本文介绍了LM49155主要指标,简化方框图以及典型应用电路。LM49155是NS 公司的高度集成的PowerWise音频子系统,集成了噪音抑制麦克风放大器,1.35W单声道带ALC的D类放大器,带AGC的AB类耳机驱动器,带开关机声抑制的高效立体声参考地耳机放大器以及I2C模式选择和音量控制。主要用于手机和手提电子设备。
Uplink Noise Suppression & Downlink SNR Enhancement Analog Audio Subsystem
The LM49155 is a fully integrated audio subsystem designed for portable handheld applications such as cellular phones. The LM49155 combines a Noise Suppression microphone amplifier, a 1.35W mono class D amplifier with ALC, class AB earpiece driver with AGC, a high efficiency, stereo, ground referenced headphone amplifier with click pop suppression and I2C modes select and volume control.
The LM49155 features analog fully differential input, and differential output microphone amplifier designed to reduce background acoustic noise, while delivering superb speech clarity in voice communication applications. Downlink SNR enhancement with an advanced acoustic AGC technology to adjust output levels.
The LM49155 speaker amplifier features National’s unique output limiter that provides both a no-clip feature and speaker protection. The E2S class D amplifier features a patented, ultra low EMI PWM architecture that significantly reduces RF emissions while preserving audio quality and efficiency. The headphone drivers feature National’s ground referenced architecture that creates a ground-referenced output from a single, low-voltage supply.
The LM49155 is available in an ultra-small 36-bump micro SMD package (3.434mm x 3.459mm x 0.6mm).
LM49155主要指标:
■ Uplink Far Field Noise Suppression Electrical FFNSE at f = 1kHz 34dB (typ)
■ Downlink SNR Enhancement Earpiece Amplifier
Near-Field SNR Enhancement 6 to 18dB (typ)
Downlink SNRIE 16dB (typ)
■ Class D Loudspeaker Amplifier RL = 15μH+8Ω+15μH
POUT, THD+N ≤ %, VDD = 5.0V 1.35W (typ)
■ Headphone Amplifier RL = 32Ω
POUT, THD+N ≤ %, HPVDD = 1.8V 19mW (typ)
LM49155主要特性:
■ Noise cancellation for uplink and downlink without DSPtype artifacts, distortions or delays
■ Adapting AGC on ambient noise level & downlink signal strength for earpiece
■ Downlink adjustable noise-reducing high pass filter
■ E2S Class D Amplifier with ALC
■ Ground Referenced Headphone Outputs with Advanced Click Pop Suppression
■ Micro-power shutdown
LM49155应用:
■ Mobile Phones
■ Portable Electronic Devices
图1。LM49155简化方框图
图2。LM49155典型应用框图
编辑:神话 引用地址:LM49155设计的PowerWise降噪音频功率放大技术
LM49155主要指标:
LM49155主要特性:
LM49155应用:
■ Mobile Phones
图1。LM49155简化方框图
图2。LM49155典型应用框图
上一篇:TDA1517ATW设计的8W BTL音频功率放大技术
下一篇:基于TI的OMAP平台手持设备语音应用解决方案
- 热门资源推荐
- 热门放大器推荐
小广播
热门活动
换一批
更多
最新模拟电子文章
更多精选电路图
更多热门文章
更多每日新闻
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
更多往期活动
11月16日历史上的今天
厂商技术中心
