基于UBA2028设计的600V荧光灯电源技术
最新更新时间:2011-05-09来源: 互联网 手机看文章 扫描二维码
随时随地手机看文章
The UBA2028 is a high voltage power IC that drives and controls electronically ballasted
Compact Fluorescent Lamps (CFLs). The IC includes a Metal-Oxide-Semiconductor
Transistor (MOST) half-bridge power circuit, a dimming function, a high voltage level shift
circuit, an oscillator function, a lamp voltage monitor, a current control function, a timer
function and various protections.
UBA2028主要特性和优势:
编辑:神话 引用地址:基于UBA2028设计的600V荧光灯电源技术
上一篇:基于Si3480设计的PoE电源管理技术
下一篇:基于FAN6862设计的40W笔记本电脑电源技术
小广播
Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php
Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php
更多每日新闻
随便看看
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
