-boot移植(十一)---代码修改---支持nandflash
发布者:sjjawx831最新更新时间:2023-06-08 来源: elecfans关键字:nandflash  擦除 手机看文章 扫描二维码
随时随地手机看文章
一、移植前的修改
1.1 include/configs/jz2440修改
  原来的定义:
  可以看出,要先定义CONFIG_CMD_NAND才能使能NANDFlash。
  这个在我们文件中的82行有定义,所以不需要定义了。
  将里面的S3C2410全部改为S3C2440:
1.2 drivers/mtd/nand/修改
  拷贝s3c2410_nand.c 成  s3c2440_nand.c
  在此目录的makefile中添加 s3c2440_nand.c
  修改s3c2440_nand.c 文件,从board_nand_init 逐行检测修改,代码如下:
  1 #include
  3 #include
  4 #include
  5 #include
  7 /* NFCONF 寄存器定义 */
  8 #define S3C2440_NFCONF_EN          (1<<15)
  9 #define S3C2440_NFCONF_512BYTE     (1<<14)
 10 #define S3C2440_NFCONF_4STEP       (1<<13)
 11 #define S3C2440_NFCONF_INITECC     (1<<12)
 12 #define S3C2440_NFCONF_nFCE        (1<<1)
 13 #define S3C2440_NFCONF_TACLS(x)    ((x)<<12)
 14 #define S3C2440_NFCONF_TWRPH0(x)   ((x)<<8)
 15 #define S3C2440_NFCONF_TWRPH1(x)   ((x)<<4)
 17 /* NFCONF 寄存器定义 */
 18 #define S3C2440_NFCONT_LOCKTIGHT                  (1<<13)
 19 #define S3C2440_NFCONT_SOFTLOCK                  (1<<12)
 20 #define S3C2440_NFCONT_ENLLLEGALINT              (1<<10)
 21 #define S3C2440_NFCONT_ENRnBINT                 (1<<9)
 22 #define S3C2440_NFCONT_Rn                         (1<<8)
 23 #define S3C2440_NFCONT_SPAREECCLOCK             (1<<6)
 24 #define S3C2440_NFCONT_MAINECCLOCK                 (1<<5)
 25 #define S3C2440_NFCONT_ECC                      (1<<4)
 26 #define S3C2440_NFCONT_nCE                      (1<<1)
 27 #define S3C2440_NFCONT_MODE                      (1<<0)
 28
 29
 32 #define S3C2440_ADDR_NALE 4
 33 #define S3C2440_ADDR_NCLE 8
 34
 35 #ifdef CONFIG_NAND_SPL
 36
 37 /* in the early stage of NAND flash booting, printf() is not available */
 38 #define printf(fmt, args...)
 39
 40 static void nand_read_buf(struct mtd_info *mtd, u_char *buf, int len)
 41 {
 42     int i;
 43     struct nand_chip *this = mtd->priv;
 44
 45     for (i = 0; i < len; i++)
 46         buf[i] = readb(this->IO_ADDR_R);
 47 }
 48 #endif
 49
 50 /* ctrl:表示做什么,选中芯片/取消片选,是发命令还是发地址
 51  * cmd :命令值或地址值
 52  */
 53 static void s3c24x0_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl)
 54 {
 55     struct s3c24x0_nand *nand = s3c24x0_get_base_nand();
 56
 57     debug("hwcontrol(): 0x%02x 0x%02xn", cmd, ctrl);
 58
 59     if (ctrl & NAND_CLE) {
 60         /* 发命令 */
 61         writeb(cmd, &nand->nfcmd);
 62     }
 63     else if (ctrl & NAND_ALE) {
 64         /* 发地址 */
 65         writeb(cmd, &nand->nfaddr);
 66     }
 67
 68 }
 69
 70 /**
 71  * nand_select_chip - [DEFAULT] control CE line
 72  * @mtd: MTD device structure
 73  * @chipnr: chipnumber to select, -1 for deselect
 74  *
 75  * Default select function for 1 chip devices.
 76  */
 77 void s3c2440_nand_select(struct mtd_info *mtd, int chipnr)
 78 {
 79     struct s3c24x0_nand *nand = s3c24x0_get_base_nand();
 81     switch (chipnr) {
 82     case -1: /* 取消选中 */
 83         nand->nfcont |= S3C2440_NFCONT_nCE;
 84         break;
 85     case 0: /* 选中 */
 86         nand->nfcont &= ~S3C2440_NFCONT_nCE;
 87         break;
 88
 89     default:
 90         BUG();
 91     }
 92 }
 93
 94 static int s3c24x0_dev_ready(struct mtd_info *mtd)
 95 {
 96     struct s3c24x0_nand *nand = s3c24x0_get_base_nand();
 97     debug("dev_readyn");
 98     return readl(&nand->nfstat) & 0x01;
 99 }
101 #ifdef CONFIG_S3C2440_NAND_HWECC
102 void s3c24x0_nand_enable_hwecc(struct mtd_info *mtd, int mode)
103 {
104     struct s3c24x0_nand *nand = s3c24x0_get_base_nand();
105     debug("s3c24x0_nand_enable_hwecc(%p, %d)n", mtd, mode);
106     writel(readl(&nand->nfconf) | S3C2440_NFCONF_INITECC, &nand->nfconf);
107 }
108
109 static int s3c24x0_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat,
110                       u_char *ecc_code)
111 {
112     struct s3c24x0_nand *nand = s3c24x0_get_base_nand();
113     ecc_code[0] = readb(&nand->nfecc);
114     ecc_code[1] = readb(&nand->nfecc + 1);
115     ecc_code[2] = readb(&nand->nfecc + 2);
116     debug("s3c24x0_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02xn",
117           mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
118
119     return 0;
120 }
121
122 static int s3c24x0_nand_correct_data(struct mtd_info *mtd, u_char *dat,
123                      u_char *read_ecc, u_char *calc_ecc)
124 {
125     if (read_ecc[0] == calc_ecc[0] &&
126         read_ecc[1] == calc_ecc[1] &&
127         read_ecc[2] == calc_ecc[2])
128         return 0;
129
130     printf("s3c24x0_nand_correct_data: not implementedn");
131     return -1;
132 }
133 #endif
134
135 int board_nand_init(struct nand_chip *nand)
136 {
137     u_int32_t cfg = 0;
138     u_int8_t tacls, twrph0, twrph1;
139     struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power();
140     struct s3c24x0_nand *nand_reg = s3c24x0_get_base_nand();
141
142     writel(readl(&clk_power->clkcon) | (1 << 4), &clk_power->clkcon);
143
144     /* 时序设置 */
145     tacls = 4;
146     twrph0 = 8;
147     twrph1 = 8;
148
149     /* 初始化时序 */
150     cfg |= S3C2440_NFCONF_TACLS(tacls - 1);
151     cfg |= S3C2440_NFCONF_TWRPH0(twrph0 - 1);
152     cfg |= S3C2440_NFCONF_TWRPH1(twrph1 - 1);
153     writel(cfg, &nand_reg->nfconf);
154
155     /* 使能NANDFLASH控制器,初始化ECC,禁止片选 */
156     writel(S3C2440_NFCONT_MODE | S3C2440_NFCONT_nCE | S3C2440_NFCONT_ECC, &nand_reg->nfcont);
157
158     /* initialize nand_chip data structure */
159     nand->IO_ADDR_R = (void *)&nand_reg->nfdata;
160     nand->IO_ADDR_W = (void *)&nand_reg->nfdata;
161
162     nand->select_chip = s3c2440_nand_select;
163
164     /* hwcontrol always must be implemented */
165     nand->cmd_ctrl = s3c24x0_hwcontrol;
166
167     nand->dev_ready = s3c24x0_dev_ready;
168
169 #ifdef CONFIG_S3C2410_NAND_HWECC
170     nand->ecc.hwctl = s3c24x0_nand_enable_hwecc;
171     nand->ecc.calculate = s3c24x0_nand_calculate_ecc;
172     nand->ecc.correct = s3c24x0_nand_correct_data;
173     nand->ecc.mode = NAND_ECC_HW;
174     nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE;
175     nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES;
176     nand->ecc.strength = 1;
177 #else
178     nand->ecc.mode = NAND_ECC_SOFT;
179 #endif
180
181 #ifdef CONFIG_S3C2440_NAND_BBT
182     nand->bbt_options |= NAND_BBT_USE_FLASH;
183 #endif
184
185     return 0;
186 }
 修改过程如下:
 1 u-boot-2016.05commonboard_r:board_init_r函数中的初始化序列init_sequence_r中的:
 2 initr_nand
 3     nand_init
 4         nand_init_chip
 5             board_nand_init
 6                 设置nand_chip结构体, 提供底层的操作函数
 7             nand_scan
 8                 nand_scan_ident
 9                     nand_set_defaults
10                         chip->select_chip = nand_select_chip;
11                         chip->cmdfunc = nand_command;
[1] [2]
关键字:nandflash  擦除 引用地址:-boot移植(十一)---代码修改---支持nandflash
上一篇:平台设备驱动之平台驱动
下一篇:分析uboot移植第一阶段的各种代码
推荐阅读最新更新时间:2024-11-12 01:09
u-boot-2014.10移植(4)识别dm9000
在smdk2440.h里面注释掉CS8900相关的 #if 0 #define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ #define CS8900_BASE 0x19000300 #define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ #endif #if !defined(CONFIG_DRIVER_CS8900) #define CONFIG_DRIVER_DM9000 1 #def
[单片机]
移植u-boot-1.1.6之NOR的支持
u-boot-1.1.6里面默认配置文件里面支持的nor型号是 1 #if 0 2 #define CONFIG_AMD_LV400 1 /* uncomment this if you have a LV400 flash */ 3 #endif 4 #define CONFIG_AMD_LV800 1 /* uncomment this if you have a LV800 flash */ 而我们使用的nor flash不是LV400/LV800; 我们使用的芯片是MX29LV160DB,但是uboot里面没有,而有相近的AM29LV040B,这是需要借助数据手册仿写一个 MX29LV160DB特性有: 大
[单片机]
2.3NandFlash的操作
1.NandFlash分类: 2.MLC和SLC对比: 3.信号引脚: Nandflash的读: 页读:页地址 随机读:页地址+列地址 今天是要实现页读:需要页的地址。 我们来看芯片手册K9F2G08U0A.pdf:找到桉叶读的工作原理图: 寄存器NFCONT: 在这个寄存器里的【1】位: 上面就是选择操作nandflash的位: nandflash的statue寄存器: 第四位: 清除RB:第四位为1是,清除RB。 接下来是发送的操作: 寄存器: 发送: NFDATA: 主方法: Make:编译 要实现nandf
[单片机]
2.3<font color='red'>NandFlash</font>的操作
关于stm32的flash的擦除的理解
最近消化 正点原子《STM32不完全手册》—— 第三十一章 FLASH模拟EEPROM实验 时,对判断FLASH是否需要擦除的语句有点不理解,度娘了才知:FLASH擦除后字节存储的数据是0XFF void STMFLASH_Write(u32 WriteAddr,u16 *pBuffer,u16 NumToWrite) { u32 secpos; //扇区地址 u16 secoff; //扇区内偏移地址(16位字计算) u16 secremain; //扇区内剩余地址(16位字计算) u16 i; u32 offaddr; //去掉0X08000000后的地址 if(W
[单片机]
STM32 FLASH擦除、写入以及防止误擦除程序代码
编译环境:(Keil)MDK4.72.10 stm32库版本:STM32F10x_StdPeriph_Driver_3.5.0 一、本文不对FLASH的基础知识做详细的介绍,不懂得地方请查阅有关资料。   对STM32 内部FLASH进行编程操作,需要遵循以下流程:   1、FLASH解锁;   2、清除相关标志位;   3、擦除FLASH(先擦除后写入的原因是为了工业上制作方便,即物理实现方便);   4、写入FLASH;   5、锁定FLASH; 实例: #define FLASH_PAGE_SIZE ((uint16_t)0x400) //如果一页为1K大小 #define WRITE_START_ADDR ((uin
[单片机]
STM32 FLASH<font color='red'>擦除</font>、写入以及防止误<font color='red'>擦除</font>程序代码
S3C6410移植u-boot-2010.3(6)回顾总结
  经过半周的制作,我的OK6410总算是成功在我自己构建的uboot上运行系统了。   在此回顾一下整个过程的大纲。   一、成功编译的开始   1、下载一份未经过处理的uboot   2、精简uboot中不用到的文件,保留相似的芯片6400的板级文件   3、对精简后的uboot进行初次编译,顺便可以检查工具链、uboot的完整性   4、通过创建目录、拷贝、修改的方式,创建出初始的6410的板级文件、Makefile等   5、对自己创建的6410进行初次编译,产生的错误一般是拷贝的文件内容未进行更改,修复后一般能正常编译   二、基本启动信息的修改   1、修改汇编入口代码/cpu/arm1176/start.S,
[单片机]
S3C6410移植u-boot
  1、下载uboot http://ftp.denx.de/pub/u-boot/   2、解压文件 tar xvf u-boot-latest.tar.bz2   3、进入uboot根目录、接着开始修改文件   4、创建板级文件目录 cd /borad/samsung mkdir smdk6410   5、复制smdk6400文件到创建的文件目录 cp smdk6400/* smdk6410/   6、修改目录下的文件名 cd smdk6410 mv smdk6400.c smdk6410.c mv smdk6400_nand_spl.c smdk6410_nand_spl.c   7、修改板级文件内容
[单片机]
u-boot移植(八)---代码修改---存储控制器--MMU
一、MMU介绍 1.1 虚拟地址与物理地址   建立两个应用程序,hello1.c和hello2.c,然后运行:   hello1.c      hello2.c      运行结果如下:      可以看到两个结果打印的地址是一样的,都为 0x601040,这说明两段程序都运行于同一个地址中。我们的死循环程序又保证了两个程序在同时运行。      对于2440来说,如下图:      CPU只管发出地址,读写数据。不管地址是否是物理地址还是虚拟地址。   写程序的时候,链接地址也没有物理地址和虚拟地址。链接地址是CPU看到的,是从CPU的角度来说的。 1.2 虚拟地址转换成物理地址   对与ARM来说,虚拟地址(VA)
[单片机]
u-<font color='red'>boot</font><font color='red'>移植</font>(八)---代码修改---存储控制器--MMU
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
