u-boot-1.1.6 设置新分区支持设备树
发布者:boyatang最新更新时间:2023-06-13 来源: elecfans关键字:u-boo  设备树 手机看文章 扫描二维码
随时随地手机看文章
在u-boot命令行执行mtaparts命令
mini2440 :> mtdparts
device nand0 , # parts = 4
#: name                    size                         offset        mask_flags
0: bootloader           0x00040000      0x00000000       0            // 256K
1: params                0x00020000      0x00040000       0            // 128K
2: kernel                  0x00200000      0x00060000       0            //  2M
3: rootfs                   0x0fda0000       0x00260000       0            //  -
当使用高版本kernel或者BootLoader时发现编译出来的bin文件都很大, 加上设备树的支持, 现在重新规划分区
0: bootloader           0x00080000      0x00000000       0      // 512K
1: device_tree          0x00010000     0x00080000       0      // 64K
1: params                0x00010000      0x00090000       0      // 64K
2: kernel                  0x00500000      0x000a0000       0      // 5M
3: rootfs                   0x0fda0000       0x0085a0000       0      // -
需要修改的内容:
(1)文件系统分区
#define CONFIG_BOOTARGS    "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0" ->    // rootfs分区offset变成了4
#define CONFIG_BOOTARGS    "noinitrd root=/dev/mtdblock4 rw init=/linuxrc console=ttySAC0,115200"
(2)启动参数
原来启动执行bootm kernel
现在变成  bootm 0x30007FC0 - 0x32000000
其中0x30007FC0 是内核地址, 0x32000000   是设备树加载地址
#define CONFIG_BOOTCOMMAND "nand read.jffs2 0x30007FC0 kernel; bootm 0x30007FC0" ->    //
#define CONFIG_BOOTCOMMAND "nand read.jffs2 0x30007FC0 kernel; nand read.jffs2 32000000 device_tree; bootm 0x30007FC0 - 0x32000000"
(3)环境变量offset由0x40000 变成0xa0000
#define CFG_ENV_OFFSET      0x40000 ->
#define CFG_ENV_OFFSET      0xa0000
(4)MTDPARTS_DEFAULT
#define MTDPARTS_DEFAULT
                "mtdparts=nandflash0:256k@0(bootloader),"
                "128k(params),"
                 "2m(kernel),"
                 "-(root)"
变成
#define MTDPARTS_DEFAULT "mtdparts=nandflash0:512k@0(bootloader),"
                          "64k(device_tree),"
                           "64k(params),"
                           "5m(kernel),"
                            "-(root)"
最后一点:u-boot怎么把device_tree传递给kernel呢?
由r2寄存器
内核启动时:
theKernel (0, bd->bi_arch_number, bd->bi_boot_params);
theKernel = (void (*)(int, int, uint))30008000);
三个参数分别是r0,  r1, r2
原来这三个参数分别是
* mov r0, #0
* ldr r1, =362       // machine-id
* ldr r2, =0x30000100
* mov pc, #0x30008000
根据启动参数bootm 0x30007FC0 - 0x32000000
判断获取最后一个参数传递给r2,即可
在do_bootm_linux函数最后添加如下代码:
if (argc == 4) {
        of_flat_tree = (char *) simple_strtoul(argv[3], NULL, 16);
        if  (be32_to_cpu(*(ulong *)of_flat_tree) == OF_DT_HEADER) {
            printf ("nStarting kernel with device tree at 0x%x...nn", of_flat_tree);
            cleanup_before_linux ();
            theKernel (0, bd->bi_arch_number, of_flat_tree);
        } else {
            printf("Bad magic of device tree at 0x%x!nn", of_flat_tree);
添加头文件
#include
关键字:u-boo  设备树 引用地址:u-boot-1.1.6 设置新分区支持设备树
上一篇:nand flash相关
下一篇:u-boot-1.1.6移植之dm9000
推荐阅读最新更新时间:2024-10-30 22:18
基于S3C2410嵌入式设备U-Boo移植及自启动的实现
  S3C2410是三星公司针对嵌入式系统推出的高性价比 微处理器 ,它是基于ARM9TDMI内核的16/32位RISC处理器,工作主频为200M Hz 。由于现有的Linux系统引入了设备文件的概念,读写串口可以像读写普通文件一样进行操作,非常方便。   一、Linux系统的安装   安装过程首先出现欢迎对话框,如上图所示。Red Hat先后会询问用户使用何种语言、用户使用的键盘类型(默认选项为美式键盘)以及安装软件的位置(选择本地CD -ROM)等许多需用户选择的问题。   使用Disk Druid建立Linux文件系统然后通过PC机对开发板进行设置,并执行以下命令,从而对开发板进行内核及文件系统的烧写工作:
[单片机]
基于S3C2410嵌入式<font color='red'>设备</font>的<font color='red'>U-Boo</font>移植及自启动的实现
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
