初始化函数可以通过CubeMX配置,这里直接通过原码记录:
注意点:
STM32F407配置时钟频率为168MHz,TIM3挂载再APB1总线上时钟频率为84MHz,WS2812B需要的时钟频率为800K则定时器预装载寄存器的初值应配置为84M/800K = 105
0码和1码的配置需要根据预装载寄存器设定的初值来配置以符合WS2812手册中的0码和1码的时序。可参考:https://blog.csdn.net/xiaoyuanwuhui/article/details/99639068
芯片外设层驱动
tim.h
#ifndef __TIM_H
#define __TIM_H
#include "stm32f4xx.h"
extern TIM_HandleTypeDef htim3;
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* timHandle);
void tim3_init(void);
#endif /* __TIM_H */
tim.c
#include "tim.h"
DMA_HandleTypeDef hdma_tim3_ch1_trig;
TIM_MasterConfigTypeDef sMasterConfig;
TIM_OC_InitTypeDef sConfigOC;
htim3.Instance = TIM3;
htim3.Init.Prescaler = 0;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 105-1;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
// _Error_Handler(__FILE__, __LINE__);
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 0;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
HAL_TIM_MspPostInit(&htim3);
void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef* tim_pwmHandle)
if(tim_pwmHandle->Instance==TIM3)
/* TIM3 clock enable */
__HAL_RCC_TIM3_CLK_ENABLE();
/* DMA controller clock enable */
__HAL_RCC_DMA1_CLK_ENABLE();
/* TIM3 DMA Init */
/* TIM3_CH1_TRIG Init */
hdma_tim3_ch1_trig.Instance = DMA1_Stream4;
hdma_tim3_ch1_trig.Init.Channel = DMA_CHANNEL_5;
hdma_tim3_ch1_trig.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_tim3_ch1_trig.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_tim3_ch1_trig.Init.MemInc = DMA_MINC_ENABLE;
hdma_tim3_ch1_trig.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_tim3_ch1_trig.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_tim3_ch1_trig.Init.Mode = DMA_NORMAL;
hdma_tim3_ch1_trig.Init.Priority = DMA_PRIORITY_MEDIUM;
hdma_tim3_ch1_trig.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
if (HAL_DMA_Init(&hdma_tim3_ch1_trig) != HAL_OK)
/* Several peripheral DMA handle pointers point to the same DMA handle.
Be aware that there is only one stream to perform all the requested DMAs. */
__HAL_LINKDMA(tim_pwmHandle,hdma[TIM_DMA_ID_CC1],hdma_tim3_ch1_trig);
__HAL_LINKDMA(tim_pwmHandle,hdma[TIM_DMA_ID_TRIGGER],hdma_tim3_ch1_trig);
/* TIM3 interrupt Init */
HAL_NVIC_SetPriority(TIM3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM3_IRQn);
/* DMA interrupt init */
/* DMA1_Stream4_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Stream4_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Stream4_IRQn);
GPIO_InitTypeDef GPIO_InitStruct;
if(timHandle->Instance==TIM3)
/* GPIOA clock enable */
__HAL_RCC_GPIOA_CLK_ENABLE();
/**TIM3 GPIO Configuration
PA6 ------> TIM3_CH1
GPIO_InitStruct.Pin = GPIO_PIN_6;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.Alternate = GPIO_AF2_TIM3;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
void HAL_TIM_PWM_MspDeInit(TIM_HandleTypeDef* tim_pwmHandle)
/* Peripheral clock disable */
__HAL_RCC_TIM3_CLK_DISABLE();
/* TIM3 DMA DeInit */
HAL_DMA_DeInit(tim_pwmHandle->hdma[TIM_DMA_ID_CC1]);
HAL_DMA_DeInit(tim_pwmHandle->hdma[TIM_DMA_ID_TRIGGER]);
/* TIM3 interrupt Deinit */
HAL_NVIC_DisableIRQ(TIM3_IRQn);
* @brief This function handles DMA1 stream4 global interrupt.
void DMA1_Stream4_IRQHandler(void)
HAL_DMA_IRQHandler(&hdma_tim3_ch1_trig);
* @brief This function handles TIM3 global interrupt.
void TIM3_IRQHandler(void)
HAL_TIM_IRQHandler(&htim3);
WS2812硬件驱动
ws281x.h
#ifndef __WS281X_H
#define __WS281x_H
#include "tim.h"
void ws281x_init(void);
void ws281x_show(void);
uint32_t ws281x_color(uint8_t r, uint8_t g, uint8_t b);
void ws281x_setColor(uint16_t n, uint32_t color);
void ws281x_close(void);
#endif /* __WS281X_H */
ws281x.c
#include "WS281x.h"
#include #ifndef PIXEL_NUM #define PIXEL_NUM 5 #endif #define GRB (3*8) #define WS_TERO 30 #define WS_ONE 45 /* pwm 占空比数值为uint16_t 类型,DMA传输时只能以半字输出,pixelBuffer应为uint16_t 类型 */ uint16_t pixelBuffer[PIXEL_NUM][GRB]; void ws281x_init(void) { /* 配置TIM3 pwm频率为800Khz */ tim3_init(); } void ws281x_show(void) { HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_1, (uint32_t *)pixelBuffer, PIXEL_NUM * GRB); } uint32_t ws281x_color(uint8_t r, uint8_t g, uint8_t b) { return (uint32_t)(g << 16 | r << 8 | b); } /* pixel num from 0 start */ void ws281x_setColor(uint16_t n, uint32_t color) { if(n < PIXEL_NUM) { for(uint8_t i = 0; i < GRB; ++i) { pixelBuffer[n][i] = ((color << i) & 0x800000) ? WS_ONE : WS_TERO; } } } void ws281x_close(void) { uint16_t* ptr = (uint16_t *)pixelBuffer; for(uint16_t i = 0; i < PIXEL_NUM * GRB; ++i) { *ptr++ = WS_TERO; } ws281x_show(); } /* 中断回调函数,在设定的pwm通过DMA发送完成后会调用 */ void HAL_TIM_PWM_PulseFinishedCallback(TIM_HandleTypeDef* htim) { __HAL_TIM_SetCompare(htim, TIM_CHANNEL_1, 0); //占空比清0,若不清会导致灯珠颜色不对 HAL_TIM_PWM_Stop_DMA(htim, TIM_CHANNEL_1); } 结语 这里只实现了底层驱动接口,未移植显示效果部分的代码,显示效果可参考我的其他WS2812相关文章。HAL库分层效果确实好,但内部代码的理解难度要高很多
上一篇:彻底搞清printf在STM32上的使用
下一篇:STM32HAL库串口处理---中断收发
推荐阅读最新更新时间:2024-11-13 19:04
设计资源 培训 开发板 精华推荐
- 深圳通-PCB-开源
- MC33074ADR2G快速建立逆变器的典型应用
- 用于便携式的 12 位、1 通道 DAC
- 使用 ON Semiconductor 的 NCV4949 的参考设计
- STR-ACF-12V100WPSU-GEVB:启用 Strata 的 NCP1568 100W 交流到直流转换器
- 485转TTL485通信模块正常双相自动切换收发数据modbus
- LT1952EGN-1、LTC3900CS8、LT4430ES6 演示板,Vin=34V-75V Vout=3.3V @ 30A
- 5V升压电路
- LT6656BIS6-3.3、3.3V ADC 电压基准和桥式激励电源的典型应用
- Si91822 微功率 300mA CMOS 固定输出 LDO 稳压器的典型应用,具有错误标志/上电复位
