The Si3480 is a power manager intended for use with the Si3452 Power over Ethernet (PoE) controller. The Si3480 enables the use of a smaller, lower cost, and more efficiently-utilized power supply in an unmanaged PoE Power Sourcing Equipment (PSE) system.
The Si3452 is capable of delivering over 30 W per port, which means that, in a typical 8-port system, a 240 W power supply would have to be used to avoid overload. Typically, not all ports are used at full power; so, a smaller power supply in the range of 30 to 150 W can be used along with the Si3480 power management controller.
The Si3480 power management controller is pin programmed. The pins are used to set the power supply capacity, the number of low power (category 1, 15.4 W), and high power (category 2, 30 W) ports, the port priority, and the detection timing (Alternative A or Alternative B). The Si3480 uses the real time overload and current monitoring capability of the Si3452 to manage power for up to eight ports. Power management is based on actual consumption rather than mere classification in order to supply power to the greatest number of ports.
The Si3480 also provides LED drive to indicate port status and drive an LED bar graph display to indicate the power supply capacity in use. If a port is denied power due to power supply capacity limitations, the LED indicators provide a simple and intuitive indication, helping a user recognize and correct the overload situation by rebalancing loads or adding mid-span power injectors to ports that would not otherwise be powered. In case of a port overload, the port is easily re-enabled by disconnecting the Powered Device (PD) and then reconnecting the PD after correcting the overload situation.
Si3480主要特性:
Enables use of a smaller power supply for a 4 or 8 port PoE system
Self-contained solution operates without the need for a host for unmanaged operation
No software required
No data isolation required
Fully compliant with IEEE 802.3 clause 33 for Power over Ethernet including the 802.3at amendment for higher power (30 W category 2 ports)
Pin programmable for overall power supply capacity, port power level, port priority, and detection timing
LED indication of port status and overall power consumption
20-pin Quad flat package (4x4 mm)
4x4 mm PCB footprint; RoHS compliant
Extended operating temperature range (–40 to +85℃)
图1。Si3480功能方框图
图2。Si3480典型应用电路图
上一篇:LCD背光及对比度调节
下一篇:基于UBA2028设计的600V荧光灯电源技术
- 热门资源推荐
- 热门放大器推荐
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
- 欧盟铁了心推动USB-C成标准:2年过渡期
- 罗永浩又要做手机?本人发声:明年春天见
- 王腾秀出Redmi Note 11:极致性价比
- 荣耀Play5活力版官宣:即刻来电、天生敢造,10月25日上市
- Redmi Note 11/Pro系列官宣:平直边框设计,于10月28日发布
- 索尼PS5国行捆绑套装今晚预售:价格4787元
- 苹果关闭了iOS 15.0.1验证通道:不允许用户降级了
- 真我GT Neo2T首发天玑1200 AI 首款智能手表T1价格699
- OPPO Reno5/Pro+ 5G开始ColorOS 12×Android 12升级内测招募
- AGM G1新系列户外旗舰发布会定于10月28日:重370克,厚23毫米
