讲init进程的启动过程从/etc/inittab出发。
内核启动init进程时已经打开/dev/console设备作为控制台,一般情况下Busybox init程序就使用/dev/console,
如果内核启动init进程的同时设置了环境变量CONSOLE或console,则使用环境变量所指定的设备。
1、/etc/inittab文件的相关文档和示例代码都在Busybox 的examples/inittab文件中。
vi examples/inittab
内容如下(红色字为格式重要部分):
# /etc/inittab init(8) configuration for BusyBox #/etc/inittab #init进程启动的第一个子进程,它是一个脚本,可以在里面指定用户想执行的操作 #比较挂接其他文件系统、配置网络等 ::sysinit:/etc/init.d/rcS #启动shell,以/dev/ttySAC0作为控制台 ttySAC0::askfirst:-/bin/sh #按下Ctrl+Alt+Del之后执行的程序,不过在串口控制台中无法输入Ctrl+Alt+Del组合键 ::ctrlaltdel:/sbin/reboot #重启、关机前执行的程序 ::shutdown:/bin/umount -a -r
# Copyright (C) 1999-2004 by Erik Andersen
# Note, BusyBox init doesn't support runlevels. The runlevels field is
# completely ignored by BusyBox init. If you want runlevels, use sysvinit.
# Format for each entry:
# The id field is used by BusyBox init to specify the controlling tty for
# the specified process to run on. The contents of this field are
# appended to "/dev/" and used as-is. There is no need for this field to
# be unique, although if it isn't you may have strange results. If this
# field is left blank, it is completely ignored. Also note that if
# BusyBox detects that a serial console is in use, then all entries
# containing non-empty id fields will be ignored. BusyBox init does
# nothing with utmp. We don't need no stinkin' utmp.
# restart, ctrlaltdel, and shutdown.
# Note: askfirst acts just like respawn, but before running the specified
# process it displays the line "Please press Enter to activate this
# console." and then waits for the user to press enter before starting
# the specified process.
# Note: unrecognised actions (like initdefault) will cause init to emit
# an error message, and then go along with its business.
# Note: BusyBox init works just fine without an inittab. If no inittab is
# found, it has the following default behavior:
# ::sysinit:/etc/init.d/rcS
# ::askfirst:/bin/sh
# ::ctrlaltdel:/sbin/reboot
# ::shutdown:/sbin/swapoff -a
# ::shutdown:/bin/umount -a -r
# ::restart:/sbin/init
# if it detects that /dev/console is _not_ a serial console, it will
# also run:
# tty2::askfirst:/bin/sh
# tty3::askfirst:/bin/sh
# tty4::askfirst:/bin/sh
# Boot-time system configuration/initialization script.
# This is run first except when booting in single-user mode.
# /bin/sh invocations on selected ttys
# Note below that we prefix the shell commands with a "-" to indicate to the
# shell that it is supposed to be a login shell. Normally this is handled by
# login, but since we are bypassing login in this case, BusyBox lets you do
# this yourself...
# Start an "askfirst" shell on the console (whatever that may be)
::askfirst:-/bin/sh
# Start an "askfirst" shell on /dev/tty2-4
tty2::askfirst:-/bin/sh
tty3::askfirst:-/bin/sh
tty4::askfirst:-/bin/sh
# /sbin/getty invocations for selected ttys
tty4::respawn:/sbin/getty 38400 tty5
tty5::respawn:/sbin/getty 38400 tty6
# Example of how to put a getty on a serial line (for a terminal)
#::respawn:/sbin/getty -L ttyS0 9600 vt100
#::respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#::respawn:/sbin/getty 57600 ttyS2
# Stuff to do when restarting the init process
# Stuff to do before rebooting
2、仿照Busybox 的examples/inittab 文件,创建一个inittab文件,内容如下:
上一篇:构建根文件系统(3)编译、安装Busybox、安装glibc
下一篇:构建根文件系统(1)Linux root filesystem目录结构
推荐阅读最新更新时间:2024-11-17 06:32
设计资源 培训 开发板 精华推荐
- stm32最小系统
- 适用于工业应用的 C8051F523A MCU 的 C8051F530ADK、8051 开发系统
- STM32F411RET
- 用于计量的模拟放大
- NCP1076DIPGEVB,用于离线 SMPS 评估板的 20W 高压开关稳压器
- NCN5140REF4TGEVB:KNX 系统级封装 4 按钮触摸墙壁开关参考设计
- AL5811 60V 线性、75mA 可调电流 LED 驱动器的典型应用,用于低侧电流 LED 设置
- GPU内核电源RT8809双相PWM控制器典型应用
- 使用 ROHM Semiconductor 的 BD49L46G-TL 的参考设计
- LTM8029 演示板、36VIN、600mA 降压模块转换器,具有 5A 静态电流
- TI MCU 推新了!八月直播揭秘新特性~报名观看赢好礼!
- 考眼力:高速数字设计的秘籍 藏在哪里? 走近Keysight PATHWAVE,提升工作效率
- 英飞凌ADAS解决方案,确保您每一次安全出行 参与赢好礼!
- 有奖直播|是德科技感恩月—遇见KeysightCare - 贵重仪器安全避坑指南
- 解锁【W5500-EVB-Pico】,探秘以太网底层,得捷Follow me第4期来袭!
- 【备战国赛】干货文集限时免积分下载,别错过哦~
- 【社区大讲堂】顶嵌与你一起:动手做嵌入式产品
- “赞一赞我的国”:集合啦,侃侃好用的国产单片机
- 艾睿电子&ADI有奖直播:无需光耦的flyback隔离电源设计
- 意法半导体工业峰会2023 直播结束
