基于MLX90129的13.56MHz RFID设计方案
最新更新时间:2013-11-25来源: 互联网关键字:MLX90129  RFID 手机看文章 扫描二维码
随时随地手机看文章
MLX90129是Melexis公司的13.56MHz 传感器标签/数据采集IC,它把用于外部电阻传感器的精密数据采集和广泛外设组合在一起,存取和控制通过ISO15693 RFID前端或主/从SPI端口进行,除了13.56MHz调谐天线外不需要其它元件. MLX90129具有带存取保护的4kb EEPROM,以及单独使用的数据采集模式,主要用在冷链监视,财产管理和监视,建筑物自动化以及工业,医疗和住宅区控制与监视.本文介绍MLX90129主要特性,方框图,应用方框图,以及多种应用框图和MLX90129 评估板框图,电路图和材料清单(BOM).
MLX90129: 13.56MHZ SENSOR TAG / DATALOGGER IC
The MLX90129 combines a precise acquisition chain for external resistive sensors, with a wide range of interface possibilities. It can be accessed and controlled through its ISO15693 RFID front-end or via its SPI port.Without any other component than a 13,56MHz tuned antenna, it becomes a RFID thermometer.
For measuring others physical quantities, one or two resistive sensors can be connected to make batteryless sensing point. In this tag mode, the chip can supply a regulated voltage to the other components of the application.
Adding a battery will enable the use of the standalone data logging mode. The sensor output data is stored in the internal 3.5kbits user memory. One can extend the storage capacity by connecting an external E2PROM to the SPI port.
The SPI port can also connect the MLX90129 to a microcontroller which allows more specific applications, like adding actuating capability or RF transmission.
The MLX90129 has been optimized for low power, low voltage battery and battery-less applications.
MLX90129主要特性和优势:
Versatile A/D interface for resistive sensors
ISO-15693 13.56MHz transponder
Slave / Master SPI interface
4 k-bit EEPROM with access protection
Standalone data-logging mode
Ultra low power
Battery or battery-less applications
Low cost and compact design
MLX90129应用:
Cold chain monitoring
Asset management and monitoring (security and integrity)
Building automation
Industrial, medical and residential control and monitoring
图1.MLX90129方框图
图2.MLX90129应用方框图
图3.MLX90129 RFID多传感器标签框图
图4.MLX90129数据采集框图
图5.MLX90129基于MCU的应用框图
MLX90129 评估板
The EVB90129 is an assembled printed circuit board that simplifies evaluation of the MLX90129 sensor tag IC and to facilitate the development of wireless sensor applications based on the MLX90129.
The EVB90129 was developed to demonstrate a wide range of applications, from fully passive sensor tag operation to complex data logging. Each of its elements can be reconfigured by means of jumpers.
The board can be powered either by an external voltage supply, the on-board battery or the electromagnetic field from a RFID reader.In addition to the internal temperature sensor of the MLX90129, the EVB90129 embeds 3 external sensors, light, temperature and potentiometer to demonstrate the flexibility for measurement of a variety of physical quantities. The custom prototyping area allows users to integrate their own sensor or circuit into this evaluation board.
The EVB90129 is capable of storing 128 Kbytes of datas in the SPI EEPROM memory connected to the MLX90129. The EVB90129 can be accessed and controlled through a contactless (RFID) or a contact (SPI) interface. The RFID access to the MLX90129 and the related commands are compliant with the ISO15693 standard. The SPI and other digital inputs/outputs from the MLX90129 are connected to an 8-pin connector of the EVB90129. This allows easy connection to a microcontroller.
图6.MLX90129 评估板外形图
图7.MLX90129 评估板框图
图8.MLX90129 评估板电路图
MLX90129评估板材料清单(BOM):
关键字:MLX90129  RFID 编辑:神话 引用地址:基于MLX90129的13.56MHz RFID设计方案
上一篇:基于线阵CCD的图像和位置传感系统
下一篇:TANDBERG推出个人网真解决方案EX90
推荐阅读最新更新时间:2023-10-12 20:53
英飞凌全新Secora Pay RFID,更轻,更快,更环保
为了支持支付行业在智能卡上使用更环保的材料,英飞凌开发了一种全新射频识别非接触式支付卡天线。现在提供了一个完整、单一来源的射频识别模块,该模块很容易适用在利用木质纸板、海洋废弃物中回收的塑料所制造的RFID卡上。 英飞凌的Secora Pay采用了Coil-on-Module (CoM) RFID封装,以及最新开发的天线,专门为从海洋回收的塑料或木材制成的信用卡所设计。这种创新的双接口芯片封装技术旨在增加智能卡的耐用性和鲁棒性。这是全行业最薄的支付模块,可进行低成本制造和大规模部署。 通过英飞凌经过现场验证的感应耦合即插即用封装技术制造的 CoM DIF卡可为客户提供从基于接触到非接触过渡的智能解决方案。CoM封装以
[网络通信]
英飞凌全新Secora Pay <font color='red'>RFID</font>,更轻,更快,更环保
RFID在物流和供应链中的应用
目标的快速识别对于快速处理物流过程具有决定性的意义,这也需要通过提高效率来降低成本。RFID技术可以在物流和供应链 当中提供新的应用机会,传感器专业厂家Sick公司将为这些新的用途提供合适的产品和解决方案。SICK传感器是以光电器件作为转换元件的传感器。它可用于检测直接引起光量变化的非电量,如光强、光照度、辐射测温、气体成分分析等;也可用来检测能转换成光量变化的其他非电量,如零件直径、表面粗糙度、应变、位移、振动、速度、加速度,以及物体的形状、工作状态的识别等。光电式传感器具有非接触、响应快、性能可靠等特点,因此在工业自动化装置和机器人中获得广泛应用。近年来,新的光电器件不断涌现,特别是CCD图像传感器的诞生,为SICK传感器的进
[模拟电子]
<font color='red'>RFID</font>在物流和供应链中的应用
RFID 无线感测网路复杂事件处理新趋势
  由于微机电技术的发展,使得微小的感测器也能具有无线通讯的能力。相关的应用常是为了收集不同或高量的资料而布建大规模的感测器,例如将数万的感测器散布于森林中作为火灾的判定;或将感测器节点布建在房屋中做为人体健康的监测。在WSAN (Wireless Sensor Area Network)环境中,为数众多的感测节点所产生出的大量事件,必定会让整个系统效能有所延迟,并且如何有效管理这些事件,能更有效的快速产生回应,已成为重要的议题。     事件驱动架构    毫无疑问地,不论个人或组织,每天都不断面临到新事件的发生与其采取的对策,这个过程即所谓的事件驱动,而事件驱动架构,则是根据自身的能力与经验值,去反应这个世界上任何一个对他
[网络通信]
RFID洗涤系统设计与实现
  射频识别即RFID(Radio Frequency IDentification)技术,又称电子标签、无线射频识别,是一种通信技术,可通过无线电讯号识别特定目标并读写相关数据,而无需识别系统与特定目标之间建立机械或光学接触。   1、系统概述   本系统将RFID技术应用于对衣物个体的识别与管理。基于超高频(UHF) RFID技术,实现洗衣行业快速收衣、分拣、全自动盘点、取衣的高效工作平台,大大提高工作效率、降低出错率。   本智能洗衣应用系统与传统的人工管理比较具有以下的优点:   1)减少人工管理工作,使用方便快捷;   2) 提高工作效率和经济效益,节约人员费用支出,降低成本;   3) 全自动设计,提高服务
[网络通信]
冷温激光技术 引领数码标签打印新趋势
    在Print China 2011同期(2011年4月9日),第三届标签技术高峰论坛成功举办。此次论坛主题为“数字技术引领标签产业未来”,中国印刷及设备器材工业协会高级顾问、标签印刷分会名誉理事长谭俊峤主持。在论坛上,经纶科技(深圳)有限公司市场经理刘渊女士进行了题为“冷温技术与数码标签的完美结合”的演讲,从目前的标签市场分析着眼,向与会业界同仁讲述了当下标签与主流数字化技术的关联情况,并首次公开展示了经纶科技优秀的冷温激光打印产品的独特技术以及其成熟的市场表现。     领先冷温技术 带来数码标签打印新形势     通过介绍冷温激光技术的基本原理,刘渊向大家展示了以法国NIPSON系列黑白激光数码印刷机、欣泰ST
[网络通信]
基于MF RC500型读卡器的无源RFID系统设计
摘 要:在对射频识别(RFID)系统的组成和原理进行分析的基础上,提出基于Philips公司MF RC500型读卡器和AT89S51型单片机实现的射频识别读写器的设计方法。首先介绍RFID系统的组成及MF RC500的特性.接着给出由AT89S51型单片机和MF RC500构建无源RFID系统的原理设计,以及对Mifare S50卡的读写流程。 关键词:射频识别技术;读卡器;MF RE500;单片机;AT89S51;RFID标签 1 引言 RFlD是射频识别技术(Radio Frequency denti-fieation)的英文缩写,又称电子标签,是一项利用射频信号通过空间耦合(交变磁场或电磁场)实现无接触信息传递并通过所
[应用]
基于ATMEGA64L和TRH031M的RFID读卡器设计
概述 RFID(无线射频识别技术)作为一种新兴的非接触自动识别技术,通过射频信号自动识别目标对象并获取相关数据,可识别高速运动物体,可同时识别多个标签,可工作于恶劣环境,操作快捷方便,在物流、交通、收费、身份识别等众多领域有广泛应用。RFID技术在国外发展的很快,RFID产品种类很多,像TI, MOTOROLA,PHILIPS等世界著名厂商都生产RFID产品,并且它们的产品各有特点,自成系列。目前,中国射频识别技术及应用处于初级发展阶段。RFID技术作为一种新兴的自动识别技术,也已开始在国内应用,并且应用领域越来越广。 本文把RFID技术应用到物流系统中,实现了基于RFID技术的物流系统的软硬件原型。 系统硬件设
[单片机]
基于ATMEGA64L和TRH031M的<font color='red'>RFID</font>读卡器设计
奥地利微电子推出全新的HF RFID读卡器IC
  奥地利微电子公司日前发布AS3910 HF RFID读卡器 IC。AS3910拥有出类拔萃的功效和天线自动调谐功能,完美适用于采用PCB天线的各类便携式应用及产品。   AS3910 HF RFID读卡器IC的电源电压为3.3V时,输出功率达1W,是同类产品的4倍。AS3910还整合了正在申请专利的天线自动调谐功能,适合于各种极富挑战性的环境。   片上自动调谐意味着生产过程中或现场不再需要人工调整天线。谐振频率的动态自动调整范围达10%,现场有许多金属时用户可在系统问题上花费更少的时间。这可以使用户的产品更快进入市场,并将更多精力集中在创建基于AS3910的自有独特IP上。   芯片包含了ISO 14443
[模拟电子]
小广播
最新模拟电子文章
换一换 更多 相关热搜器件
