ZMDIZLED7330电源效率98%低成本LED驱动方案
最新更新时间:2011-08-27来源: chinaaet关键字:源管理  DC/DC转换器  LED驱动器 手机看文章 扫描二维码
随时随地手机看文章
ZMDI公司的ZLED7330 LED驱动器的电源效率达到98%,主要为高亮和大电流LED而设计. ZLED7330具有三种模式来决定输出电平,输出电流高达1.2A,内部集成了40V功率开关,DC输入电压从8.5V到40V,输出电流精度5%,LED开路保护和热关断保护.本文介绍了ZLED7330主要特性和优势,以及几种基本应用电路.
The ZLED7330 continuous-mode inductive step-down converter family is one of our ZLED LED control ICs. It is designed for applications requiring high brightness and high current. The ZLED7330 can efficiently drive a single LED or multiple series-connected LEDs from a voltage input higher than the LED forward voltage (Vin = 8.5 to 40VDC). It provides an adjustable output current (1.0A maximum), which is set via an external resistor and controlled by the ZLED7X30’s integrated high-side output current-sensing circuit and high speed internal 40V power switch. Its low conducting impedance ensures high system efficiency.
The ZLED7330 provides a switch dimming function. It detects external switch action to adjust output current, allowing dimming functionality to be achieved without changing the original lighting system circuitry.
The switch dimming is implemented in either two-level-mode or three-level mode. The output current of every level and the total number of levels are customer selected by setting the corresponding input conditions of DIM1 and DIM2 pin.
The ZLED7330 enables diverse industrial and consumer lighting applications requiring high driving currents, wide operating voltage range, high efficiency, and variable brightness control. It offers over-temperature and LED open-circuit protection. The ZLED7330 can also minimize bill-of-material costs because very few external components are required for most applications. Only a resistor, a diode, an inductor, and a capacitor are needed for a typical basic application.
For easy evaluation of the ZSC7330, ZMDI offers the ZSC7330 Demo Kit, which includes a cascadable test board including one 5W white High Brightness LED, 5 ZLED7330 samples in SOP-8 package and documentation. Order using part number ZLED7330KIT-D1. Additional unpopulated cascadable test boards are also available.
ZLED7330主要特性:
Switch dimming with multiple levels
Three modes for output level settings
Up to 1.2A output current
Internal 40V power switch
Wide DC input voltage range 8.5 to 40 VDC
Output current accuracy: 5% (typical)
Thermal shutdown protection
ZLED7330优势:
High efficiency: up to 98%
Very few external components needed for operation
Adds switch dimming function to existing installation
ZLED7330应用:
MR16/MR11 LED spot lights
LED street lights
parabolic aluminized reflector (PAR)
LED lights and other general purpose industrial and consumer LED applications
图1.开关调光的ZLED7330应用电路
图2.输出电流由RS决定的 ZLED7330基本应用电路
图3.采用卤钨灯电子变压器的ZLED7330应用电路
关键字:源管理  DC/DC转换器  LED驱动器 编辑:探路者 引用地址:ZMDIZLED7330电源效率98%低成本LED驱动方案
上一篇:移动电话闪光灯LED驱动电路设计
下一篇:基于SP7616的多颗LED驱动方案设计
推荐阅读最新更新时间:2023-10-18 15:37
适用于众多开关模式DC/DC拓扑
作为一名应用工程师,我知道降压稳压器的实施不可避免地要涉及效率与尺寸的权衡。尽管这一原理适用于众多开关模式  DC/DC 拓扑,但当应用需要低输出电压和高输出电流(例如 1V 和  30A)时,这一原理就不一定适用了,因为这需要可平衡效率与尺寸的小型电源解决方案。 高效率是重要的性能基准,不仅可减少功率损耗与组件温度上升,而且还可在给定气流与环境温度条件下带来更多有用功率。从这个观点来看,低开关频率非常具有诱惑力,但同时需要大型滤波器组件来满足输出纹波与瞬态响应等目标规范的要求,因此成本和尺寸会随之增加。 专门用于电源管理的 PCB  面积是系统设计人员所面临的一个巨大制约条件。对于这个问题,我们先来回顾一下高开关频率的各
[电源管理]
DC-DC转换器的电源转换效率和功率电感性能的解决方案
随着高新技术的不断研发,各种设备都已进入高端化,作为后备军,电源电路也有了较为明显的进步。具体来说,以典型的手机为例,除了原始的通话功能之外,相机、广播、电视等各种功能已经成为普遍标准的功能。这些功能的工作所需的电压各不相同,为此,电池电压必须通过电源转换电路将其电压转换成各电路正常工作所需电压。大多采用电源转换效率较高的开关控制器(通常称作DC-DC转换器)。     另外,在移动设备多功能化进程中,对机器的小型、薄型化要求也逐步提升。为此就必须减少元件的使用数量,或者将元件做到更小。此对策是借由提高DC-DC 转换器的开关频率,减小必要的功率电感和电容的额定参数值,以此来适应元件的小型化。将集中控制电源的PMIC(Powe
[电源管理]
<font color='red'>DC</font>-<font color='red'>DC转换器</font>的电源转换效率和功率电感性能的解决方案
14W高效率LED驱动器电源设计
  一、设计特色   1、作环境温度高(75度)   2、高能效   3、合EU CoC/CEC 2008/能源之星2.0要求,带载模式效率高(可达86%,要求为79.6%);在265  VAC输入时的空载输入 功率 250 mW,要求为300 mW   4、滞过热关断保护   5、载断开保护   6、足EN55015B传导 EMI 限制,EMI裕量 8 dB微伏   二、工作原理   图1所示为一个典型的20 V、14 W恒压(CV)、恒流(CV)输出的 电源电路 。 LED 阵列的光输出量与所流经的电流量成正比。因此, LED驱动 器应具有恒流输出,而不是恒压输出。在本设计中,DC输出未与AC输入隔离,因而LED阵列和
[电源管理]
14W高效率<font color='red'>LED驱动器</font>电源设计
集成MOSFET和高边电流检测的LED驱动器
     MAX16832A/MAX16832C是降压恒流高亮度LED (HB LED)驱动器,为汽车内部/外部照明、建筑和环境照明、LED灯泡和其它LED照明应用提供具有成本效益的解决方案。   MAX16832A/MAX16832C工作于+6.5V至+65V输入电压范围,在最高+125°C温度范围内可提供最大700mA的输出电流,而在最高+105°C的温度范围内可提供1A的输出电流。高边检流电阻调节输出电流,而专用的脉宽调制(PWM)输入可实现宽亮度范围的脉冲式LED亮度调节。   这些器件非常适合需要宽输入电压范围的应用。高边电流检测和内置电流设置电路减少了外部元件数量,并可提供±3%精度的平均输出电流。在负载瞬变和
[电源管理]
集成MOSFET和高边电流检测的<font color='red'>LED驱动器</font>
具有集成线圈的超小型降压DC/DC转换器
  随着手机、智能手机、便携式游戏机、数码相机、PND等便携式电子产品向多功能、小型化的方向发展,对电源管理也提出了越来越高的要求,特别是在用电池驱动时,如何有效地使用电池、延长电池的使用时间成为大家关注的焦点,因此,电源管理必须同时具有小型化和高效率的特性。DC/DC在能量转换方面有着高效率的性能,但外部的线圈却常常需要占据很大一部分空间,不利于实现产品的小型化;常用的LDO体积虽小,但在效率方面却不能令人满意。特瑞仕半导体公司日前新推出的XCL205/206/207系列产品能很好的解决这个问题。   XCL205/206/207拥有DC/DC的特性,LDO的用法(图1)。   XCL205/206/207是一
[电源管理]
具有集成线圈的超小型降压<font color='red'>DC</font>/<font color='red'>DC转换器</font>
寿命和可靠性对于LED驱动器设计的重要性
1 引言 随着日益严重的能源及环境问题,全球各地正在大范围地取代传统的白炽灯灯具。虽然有很大部分是紧凑型荧光灯,但是对节能灯的灯管汞含量的关注(有可能对环境造成污染)以及更大的节能潜力需求,使越来越多的用户转向LED灯。最新的LED灯能耗不到的白炽灯能耗的80%,不含有毒物质。据市场调研公司iSuppli预计,LED相关的全球销售额将继续强劲增长的格局,尽管全球经济复苏缓慢,但估计市场将在2013年达到约146亿美元。 随着富含电子器件的节能灯的广泛使用,消费者却开始看到了这种产品的频繁失效。而LED照明的潜在寿命则会大大延长,并提供更好的可靠性。 问题存在于是否LED灯所使用的电子驱动装置也达到了同样的寿命和高可靠性?设计不良产
[电源管理]
寿命和可靠性对于<font color='red'>LED驱动器</font>设计的重要性
电源设计细节:DC-DC转换器之接地环路详解
DC-DC转换器为整个系统中的各个电路供电。尽管每个电路在测试台上可能表现很好,但系统整体性能却往往达不到各个电路的性能效果。为什么?有许多潜在因素,而系统中各个电路的整体接地系统是首要原因。设计师需要非常清楚每个电路如何接地,系统中是否存在接地环路。 当两个电路和/或系统之间存在一个以上对地连接时就构成了接地环路。重复接地通道相当于形成一个接收接口信号的环形天线(电流通过接地电阻转换成电压)。接收接地环路感应电压的后果是,随着感应电压的叠加造成系统对地基准电压不稳。这些感应噪声电压会成为整个系统响应的一部分! 此外,接地环路形成一条共用线,导致接地电流经一个以上通道回到系统对地端接地极原点。例如,多台计算机的电源通过公共办公布线
[电源管理]
电源设计细节:<font color='red'>DC</font>-<font color='red'>DC转换器</font>之接地环路详解
具有数/模转换功能的DC-DC转换器
    摘要: MAX686是一种具有数/模控制功能的新颖DC-DC转换器,它具有转换精度高、体积小、集成度高、功耗小、效率高等特点。因此,在数按电源和单片机应用电路中获得广泛应用。     关键词: 数/模转换器(DAC) DC-DC转换器  脉冲频率调制器(PFM) MAX686 1 概述     在实际应用电路中,电源的精度是很重要的,它的优劣直接影响到应用电路的性能。因此,在电路设计时,必须把电源精度作为电路设计的首要任务。     MAX686是一种具有数/模控制功能的新型DC/DC转换器,它能把正的、宽范围的输入电压(0.8~27.5V)转换成正极性或负极性的输出电压(27.5V
[应用]
小广播
最新电源管理文章
