基于FAN6862设计的40W笔记本电脑电源技术
最新更新时间:2011-05-09来源: 互联网 手机看文章 扫描二维码
随时随地手机看文章
The FAN6862 is designed for SMPS and integrates a frequency-hopping function that helps reduce EMI emission of a power supply with minimum line filters.
The built-in synchronized slope compensation is proprietary sawtooth compensation for constant output power limit over universal AC input range. The gate output is clamped at 18V to protect the external MOSFET from over-voltage damage.
Other protection functions include VDD over-voltage protection and over-temperature protection. For overtemperature protection, an external NTC thermistor can be applied to sense the ambient temperature. When VDD OVP or OTP is activated, an internal latch circuit latches off the controller.
FAN6862主要特性:
编辑:神话 引用地址:基于FAN6862设计的40W笔记本电脑电源技术
上一篇:基于UBA2028设计的600V荧光灯电源技术
下一篇:PT4201设计的离线式LED射灯技术
小广播
最新电源管理文章
换一换 更多 相关热搜器件
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
