根据 OpenMV与stm32,msp432等单片机的串口通讯(已经写好一个识别色块的例程,可直接使用)keil(MDK)改进。
一、首先有一个大思想的问题,举个例子就是假如msp432充当“大脑”,openmv就相当于“眼睛”,那么链接所写的就是“眼睛”一直在向“大脑”发送数据,中断会一直触发。那么我们换种思路,如果是我“大脑”发个信号之后,“眼睛”再将数据发送给“大脑”。
(利:中断触发减少,可调整数据发送速率,可主动请求数据。)
(弊:主程序占用,请求可能会被搁置,如果使用定时器的延时可以避免这个。)
二、就是他的那个代码里有一个数据的判断是错误的。
下面是openmv的代码
# Blob Detection and uart transport
import sensor, image, time
from pyb import UART
import json
import lcd
# For color tracking to work really well you should ideally be in a very, very,
# very, controlled enviroment where the lighting is constant...
yellow_threshold = (1, 17, -20, 11, -12, 17)
#记得更改要识别色块的阈值
# You may need to tweak the above settings for tracking green things...
# Select an area in the Framebuffer to copy the color settings.
sensor.reset() # Initialize the camera sensor.
sensor.set_pixformat(sensor.RGB565) # use RGB565.
sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.
sensor.skip_frames(10) # Let new settings take affect.
sensor.set_auto_whitebal(False) # turn this off.
clock = time.clock() # Tracks FPS.
lcd.init() # Initialize the lcd screen.
#lcd初始化
uart = UART(3, 115200)
uart.init(115200,bits=8,parity=None,stop=1)
#这里是UART3,115200
def find_max(blobs):
max_size=0
for blob in blobs:
if blob.pixels() > max_size:
max_blob=blob
max_size = blob.pixels()
return max_blob
#得到识别面积最大的色块
while(True):
img = sensor.snapshot() # Take a picture and return the image.
blobs = img.find_blobs([yellow_threshold])
if blobs:
max_blob=find_max(blobs)
img.draw_rectangle(max_blob.rect())
img.draw_cross(max_blob.cx(), max_blob.cy())
img.draw_string(0,0,'x='+str(max_blob.cx()),color=(0,0,0))
img.draw_string(0,10,'y='+str(max_blob.cy()),color=(0,0,0))
output_str=bytearray([0x2c,4,max_blob.cx(),max_blob.cy(),max_blob.w(),max_blob.h(),0x5B])
#output_str="[%d,%d,%d,%d]" % (max_blob.cx(),max_blob.cy(),max_blob.w(),max_blob.h()) #方式1
#output_str=json.dumps([max_blob.cx(),max_blob.cy()]) #方式2
#output_str = json.dumps(max_blob)
# print('you send:',output_str)
lcd.display(img) # Take a picture and display the image.
#将图像显示在lcd中
#else:
##print('not found!')
#print('you send:',output_str)
#output_str=bytearray([0x2c,0,0x5B])
#uart.write(output_str)
if uart.any():
a=uart.readline().decode().strip()
# b=int(a)
print(a)
if a=='x':
a='NULL'
b=0
#加入了一个判断的条件,当主机发送'x'时,我发送数据
还有一些当时存在疑惑的地方这里解释一下
2c就相当于报头,5B相当于结尾
2c在ccs中不是16进制显示的话会是’,’ ASCII码是44
5B在ccs中不是16进制显示的话回是’[’ ASCII码是91
期中的max_blob.cx(),max_blob.cy(),max_blob.w(),max_blob.h()是最大的目标的x,y坐标,还有宽和高。
有一个.h头文件,在stm32中和msp432中都是一样的,都可以用。
#ifndef __openmv_H
#define __openmv_H
typedef struct
u16 cx;
u16 cy;//最大色块的中心坐标
u16 w;
u16 h;
u16 s;//最大色块的面积(在popenv ide软件上运行框起来的面积(w*h))
}_CARD;
void Openmv_Init(u32 bound);
void Openmv_Receive_Data(int16_t data);
extern _CARD CARD;
#endif
/* end of openmv.h */
(转自原作者)
还有.c文件
* MSP432 UART - Loopback with 24MHz DCO BRCLK
* MCLK = HSMCLK = SMCLK = DCO of 24MHz
* MSP432P401
* RST -| P3.3/UCA0TXD|----定时发送数据请求
* | P3.2/UCA0RXD|----接收数据,8bit*7个
/* DriverLib Includes */
#include /* Standard Includes */ #include #include #include "openmv.h" _CARD CARD={0}; uint8_t RXData = 0; uint8_t TXData = 'x'; /* UART Configuration Parameter. These are the configuration parameters to * make the eUSCI A UART module to operate with a 115200 baud rate. These * values were calculated using the online calculator that TI provides * at: * http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP430BaudRateConverter/index.html */ const eUSCI_UART_ConfigV1 uartConfig = { EUSCI_A_UART_CLOCKSOURCE_SMCLK, // SMCLK Clock Source 13, // BRDIV 0, // UCxBRF 37, // UCxBRS 设置波特率为115200 EUSCI_A_UART_NO_PARITY, // No Parity EUSCI_A_UART_LSB_FIRST, // LSB First EUSCI_A_UART_ONE_STOP_BIT, // One stop bit EUSCI_A_UART_MODE, // UART mode EUSCI_A_UART_OVERSAMPLING_BAUDRATE_GENERATION, // Oversampling EUSCI_A_UART_8_BIT_LEN // 8 bit data length }; void Openmv_Init(void) { MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P3, GPIO_PIN2 | GPIO_PIN3, GPIO_PRIMARY_MODULE_FUNCTION); /* Configuring UART Module */ MAP_UART_initModule(EUSCI_A2_BASE, &uartConfig); /* Setting DCO to 24MHz (upping Vcore) */ FlashCtl_setWaitState(FLASH_BANK0, 1); FlashCtl_setWaitState(FLASH_BANK1, 1); MAP_PCM_setCoreVoltageLevel(PCM_VCORE1); CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_24); /* Enable UART module */ MAP_UART_enableModule(EUSCI_A2_BASE); // MAP_UART_clearInterruptFlag (EUSCI_A2_BASE); /* Enabling interrupts */ MAP_UART_enableInterrupt(EUSCI_A2_BASE, EUSCI_A_UART_RECEIVE_INTERRUPT); MAP_Interrupt_enableInterrupt(INT_EUSCIA2); MAP_Interrupt_enableMaster(); } void Openmv_Receive_Data(uint8_t data)//接收Openmv传过来的数据 { static uint8_t openmv[7]; //存取数据 static uint8_t state = 0; uint8_t i; static uint8_t bit_number=0; if(state==0&&data==0x2C) { state=1; openmv[bit_number++]=data; } else if(state==1&&data==4) { state=2; openmv[bit_number++]=data; } else if(state==2) { openmv[bit_number++]=data; if(bit_number>=6) { state=3; } } else if(state==3) //检测是否接受到结束标志 { if(data == 0x5B) { state = 0; openmv[bit_number++]=data; CARD.cx=openmv[2]; CARD.cy=openmv[3]; CARD.w=openmv[4]; CARD.h=openmv[5]; CARD.s=openmv[4]*openmv[5]; } else if(data != 0x5B) { state = 0; for(i=0;i<=7;i++)
上一篇:MSP432滴答定时器(SysTick)说明和配置
下一篇:MSP432中断初试
推荐阅读最新更新时间:2024-11-13 08:29
设计资源 培训 开发板 精华推荐
- 冰墩墩V2.0
- OP484FPZ输出过载恢复运放测试电路典型应用
- NCP1342PD45WGEVB:NCP1342 45 W USB PD 评估板
- DC2268A-A,用于 LTM4620EV 双降压模块稳压器的演示板,5.5V = VIN = 16V,Vout1 = 3.3V @ 13A,Vout2 = 1.5V @ 13A
- SG1843交直流开关转换器典型应用电路
- 超迷你Arduino
- LT8570IDD-1 1.2MHz 电荷泵的典型应用从单个锂离子电池产生 ±12V
- AKD5357-B,AK5357 24 位 Delta-Sigma ADC 评估板
- 多功能双热插拔控制器/电源排序器允许带电背板插入
- RDR-292 - 用于 LED 街道照明的 150 W LLC 电源的参考设计报告
