基于ADP8863设计的带电荷泵驱动的LED驱动技术
最新更新时间:2011-09-18来源: 21ic关键字:ADP8863  电荷泵驱动  LED驱动技术 手机看文章 扫描二维码
随时随地手机看文章
ADP8863具有先进的自治的LED光特性的功1强大的电荷泵驱动器,能独立地驱动多达7个LED,每个电流高达30mA,第7个LED的驱动电流可高达60mA.电荷泵的自动增益选择有1x,1.5x 和2x,工作电压从2.5 V 到5.5 V,可驱动最大电流240mA,主要用在LED指示器,装饰指示照明,键盘照明,RGB LED色彩发生和蔼混合以及小型显示器通用照明.本文介绍ADP8863主要特性,详细方框图以及多种应用电路.
The ADP8863 combines a powerful charge pump driver with advanced autonomous LED lighting features. It allows as many as seven LEDs to be independently driven up to 30 mA (maximum). The seventh LED can also be driven to 60 mA (maximum). All LEDs are programmable for maximum current and fade in/fade out times via the I2C interface.
Additionally, automated blinking routines can be independently programmed and enabled for all seven LED channels. These LEDs can also be combined into groups to reduce the processor instructions.
This entire configuration is driven by a two-capacitor charge pump with gains of 1×, 1.5×, and 2×. The charge pump is capable of driving a maximum IOUT of 240 mA from a supply of 2.5 V to 5.5 V. The device includes a variety of safety features including short-circuit, overvoltage, and overtemperature protection. These features allow easy implementation of a safe and robust design. Additionally, input inrush currents are limited via an integrated soft start combined with controlled input-to-output isolation.
The ADP8863 is available in a compact lead frame chip scale package (LFCSP).
ADP8863主要特性:
Automated blinking and funlight timing for each LED driver
16 programmable fade in and fade out times
0.1 sec to 5.5 sec
Selectable linear, square, or cubic fade rates
7 independent and programmable LED drivers
7 drivers capable of 30 mA (maximum)
1 driver also capable of 60 mA (maximum)
Programmable maximum current limit (128 levels)
Separate and independent controls for backlight LEDs
Backlight fade override
Up to two built-in comparator inputs with programmable modes for ambient light sensing
Charge pump with automatic gain selection of 1×, 1.5×, and 2× for maximum efficiency
Standby mode for <1 μA current consumption
I2C-compatible interface for all programming
Dedicated reset pin and built-in power-on reset (POR)
Short-circuit, overvoltage, and overtemperature protection
Internal soft start to limit inrush currents
Input-to-output isolation during faults or shutdown
Operation down to VIN = 2.5 V with undervoltage lockout (UVLO) at VIN = 2.0 V
Small lead frame chip scale package (LFCSP)
ADP8863应用:
LED indication
Funlight indicator lighting
Keypad backlighting
RGB LED color generation and mixing
General backlighting of small format displays
图1.ADP8863详细方框图
图2.ADP8863典型工作电路框图
图3.ADP8863采用镇流电阻给LED供电方框图
图4.ADP8863连接到ADP8861,给更多LED供电方框图
图5.用于低Vf LED的另一种应用电路
关键字:ADP8863  电荷泵驱动  LED驱动技术 编辑:探路者 引用地址:基于ADP8863设计的带电荷泵驱动的LED驱动技术
上一篇:HV9963设计的高压LED驱动方案
下一篇:解析:LED灯泡为何昂贵,是否物有所值?
推荐阅读最新更新时间:2023-10-18 15:45
去电源一体化光源LED驱动技术分析及发展趋势
去电源化更便于 LED 灯具或光源的设计,对 LED照明 产品的普及也具有非常重要的促进作用。但如何从技术层面实现去电源化呢?去电源化技术目前会面临怎样的问题呢?未来的 LED驱动 /光源趋势与格局又是什么样的呢?以下笔者带你详细剖析。   LED产业发展到今天,随着市场和技术的成熟,其应用己全面渗透到各个领域。驱动电源作为LED产业链的一个重要组成部分,在LED的推广和快速普及化的过程中扮演了非常重要的作用。众所周知,当前LED的驱动绝大部分为点对点驱动,即一个电源驱动一个LED灯。可以说,LED产业链的成熟伴随着LED驱动的成熟。   自然界的万事万物都在向前发展,LED产业自然也离不开这个规律。LED光源在早期的推广中一直都
[电源管理]
去电源一体化光源<font color='red'>LED驱动</font><font color='red'>技术</font>分析及发展趋势
点阵式LED驱动器的技术发展趋势
  在手机和家用电器等民用机器处于全球性竞争愈演愈烈的环境中,设计上的个性化成了一个重要的因素。因此,利用形形色色的器件创造出来的设计和显示方式被人们所采用,尤其是最近伴随着LED向小型化、薄型化发展,电子装置的各种显示部分装上了LED点阵显示器,移动电话手机的键盘和机壳加上了华丽的LED装饰,设计性提高了的电子装置越来越多。另外,在白色家电领域,在相当程度上不断走向成熟的中国、印度等国市场也在向高性能化发展,许多使用了LED的显示和装饰容易使人在视觉上感到与众不同,所以需求正在扩大。 LED驱动器 的发展动向   在上述背景下,要求为LED提供电流使其点亮的装饰用LED驱动器IC,能够以更为灵活的亮灯模式控
[家用电子]
点阵式<font color='red'>LED驱动</font>器的<font color='red'>技术</font>发展趋势
LED驱动电源技术国内外研究现状及发展趋势
  在设施农业中,通常所采用的人工光源是荧光灯与高压钠灯。近年来,随着光电技术的发展,发光二极管(LED)的亮度与效率也大幅度提高,使得这种光源在设施农业生产中的应用变为可行,尤其对封闭可调控的设施农业环境(如植物工厂,组织培养室、植物生长箱等)是一种非常合适的人工光源。为此,主要介绍了LED在设施农业中的应用及发展趋势。   市景观照明追求的不是亮度,而是艺术的创意设计,LED产品应该能够找到它的用武之地。发光角度小的LED方向性强,可作局部重点照明;在封装材料中添入散射剂可以实现175度的发光角适合较大范围内的照明,问题是目前城市夜景照明中建设单位过于追求高亮度难以给设计师提供足够大的选择范围,目前在城市夜景照明工程中常用的L
[电源管理]
DAC驱动电荷泵产生可调负偏压
  图1所示电路可提供一个小电流、可调整的负偏置电压。适用于传感器偏置、LCD对比度偏压、或压控振荡器(VCO)的调谐电压。该电路利用DAC驱动一个电荷泵倍压器提供所需电压,免去了通常由运算放大器和诸多分离器件构成的庞大的电平偏移电路。   IC1双路、8位D/A转换器,具有串行接口缓冲电压输出。输出阻抗仅50Ω,用它驱动仅吸收1.1mA电流的IC2电荷泵,输出电压仅下跌50mV。当输入码在0至255变化时,DAC输出可达满电压摆幅,输出调整步长40mV。   当IC1用+5V供电而IC2输出-3V时,产生电荷泵最小输出电压(1.5V),对应代码为80(十进制)。电荷泵仅吸收0.6mA电流并能产生Vcc±2倍的输出电压
[电源管理]
DAC<font color='red'>驱动</font><font color='red'>电荷泵</font>产生可调负偏压
一种用于白光LED驱动电荷泵电路设计
0 引 言 目前用于白光驱动的升压型电路主要有电感型DC-DC电路和电荷泵电路。电感型DC-DC电路存在EMI等问题,而电荷泵电路结构简单,EMI较小,得到了广泛的应用。 白光LED驱动的电荷泵主要有两种类型:电压模式和电流模式。相对于电压模式可能造成每个LED亮度不匹配的缺点,电流模式每路单独输出恒定电流,使亮度可以较好地匹配,而且不需要外围平衡电阻,大大节省了空间。 本文设计了一种用于白光LED驱动的电流型电荷泵电路。采用1.5倍压升压,比传统的2倍压升压模式提高了效率,并采用数字调光方式,可提供32级灰度输出,满足不同场合的要求。系统结构如图1所示。主要可分为以下部分:带隙基准电路,软启动电路,振荡器,1.5倍
[应用]
面向汽车应用的LED驱动技术分析
在过去的十年里,汽车电子产品有了突飞猛进的发展,车载电子控制、车载信息服务以及娱乐系统不管是在数量上还是在精细程度上都有了显著的提高。本文将重点探讨这种成长的主要组成部分之一,即:目前以及下一代汽车中led照明使用率的飞速提高。这种新型照明领域给汽车电子产品的设计师和制造商均带来了新的挑战。了解这些挑战并找到可行的解决方案是最为重要的,因为与这些照明系统相关联的发展似乎是没有止境的。 LED照明 诸如小外形尺寸、低功耗和快速接通时间等优势开创了高亮度LED被当今汽车所广泛采用的局面。LED在汽车中的初始应用是中央高架停车灯(CHMSL);这些应用使用红光LED来提供一个非常扁薄的照明阵列,该照明阵列易于安装
[电源管理]
面向汽车应用的<font color='red'>LED驱动</font><font color='red'>技术</font>分析
技术文章—恒流LED驱动器:经济高效、可靠、使用方便
LED被广泛用于各个细分市场。尽管高功率LED需要采用复杂的驱动方案,但绝大多数应用是使用电流低于500毫安的LED,并可由线性恒流LED驱动器驱动。这些驱动器使用简单、可靠、经济高效,且不会影响EMC。本文简要介绍在实际应用中使用恒流LED驱动器时应考虑哪些设计和功率问题。 为了驱动高性能LED,有多种高端解决方案,使用具有复杂控制器的升压-降压拓扑结构,但这需要深刻理解这些拓扑才能创建可靠且符合EMC规范的设计。但是,对于中低功率LED,有一个非常简单且强大的驱动器解决方案,使用恒流LED驱动器作为一个简单的线性稳压器。从功率损耗的角度来看,恒流LED驱动器并不是理想的选择,但其出色的EMC性能、可靠性、容易实现,以
[电源管理]
<font color='red'>技术</font>文章—恒流<font color='red'>LED驱动</font>器:经济高效、可靠、使用方便
京东方重点研发有源AMOLED驱动背板技术
  OLED显示依据驱动方式不同,分为无源驱动OLED(PMOLED)和有源驱动OLED(AMOLED)两类。与PMOLED相比,AMOLED具有更大的优势和更广的应用领域。近年来的市场调查显示,虽然OLED显示市场在快速增长,但PMOLED的市场却在缩小。而OLED显示越来越频繁地出现在人们视野中,OLED显示技术越来越被接纳作为新一代平板显示技术。   积极开发非硅基TFT背板技术   与TFT-LCD的原理近似,AMOLED显示是利用对应每一个像素的薄膜晶体管(TFT)电路来控制作为像素的OLED单元发光,不同的是,AMOLED是通过控制流过OLED单元的电流发光的,因而对驱动像素的背板有着不同要求。对于AMOLED显示来说,
[手机便携]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
