Abstract: When does input bias current become a concern? Which architecture offers the lowest offset voltage? This application note introduces common op-amp input structures with their associated design advantages and challenges.
Operational amplifier (op amp) inputs vary widely in structure and performance. This document presents common op-amp input structures. By using the Electrical Characteristics table, the op amps are identified by type and part number.
Each op amp structure type offers its own advantages and disadvantages. Therefore, Maxim will continue to introduce op amps with a variety of configurations to optimize each product for its intended application. Table 1 below lists the various types used, some of which are very common while others are represented by only one or two examples in our product line.
Table 1. Op Amp Input: Types and Parameters
The bipolar PNP has been Maxim's most common input because of its inherently low offset and single-supply operation. The bipolar rail-to-rail stage is, however, challenging the PNP version for customer use, and now constitutes more than 50% of our new op amp products. The remaining input stages shown in the table account for less than 20% of our op amp product line.
Generally if customers are looking for low offset voltage, they will have to use one of the bipolar input stages. If high impedance is needed, the application will require a CMOS input stage. If the application requires a JFET input stage, a CMOS-type op amp might satisfy the criteria. Maxim currently offers few op amps with JFET input stages, and those devices are very high priced.
Most of Maxim's op amps can be identified using the above table as a guide. Compare the offset voltage, the bias current, and the offset current to determine which of the above categories is the closest match for an application.
编辑:神话 引用地址:运算放大器的输入-Operational Amplifier
Type | VOS | IB | IOS | TCIB | Comments |
Bipolar PNP | 100µV to 2mV | 100nA to 1µA | 10% IB | < 20% |
Bipolar NPN | 10µV to 1mV | 100nA to 1µA | 10% IB | < 20% |
Bipolar Rail to Rail | 500µV to 5mV | ±100nA to 1µA | 50% IB | < 40% |
CMOS p-Channel | 350µV to 20mV | ±10pA to 1nA | IB | 10x per 30°C |
CMOS n-Channel | 350µV to 20mV | ±10pA to 1nA | IB | 10x per 30°C |
CMOS Rail-to-Rail | 1mV to 20mV | ±10pA to 1nA | IB | 10x per 30°C |
Bipolar NPN with IB Cancellation | 100µV to 200µV | ±10nA to 100nA | 50% IB | < 40% |
Bipolar Current-Mode Feedback | 500µV to 5mV | ±100nA to 10µA (IN+ only) | NA | < 40% |
JFET Op Amp | 500µV to 2mV | ±10pA to 1nA | IB | 10x per 50°C | |
Active Input Offset Cancellation | 1µV to 25µV | ±10pA to 100pA | IB | ~ 0 |
上一篇:电流限制电路的降压稳压器-Current-Limit Cir
下一篇:监测一小步变化的直流电压-Monitoring a Smal
- 热门资源推荐
- 热门放大器推荐
小广播
热门活动
换一批
更多
最新电源管理文章
更多精选电路图
更多热门文章
更多每日新闻
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
更多往期活动
11月16日历史上的今天
厂商技术中心
