代码 : https://github.com/lisider/linux/tree/ok6410a-linux-5.11
提交id : 0cf53aa024fbd417f0796a77ff7f9b891680dac8
defconfig : arch/arm/configs/ok6410A_sdboot_mini_net_lcd_x11_usb_debug_uvc_defconfig
用户空间代码 uvc_cam_test
Makefile
CROSS_COMPILE =arm-none-linux-gnueabi-
KERNELDIR =
CFLAGS = -I$(KERNELDIR)/include -O -Wall -static
CC = $(CROSS_COMPILE)gcc
AR = $(CROSS_COMPILE)ar
ALL : uvc_cam_test
test_usb_camera: uvc_cam_test.c
$(CC) -o uvc_cam_test uvc_cam_test.c $(CFLAGS)
clean :
rm -rf uvc_cam_test
uvc_cam_test.c
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #define CLEAR(x) memset (&(x), 0, sizeof (x)) struct buffer { void * start; size_t length; }; static char * dev_name = NULL; static int fd = -1; struct buffer * buffers = NULL; static unsigned int n_buffers = 0; static int time_in_sec_capture=5; static int fbfd = -1; static struct fb_var_screeninfo vinfo; static struct fb_fix_screeninfo finfo; static char *fbp=NULL; static long screensize=0; static void errno_exit (const char * s) { fprintf (stderr, "%s error %d, %sn",s, errno, strerror (errno)); exit (EXIT_FAILURE); } static int xioctl (int fd,int request,void * arg) { int r; do r = ioctl (fd, request, arg); while (-1 == r && EINTR == errno); return r; } inline int clip(int value, int min, int max) { return (value > max ? max : value < min ? min : value); } static void process_image (const void * p){ //ConvertYUVToRGB32 unsigned char* in=(unsigned char*)p; int width=320; int height=240; int istride=width*2; int x,y,j; int y0,u,y1,v,r,g,b; long location=0; for ( y = 10; y < height + 10; ++y) { for (j = 0, x=10; j < width * 2 ; j += 4,x +=2) { location = (x+vinfo.xoffset) * (vinfo.bits_per_pixel/8) + (y+vinfo.yoffset) * finfo.line_length; y0 = in[j]; u = in[j + 1] - 128; y1 = in[j + 2]; v = in[j + 3] - 128; r = (298 * y0 + 409 * v + 128) >> 8; g = (298 * y0 - 100 * u - 208 * v + 128) >> 8; b = (298 * y0 + 516 * u + 128) >> 8; fbp[ location + 0] = ((clip(g, 0, 255)&0x1c)<< 3 ) | ( clip(b, 0, 255) >> 3 ); fbp[ location + 1] = ((clip(r, 0, 255) & 0xf8) ) | ( clip(g, 0, 255)>> 5); r = (298 * y1 + 409 * v + 128) >> 8; g = (298 * y1 - 100 * u - 208 * v + 128) >> 8; b = (298 * y1 + 516 * u + 128) >> 8; fbp[ location + 2] = ((clip(g, 0, 255)&0x1c)<< 3 ) | ( clip(b, 0, 255) >> 3 ); fbp[ location + 3] = ((clip(r, 0, 255) & 0xf8) ) | ( clip(g, 0, 255)>> 5); } in +=istride; } } static int read_frame (void) { struct v4l2_buffer buf; CLEAR (buf); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; if (-1 == xioctl (fd, VIDIOC_DQBUF, &buf)) { switch (errno) { case EAGAIN: return 0; case EIO: default: errno_exit ("VIDIOC_DQBUF"); } } assert (buf.index < n_buffers); // printf("v4l2_pix_format->field(%d)n", buf.field); //assert (buf.field ==V4L2_FIELD_NONE); process_image (buffers[buf.index].start); if (-1 == xioctl (fd, VIDIOC_QBUF, &buf)) errno_exit ("VIDIOC_QBUF"); return 1; } static void run (void) { int frames; frames = 30 * time_in_sec_capture; while (frames-- > 0) { for (;;) { fd_set fds; struct timeval tv; int r; FD_ZERO (&fds); FD_SET (fd, &fds); tv.tv_sec = 2; tv.tv_usec = 0; r = select (fd + 1, &fds, NULL, NULL, &tv); if (-1 == r) { if (EINTR == errno) continue; errno_exit ("select"); } if (0 == r) { fprintf (stderr, "select timeoutn"); exit (EXIT_FAILURE); } if (read_frame ()) break; } } } static void stop_capturing (void) { enum v4l2_buf_type type; type = V4L2_BUF_TYPE_VIDEO_CAPTURE; if (-1 == xioctl (fd, VIDIOC_STREAMOFF, &type)) errno_exit ("VIDIOC_STREAMOFF"); } static void start_capturing (void) { unsigned int i; enum v4l2_buf_type type; for (i = 0; i < n_buffers; ++i) { struct v4l2_buffer buf; CLEAR (buf); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = i; if (-1 == xioctl (fd, VIDIOC_QBUF, &buf)) errno_exit ("VIDIOC_QBUF"); } type = V4L2_BUF_TYPE_VIDEO_CAPTURE; if (-1 == xioctl (fd, VIDIOC_STREAMON, &type)) errno_exit ("VIDIOC_STREAMON"); } static void uninit_device (void) { unsigned int i; for (i = 0; i < n_buffers; ++i) if (-1 == munmap (buffers[i].start, buffers[i].length)) errno_exit ("munmap"); if (-1 == munmap(fbp, screensize)) { printf(" Error: framebuffer device munmap() failed.n"); exit (EXIT_FAILURE) ; } free (buffers); } static void init_mmap (void) { struct v4l2_requestbuffers req; //mmap framebuffer fbp = (char *)mmap(NULL,screensize,PROT_READ | PROT_WRITE,MAP_SHARED ,fbfd, 0); if ((int)fbp == -1) { printf("Error: failed to map framebuffer device to memory.n"); exit (EXIT_FAILURE) ; } memset(fbp, 0, screensize); CLEAR (req); req.count = 4; req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; req.memory = V4L2_MEMORY_MMAP; if (-1 == xioctl (fd, VIDIOC_REQBUFS, &req)) { if (EINVAL == errno) { fprintf (stderr, "%s does not support memory mappingn", dev_name); exit (EXIT_FAILURE); } else { errno_exit ("VIDIOC_REQBUFS"); } } if (req.count < 4) { //if (req.count < 2) fprintf (stderr, "Insufficient buffer memory on %sn",dev_name); exit (EXIT_FAILURE); } buffers = calloc (req.count, sizeof (*buffers)); if (!buffers) { fprintf (stderr, "Out of memoryn"); exit (EXIT_FAILURE); } for (n_buffers = 0; n_buffers < req.count; ++n_buffers) { struct v4l2_buffer buf; CLEAR (buf); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = n_buffers; if (-1 == xioctl (fd, VIDIOC_QUERYBUF, &buf)) errno_exit ("VIDIOC_QUERYBUF"); buffers[n_buffers].length = buf.length; buffers[n_buffers].start =mmap (NULL,buf.length,PROT_READ | PROT_WRITE ,MAP_SHARED,fd, buf.m.offset); if (MAP_FAILED == buffers[n_buffers].start) errno_exit ("mmap"); } } static void init_device (void) { struct v4l2_capability cap; struct v4l2_cropcap cropcap; struct v4l2_crop crop; struct v4l2_format fmt; // Get fixed screen information //得到固定屏幕的信息 if (-1==xioctl(fbfd, FBIOGET_FSCREENINFO, &finfo)) { printf("Error reading fixed information.n"); exit (EXIT_FAILURE); } // Get variable screen information //得到可变屏幕的信息 if (-1==xioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo)) { printf("Error reading variable information.n"); exit (EXIT_FAILURE); } screensize = vinfo.xres * vinfo.yres * vinfo.bits_per_pixel / 8; //输出可变屏幕和固定屏幕的信息 printf("vinfo: xoffset:%d yoffset:%d bits_per_pixel:%d xres:%d yres:%dn",vinfo.xoffset, vinfo.yoffset, vinfo.bits_per_pixel, vinfo.xres, vinfo.yres); printf("finfo: line_length:%d screensize:%ldn", finfo.line_length, screensize); //获取camere的信息,复制到cap中 if (-1 == xioctl (fd, VIDIOC_QUERYCAP, &cap)) { if (EINVAL == errno) { fprintf (stderr, "%s is no V4L2 devicen",dev_name); exit (EXIT_FAILURE); } else { errno_exit ("VIDIOC_QUERYCAP"); } } printf("cap.capabilities = %dn",cap.capabilities); if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) { //#define V4L2_CAP_VIDEO_CAPTURE 0x00000001 /* Is a video capture device */ fprintf (stderr, "%s is no video capture devicen",dev_name); exit (EXIT_FAILURE); } if (!(cap.capabilities & V4L2_CAP_STREAMING)) { //#define V4L2_CAP_STREAMING 0x04000000 /* streaming I/O ioctls */ fprintf (stderr, "%s does not support streaming i/on",dev_name); exit (EXIT_FAILURE); } CLEAR (cropcap); cropcap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; //VIDIOC_CROPCAP:查询驱动的修剪能力 if (0 == xioctl (fd, VIDIOC_CROPCAP, &cropcap)) { crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; crop.c = cropcap.defrect; if (-1 == xioctl (fd, VIDIOC_S_CROP, &crop)) { switch (errno) { case EINVAL: break; default: break; } } }else { } CLEAR (fmt); /*采集信号的type width height 帧格式*/ fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; fmt.fmt.pix.width = 320; fmt.fmt.pix.height = 240; fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_YUYV; //V4L2_PIX_FMT_JPEG;//V4L2_PIX_FMT_YUYV; // fmt.fmt.pix.field = V4L2_FIELD_INTERLACED; //VIDIOC_S_FMT:设置当前驱动的频捕获格式 if (-1 == xioctl (fd, VIDIOC_S_FMT, &fmt)) errno_exit ("VIDIOC_S_FMT"); init_mmap (); } static void close_device (void) { if (-1 == close (fd)) errno_exit ("close"); fd = -1; close(fbfd); } static void open_device (void) { struct stat st; if (-1 == stat (dev_name, &st)) { fprintf (stderr, "Cannot identify '%s': %d, %sn",dev_name, errno, strerror (errno)); exit (EXIT_FAILURE); } if (!S_ISCHR (st.st_mode)) { fprintf (stderr, "%s is no devicen", dev_name); exit (EXIT_FAILURE); } //open framebuffer fbfd = open("/dev/fb0", O_RDWR); if (fbfd==-1) { printf("Error: cannot open framebuffer device.n"); exit (EXIT_FAILURE); } //open camera fd = open (dev_name, O_RDWR| O_NONBLOCK, 0); if (-1 == fd) { fprintf (stderr, "Cannot open '%s': %d, %sn",dev_name, errno, strerror (errno)); exit (EXIT_FAILURE); } } static void usage (FILE * fp,int argc,char ** argv) { fprintf (fp, "Usage: %s [options]nn" "Options:n" "-d | --device name Video device name [/dev/video]n" "-h | --help Print this messagen" "-t | --how long will display in secondsn"
上一篇:OK6410A 开发板 (八) 8 linux-5.11 OK6410A System.map 解析
下一篇:OK6410A 开发板 (八) 6 linux-5.11 OK6410A 详细解析 从 u-boot 的 theKernel 到 linux的 start_kernel
推荐阅读最新更新时间:2024-11-13 13:36
设计资源 培训 开发板 精华推荐
- LT1270CT 演示板、具有停机功能的铃音电源、+5Vin 至隔离式 +100V/-100Vout
- L6562AD 过渡模式 PFC 控制器的典型应用
- STM32F411RET最小系统原理图
- 使用 Analog Devices 的 LTC3890-3 的参考设计
- ESP32_0.91OLED模拟辉光钟_桌面时钟
- AM30EW-2403SZ 3.3V 三路输出 DC/DC 转换器的典型应用
- LTC2155-14 演示板,14 位,170Msps,1.8V 双路 ADC,DDR LVDS 输出,5-140MHz
- 【训练营_进阶班】基于ESP8266的HomeKit物联网开关
- TS9010KCX5 RF 2.5mA, 1.5V CMOS LDO with Enable 典型应用电路
- LTC3109EUF 演示板、自动极性、超低电压升压转换器和电源管理器
