxian/9X25/transplant/openssh-node/zlib-1.2.11/tmp --with-ssl-dir=/home/gino/work/jiaxian/9X25/transplant/openssh-node/openssl-1.0.2o/tmp --disable-etc-default-login CC=arm-none-linux-gnueabi-gcc AR=arm-none-linux-gnueabi-ar --disable-lastlog --disable-utmp --disable-utmpx --disable-wtmp --disable-wtmpx
make
三、部署
3.1 ssh 运行依赖的设备文件
/dev/tty
/dev/random
/dev/urandom
3.2 文件及目录
/var/empty
~ # ls -l /etc/ssh
-rw-r--r-- 1 root root 1642 May 21 2018 ssh_config
-rw----r-- 1 root root 668 May 21 2018 ssh_host_dsa_key
-rw-r--r-- 1 root root 598 May 21 2018 ssh_host_dsa_key.pub
-rw----r-- 1 root root 227 May 21 2018 ssh_host_ecdsa_key
-rw-r--r-- 1 root root 170 May 21 2018 ssh_host_ecdsa_key.pub
-rw----r-- 1 root root 399 May 21 2018 ssh_host_ed25519_key
-rw-r--r-- 1 root root 90 May 21 2018 ssh_host_ed25519_key.pub
-rw----r-- 1 root root 1675 May 21 2018 ssh_host_rsa_key
-rw-r--r-- 1 root root 390 May 21 2018 ssh_host_rsa_key.pub
-rw-r--r-- 1 root root 3156 May 21 2018 sshd_config
/usr/bin/scp
/usr/bin/sftp
/usr/bin/ssh
/usr/bin/ssh-add
/usr/bin/ssh-agent
/usr/bin/ssh-keygen
/usr/bin/ssh-keyscan
/usr/sbin/sshd
/usr/libexec/sftp-server
/usr/libexec/ssh-keysign
**note:**key 文件的生成是在目标板执行以下命令,另外需要注意的是 key 文件的权限
cd /etc/ssh/
ssh-keygen -t rsa1 -f ssh_host_key -N ""
ssh-keygen -t rsa -f ssh_host_rsa_key -N ""
ssh-keygen -t dsa -f ssh_host_dsa_key -N ""
ssh-keygen -t ecdsa -f ssh_host_ecdsa_key -N ""
ssh-keygen -t ed25519 -f ssh_host_ed25519_key -N ""
3.3 其它需要修改的文件
/etc/passwd 新增
sshd:x:74:74:Privilege-separated SSH:/var/empty/sshd:/sbin/nologin
/etc/ssh/sshd_config 修改
PermitRootLogin yes
设计资源 培训 开发板 精华推荐
- 【训练营_进阶班】智能物联网
- L78L33AB正压稳压器Edit boost电路的典型应用
- AD8350-EVAL,评估板经过精心布局和测试,以展示 AD8350 的指定高速性能
- LTC3649EFE 宽输入信号范围音频驱动器的典型应用电路
- Novena:基于飞思卡尔与 Xilinx FPGA开源计算机, 专为用作台式机、笔记本电脑或独立板而设计
- R1215D PWM升压DC/DC控制器典型应用
- ATA5756、UHF ASK/FSK PLL 发送器 IC 参考设计
- 使用 Infineon Technologies AG 的 BGA428 的参考设计
- 合宙iot power usb
- YuToo墨水屏时钟
