基于AD5421设计的回路供电工业过程控制技术
最新更新时间:2011-10-26来源: 互联网关键字:AD5421  回路供电  控制技术 手机看文章 扫描二维码
随时随地手机看文章
本文介绍了AD5421主要特性, 功能方框图,和HART调制解调器连接框图以及应用框图.
ADI公司的AD5421是完整的16位4mA-20mA转换器,包括用来给自身和发送器中其它器件供电的稳压器,输出电压从1.8V到12V,漂移为5ppm/℃.器件还包括精密的1.25V和2.5V基准电压源. AD5421采用标准的HART FSK协议通信,串口速率高达20Mbps,主要应用在工业过程控制,4-20mA回路供电发送器以及智能发送器.
16-Bit, Serial Input, Loop-Powered, 4mA to 20mA DAC
The AD5421 is a complete, loop powered, digital to 4mA-to-20mA converter, designed to meet the needs of smart transmitter manufacturers in the Industrial Control industry.It provides a high precision, fully integrated, low cost solution in a compact TSSOP package.
The AD5421 includes a regulated voltage output that is used to power itself and other devices in the transmitter. This regulator provides a regulated 1.8V to 12V output voltage. The device also contains precision 1.25V and 2.5V references, The AD5421 thus eliminates the need for a discrete regulator and voltage reference.
The AD5421 can be used with standard HART FSK protocol communication circuitry without any degradation in specified performance. The high speed serial interface is capable of operating at 20 Mbps and allows for simple connection to commonly-used microprocessors and microcontrollers via a SPI compatible three-wire interface.
The AD5421 is guaranteed monotonic to 16-bits, offers 0.0015% integral nonlinearity, 0.03% offset error and 0.03 % gain error.
The AD5421 is available in a 28 lead TSSOP package and is specified over the extended industrial temperature range of –40℃ to +105℃.
AD5421主要特性:
16-Bit Resolution and Monotonicity
Pin selectable NAMUR Compliant Ranges
4mA to 20mA
3.8mA to 21mA
3.2mA to 24mA
NAMUR Compliant ALARM Currents
Downscale ALARM current = 3.2mA
Upscale ALARM Current = 22.8mA/24mA
0.05% maximum Total Unadjusted Error (TUE)
0.0015% maximum INL Error (15 Bits minimum)
5ppm/℃ typ Output Drift
350uA maximum Quiescent Current
Flexible SPI Compatible Serial Digital Interface
Schmitt Triggered Inputs
On-Chip Fault Alerts via FAULT pin or ALARM Current
Loss of SPI Interface Control
SPI Communication Error (Packet Error Check)
Programmed Loop Current out of Range
Insufficient Loop Voltage
Over Temperature
Automatic Readback of Fault Register on each write cycle
Slew Rate Control Function
Gain and Offset Adjust Registers
On-Chip Reference (10 ppm/℃ Max)
Selectable Regulated Voltage Output
Loop Voltage Range
5.5V to 52V
Temperature Range: -40℃ to +105℃
TSSOP Package
HART Compatible
AD5421应用:
Industrial Process Control
4-20mA Loop Powered Transmitter
Smart Transmitter
图1.AD5421功能方框图
图2.AD5421和HART调制解调器连接框图
图3.AD5421应用框图
关键字:AD5421  回路供电  控制技术 编辑:神话 引用地址:基于AD5421设计的回路供电工业过程控制技术
上一篇:基于AS8002设计的太阳能电源逆变技术
下一篇:几种电话线馈电电路原理介绍及设计
推荐阅读最新更新时间:2023-10-13 10:55
Telvent的控制技术被BP Solar选中
英国石油(BP)子公司BPSolarInternational选中Telvent控制技术,将运用逾BPSolar的环球营运中心方案。
[新能源]
现代为混合动力车研全球首个换挡主动控制技术 提升燃油经济性
(图片来源:现代汽车集团) 据外媒报道,现代汽车集团(Hyundai Motor Group)研发出了全球首个换挡主动控制(ASC)变速箱技术。该项创新技术每秒对换挡操作监测500次,能够优化传动效率,精确调整变速箱转速,更好地完成换挡。此外,即将上市的新款现代索纳塔混合动力车型将首次搭载该项技术,最终其他即将上市的现代和起亚混合动力车型都将配备该技术。 ASC将新型控制逻辑软件应用于混合动力控制单元(HCU),然后控制电机,以调整发动机和变速箱的转速,将换挡时间减少了30%。此外,该技术还能够在更短时间内完成换挡的同时,保证换挡操作顺畅平滑。 创新:独立研发的控制逻辑软件应用于电机 为了进一步提高燃油经济
[汽车电子]
现代为混合动力车研全球首个换挡主动<font color='red'>控制技术</font> 提升燃油经济性
无处不在的运动控制技术才是真正的节能减排利器
作为一家全球技术领导企业,ABB致力于通过领先的技术、负责任的运营和合作关系助推低碳社会发展,减缓全球变暖和减轻气候变化可能带来的破坏性后果。在世界环境日即将来临之际,ABB将展示一系列有助于打造低碳社会的最新技术、解决方案和应用案例,介绍ABB如何以技术创新推动行业的可持续发展。 戚鲁平 ABB运动控制事业部中国区总裁 基于130多年的创新经验,ABB运动控制业务提供世界领先的工业电机,以及用于确保这些电机以更优效率运行的变频器,让客户能够提高能效、增强安全性和可靠性,并保持对其过程的精确控制。我们将丰富的运动控制产品与数字化解决方案及服务相对接,支持中国用户进一步优化性能、系统效率和节能效果,推动各行业加速能源转型和
[嵌入式]
无处不在的运动<font color='red'>控制技术</font>才是真正的节能减排利器
应用DSP重复控制技术在逆变电源系统中的应用
本文提出一种DSP重复控制的控制方案,利用重复控制器来跟踪周期性参考指令信号,减小输出电压谐波,同时电流环控制改善系统的动态性能。并根据该控制方案,设计和调试了一台基于DSP TMS320LF2407A控制的单相1kW逆变器,仿真和实验结果均验证了该方案的良好性能。 重复控制的基本理论 重复控制是基于内模原理的一种控制思想。它的内模数学模型描述的是周期性的信号,因而使得闭环控制系统能够无静差地跟踪周期信号。单一频率的正弦波是典型的周期信号,它的数学模型为   那么只要在控制器前向通道串联上与输入同频率的正弦信号,就可以实现系统的无静差跟踪。重复控制也多用数字控制方式。离散后的重复控制内模为:   式中:N为一个周期的采
[电源管理]
应用DSP重复<font color='red'>控制技术</font>在逆变电源系统中的应用
无传感器交流电动机控制技术提高了运行效率
在家用电气市场领域,全球范围的节能和节水呼声非常高。政府法令和建议条款正在重新定义一个节能和合理高效使用能源的时代。为了满足政府的政策规定,以及降低系统成本,应用设计工程师正在使用高性能的数字信号控制器(DSC)。 基于数字信号控制技术的控制方案使用一个具有 MCU 功能的数字信号处理器,用于控制 电动机 的供电,这种方案能够非常容易的在单芯片上实现。此外,灵活的外围设备也可以令设计工程师非常方便地实现各种各样的功能。使用可调速电动机驱动器让设计工程师有机会设计更多非常复杂和精确的控制程序,并可以增强设备的性能,同时又能提高能效。 绝大多数家用电气中电动机所用的 电子 驱动器的控制是非常简单的,要么使用固定恒速电动机
[嵌入式]
ADI:电机控制技术再开市场潜能
环保和绿色能源是我国七大新兴战略型产业之一,而电机的能耗占用电设备的20%左右。电机作为各电子设备中必不可少的元件,电机控制以及其在家电领域、工业领域和汽车电子领域的发展现状及未来发展方向,成为当下一个热门话题。随着工业4.0、无人机、智能机器人、汽车电子等市场的兴起,电机的重要性再次引起了人们的关注。 ADI公司亚太区电机与电源控制行业市场部经理 于常涛 ADI公司亚太区电机与电源控制行业市场部经理于常涛认为: 相应的处理器、功率模块、电流检测模块或控制算法的趋势主要表现在以下方面。 就处理器而言,ARM架构,作为通用化的处理器平台,以其优越的性价比,越来越被工业控制用户广泛使用。针对电机的控制功
[电源管理]
ADI:电机<font color='red'>控制技术</font>再开市场潜能
基于现场总线控制技术的转炉煤气回收自控系统
  1 引言   莱钢炼钢厂1#~3#转炉煤气回收自控系统于98年12月投产。该自控系统承担着将三座转炉吹炼时产生的大量的转炉煤气净化、合理化分析后进而加以回收再 利用的自动化控制任务。   但随着投运时间的推移,该系统暴露出的问题越来越突出:控制硬件/软件老化、过时--plc为西门子s5-135u,工控机为老式的奔腾166机型,编程 软件、监控软件分别为基于dos的step5和fix;控制方式落后--plc与现场信号的连接均采用传统的硬线连接方式,通讯网络为sinec-h1 网,详见图1;系统的故障率逐年上升,严重制约着生产的顺行。因此,对该控制系统进行全面的更新,以使其能够迅速满足生产的需求变得十分必要。莱钢自动化部技术
[嵌入式]
基于PIC单片机的SPWM控制技术
引言 在UPS等电力电子设备中,控制方法是核心技术。早期的控制方法使得输出为矩形波,谐波含量较高,滤波困难。SPWM技术较好地克服了这些缺点。目前SPWM的产生方法很多,汇总如下。 1)利用分立元件,采用模拟、数字混和电路生成SPWM波。此方法电路复杂,实现困难且不易改进; 2)由SPWM专用芯片SA828系列与微处理器直接连接生成SPWM波,SA828是由规则采样法产生SPWM波的,相对谐波较大且无法实现闭环控制; 3)利用CPLD(复杂可编程逻辑器件)设计,实现数字式SPWM发生器; 4)基于单片机实现SPWM,此方法控制电路简单可靠,利用软件产生SPWM波,减轻了对硬件的要求,且成本低,受外界干
[工业控制]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
