Linear 公司的LTR3741是大功率恒流恒压20A降压电源控制器,输入电压VIN从6V到36V,输出电压高达VIN-2V,稳压精度1.5%,稳流精度±6%,效率高达94%,主要应用在通用工业领域,超电容充电,恒压或恒流源。本文介绍LTR3741主要特性,方框图,以及典型应用电路,包括10V/20A恒压恒流降压转换器电路图,20A超电容充电器电路图,20A LED驱动器电路图以及10A单个锂离子电池充电器电路图等。
LT3741-High Power, Constant Current, Constant Voltage, Step-Down Controller
The LTR3741 is a fixed frequency synchronous step-down DC/DC controller designed to accurately regulate the output current at up to 20A. The average current-mode controller will maintain inductor current regulation over a wide output voltage range of 0V to (VIN – 2V). The regulated current is set by an analog voltage on the CTRL pins and an external sense resistor. Due to its unique topology, the LT3741 is capable of sourcing and sinking current. The regulated voltage and overvoltage protection are set with a voltage divider from the output to the FB pin. Soft-Start is provided to allow a gradual increase in the regulated current during startup. The switching frequency is programmable from 200kHz to 1MHz through an external resistor on the RT pin or through the use of the SYNC pin and an external clock signal.
Additional Features include an accurate external reference voltage for use with the CTRL pins, an accurate UVLO/EN pin that allows for programmable UVLO hysteresis, and thermal shutdown.
LTR3741主要特性:
Control Pin Provides Accurate Control of Regulated Output Current
1.5% Voltage Regulation Accuracy
±6% Current Regulation Accuracy
6V to 36V Input Voltage Range
Wide Output Voltage Range Up to (VIN – 2V)
Average Current Mode Control
<1μA Shutdown Current
Up to 94% Efficiency
Additional Pin for Thermal Control of Load Current
Thermally Enhanced 4mmx 4mm QFN and 20-Pin FE Package
LTR3741应用:
General Purpose Industrial
Super-Cap Charging
Applications Needing Extreme Short-Circuit Protection and/or Accurate Output Current Limit
Constant Current or Constant Voltage Source
图1。LTR3741方框图
图2。LTR3741 10V/20A恒压恒流降压转换器电路图
图3。LTR3741 5V稳压输出的20A超电容充电器电路图
图4。LTR3741 20A LED驱动器电路图
图5。LTR3741 10A单个锂离子电池充电器电路图
上一篇:DC-DC转换器的电源转换效率和功率电感性能的解决
下一篇:基于MAX17014的低成本LCD TV电源解决方案
- 热门资源推荐
- 热门放大器推荐
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
- 薯片公司疑意外曝光Xbox Series X价格:超5500元
- 三星下代旗舰Galaxy S21/S21+电池信息揭秘
- 荣耀将在9月16日推猎人游戏本:搭载Intel Core i7
- LG K52渲染图揭秘:挖孔屏+后置四摄的入门机
- 目前没有计划将AirPlay 2与HomeKit带到2018款电视
- 消息人士:iPhone XR 会于明年春季被 iPhone 12s 代替
- GoPro Hero 9 Black参数揭秘:支持5K拍摄电池容量大幅提升
- AirPods Pro 2概念设计:加入Retina HD屏幕能显示信息
- 外媒称:迹象表明 Mac 将加入 Face ID 功能
- stm32之ADC oled显示
