脉宽调制直流电动机控制电路 Pulse Width Modulation DC Motor Control
Often, people attempt to control DC motors with a variable resistor or variable resistor connected to a transistor. While the latter approach works well, it generates heat and hence wastes power. This simple pulse width modulation DC motor control eliminates these problems. It controls the motor speed by driving the motor with short pulses. These pulses vary in duration to change the speed of the motor. The longer the pulses, the faster the motor turns, and vice versa.
Schematic
Parts
Part
Total Qty.
Substitutions
R1
1 Meg 1/4W Resistor
R2
100K Pot
C1
0.1uF 25V Ceramic Disc Capacitor
C2
0.01uF 25V Ceramic Disc Capacitor
Q1
IRF511 MOSFET
IRF620
U1
4011 CMOS NAND Gate
S1
DPDT Switch
M1
Motor (See Notes)
MISC
Case, Board, Heatsink, Knob For R2, Socket For U1
1. R2 adjusts the speed of the oscillator and therefore the speed of M1.
2. M1 can be any DC motor that operates from 6V and does not draw more than the maximum current of Q1. The voltage can be increased by connecting the higher voltage to the switch instead of the 6V that powers the oscillator. Be sure not to exceed the power rating of Q1 if you do this.
3. Q1 will need a heatsink.
4. Q1 in the parts list can handle a maximum of 5A. Use the IRF620 for 6A, if you need any higher.
上一篇:简单的直流电机PWM调速电路
下一篇:步进电机控制器电路
- 热门资源推荐
- 热门放大器推荐
- 泰克有奖看视频 深入浅出剖析高速信号的抖动和眼图
- 据说,来挑战的都是“老司机”,TE答题排位赛火热进行中,不服来战!
- 力源&安森美有奖直播:RSL15 - 安森美更高效更智能更安全的 BLE 5.2 蓝牙芯片
- 注册泰克MDO示波器礼券 拿蓝牙耳机和纤细激光笔!
- 有奖直播:迈来芯消费级超低功耗位置传感器,简化设计降低成本
- 畅游安富利人工智能云会展,挑战60天打卡学习养成记!冲击华为Mate40 Pro、Apple iPad Air等豪礼啦!
- 阅读并了解 TE Connectivity 无创想,不奇迹 精彩专题,答题有礼!
- 年味大比拼,新春晒照赢好礼罗
- 有奖直播|安森美图像传感器,助力汽车、机器视觉和人工智能领域发展
- TE Connectivity 小有乾坤蕴藏无限可能
