MIC2829是Micrel公司的高度集成的电源管理集成电路(PMIC),设计用于3G/4G (HEDGE/LTE 与WiMAX) USB无线应用. MIC2829是完整的电源管理解决方案,能给处理器,双路标准的RF(如HEDGE/LTE 或WiMAX)收发器,功率放大器,存储器, USB-PHY相关的I/O接口和其它系统要求提供电源.输入电压为2.7V-5.5V,有六个DC降压稳压器,两个PWM降压稳压器和11个LDO.主要应用在4G LTE USB调制解调器,3G/4G (HEDGE/LTE)无线芯片组,WiMAX调制解调器,Express卡调制解调器,UMPC/笔记本电脑无线数据通信以及手提设备.本文介绍了MIC2829主要特性,方框图, 典型应用框图及其材料清单, MIC2829 评估板电路图和所用板材料清单(BOM).
3G/4G HEDGE/LTE PMIC with Six Buck Converters, Eleven LDOs and SIM Card Level Translation
The MIC2829 is a highly integrated Power Management Integrated Circuit (PMIC) designed for 3G/4G (HEDGE/LTE and WiMAX) USB wireless applications. It is a complete power management solution which provides power to processors, dual standard RF (such as HEDGE/LTE or WiMAX) transceivers and power amplifiers, memory, USB-PHY associated I/O interfaces and other system requirements.
The MIC2829 incorporates six DC/DC buck converters, eleven LDOs and digital level shifters for SIM Card support inside a single package. Four of the six integrated DC/DC buck converters incorporate HyperLight Load TM (HLL) technology. Each of these buck regulators operate at high switching speed in PWM mode (4MHz/2.5MHz) and maintain high efficiency in light load conditions. The high speed PWM operation allows the use of very small inductors and capacitors minimizing board area while the HLL mode enables 87% efficiency at 1mA. HyperLight Load TM technology also has unmatched load transient response to support advance portable processor requirements.
The remaining two DC/DC buck converters support 100% duty cycle operation and can deliver greater than 96% efficiency. This allows pre-regulation of system LDOs for high efficiency power system partitioning.
The MIC2829 has eleven low dropout regulators (LDOs). Five general purpose LDOs provide low dropout, excellent output accuracy of ±3% and only require 40 µA of ground current for each to operate. The remaining six are high performance Low Noise Regulators (LNRs) provide high PSRR and low output noise for sensitive RF subsystems. Each LNR requires only 20 µA of ground current to operate. The MIC2829 also has three high speed level shifters for digital SIM Card signal translation and a 50mA SIM power supply.
The MIC2829 is available in a 76-pin 5.5mm x 5.5mm LGA package with an operating junction temperature range from –40℃ to +125℃.
MIC2829主要特性:
Input voltage range: 2.7V to 5.5V
Six DC Step-Down Regulators
Four HyperLight LoadTM step-down regulators
- Low quiescent current – typical 40 µA
- DC1: 4MHz / 1000mA
- DC2: 4MHz / 300mA (with voltage scaling)
- DC3: 2.5MHz / 600mA
- DC4: 4MHz / 600mA (with adjustable delay POR)
Two PWM step-down regulators
- DC5 and DC6: Fixed 2MHz / 800mA
- 100% duty cycle
Eleven Low Dropout Regulators (LDOs)
Five general purpose 200mA LDOs (LDO1-4, LDO11)
- LDO3: 38mV dropout at 100mA
- LDO2 and LDO4: 80mV dropout at 100mA
- LDO1 and LDO11: 115mV dropout at 100mA
- Output accuracy ± 3%
- 40µA ground current
Six high performance 200mA LNRs (LDO5-10)
- High PSRR 70dB at 1kHz
- Low noise: 20 µV RMS
- 40mV dropout at 100mA
- 20µA ground current
SIM card level translator
SIM card power supply (50mA)
Thermal shutdown and current limit protection
UVLO – under voltage lockout protection
–40℃ to +125℃ operating junction temperature range
MIC2829应用:
• 4G LTE USB modems
• 3G/4G (HEDGE/LTE) wireless chipsets
• WiMAX modems
• Express card modems
• UMPC/notebook PC wireless data communications
• Portable applications
图1.MIC2829功能方框图
图2.MIC2829典型应用框图
典型应用材料清单(BOM):
MIC2829评估板
图3.MIC2829 评估板电路图
MIC2829 评估板材料清单(BOM):
编辑:神话 引用地址:基于MIC2829设计的3G-4G USB无线应用电源技术
MIC2829主要特性:
- 100% duty cycle
MIC2829应用:
• 4G LTE USB modems
• WiMAX modems
图1.MIC2829功能方框图
图2.MIC2829典型应用框图
典型应用材料清单(BOM):
MIC2829评估板
图3.MIC2829 评估板电路图
上一篇:什么是软切换?为什么高效率电源都要做软切换
下一篇:有源和无源滤波器混合并行方案在铁路牵引站谐
- 热门资源推荐
- 热门放大器推荐
小广播
热门活动
换一批
更多
最新电源管理文章
更多精选电路图
更多热门文章
更多每日新闻
- NXP 2.5亿美元收购Aviva,但车载SerDes领域依然处于战国时期
- 应对 AI 时代的云工作负载,开发者正加速向 Arm 架构迁移
- 沉浸式体验漫威宇宙,英特尔锐炫显卡为《漫威争锋》提供Day 0支持
- 艾迈斯欧司朗与法雷奥携手革新车辆内饰,打造动态舱内环境
- 《嵌入式-STM32开发指南》第二部分 基础篇 - 第7章DMA(HAL库)
- 【“源”察秋毫系列】DC-DC电源效率测试,确保高效能与可靠性的关键步骤
- NVIDIA 推出高性价比的生成式 AI 超级计算机
- Mapbox与Arm合作推出虚拟主机 加速软件定义汽车导航
- 移植tslib和Qt5.6到三星s5pv210开发板
- 智能座舱新赛点在哪? 看这四款重磅新车
更多往期活动
厂商技术中心
