SSL1623PH开关电源LED驱动方案
最新更新时间:2011-10-13来源: chinaaet关键字:电源管理  开关电源  LED驱动器 手机看文章 扫描二维码
随时随地手机看文章
NXP 公司的SSL1623PH是开关电源(SMPS)控制器,能直接从通用电压火线(80V-276V)整流电压工作,它集成了6.5Ω和650 V的功率开关,可调频率以方便设计,具有可调过流保护,以及欠压保护,温度保护和短路保护,主要用在LED镇流器,外观照明,LED点照明以及商业照明.本文介绍了SSL1623PH主要特性和优势,方框图以及典型应用电路图.
The SSL1623PH is a Switched Mode Power Supply (SMPS) controller IC that operates directly from the rectified universal AC mains. It is implemented in the high voltage Easy High Voltage Silicon-On-Insulator (EZ-HV SOI) process, combined with a low voltage Bipolar Complementary Metal Oxide Semiconductor (BiCMOS) process.
The device includes a high voltage power switch and a start-up circuit that operates directly from the rectified mains voltage. A dedicated circuit for valley switching is built in, which makes a very efficient slim-line electronic LED driver concept possible.
The SSL1623PH can operate in LED applications with a power range of up to 25 W. Applications below 15 W are more suited to the SSL152x family of mains LED drivers. In its most basic version of application the SSL1623PH acts as a voltage source. Here no additional secondary electronics are required. A combined voltage and current source can be realized with minimum costs for external components. Implementation of the SSL1623PH renders an efficient and low cost LED power supply system.
SSL1623PH主要特性和优势:
Integrated power switch: 6.5 Ω and 650 V
Operates from universal AC mains supplies, 80 V to 276 V
Adjustable frequency for flexible design
RC oscillator for load insensitive regulation loop constant
Valley switching for minimum switch-on loss
Adjustable overcurrent protection
Undervoltage protection
Temperature protection
Short-circuit winding protection
Safe restart mode for system fault conditions
Simple application with both primary and secondary (opto) feedback
16-pin DIP package
SSL1623PH应用:
LED ballasts
Contour lighting
LED spotlights
Channel letter lighting
Down lighting
Commercial lighting (retail displays)
图1.SSL1623PH方框图
图2.SSL1623PH典型应用电路图-初级检测
详情请见:
http://www.nxp.com/documents/data_sheet/SSL1623PH.pdf
关键字:电源管理  开关电源  LED驱动器 编辑:探路者 引用地址:SSL1623PH开关电源LED驱动方案
上一篇:RGB LED彩灯驱动控制方案
下一篇:LED基础知识及应用分析
推荐阅读最新更新时间:2023-10-18 15:53
苹果将采用自研电源管理芯片 Dialog真的淡定吗?
  据报道, 苹果 将于2018采用自主研发的电源管理芯片,并由台积电协助开发和生产,以取代原供应商戴乐格( Dialog  Semiconductor)的产品。对此, Dialog 发表声明表示,公司承认 苹果 内部有针对电源管理芯片设计的资源和能力。下面就随电源管理小编一起来了解一下相关内容吧。   事实上,业者人士更关心 苹果 自研电源管理芯片对于 Dialog 的业绩状况是否会有影响,毕竟目前Dialog的营收订单有超过七成来自于苹果。此事并非无的放矢,在2017年4月,苹果“抛弃”Imagination Technologies并自主研发GPU,使得Imagination Technologies不得不“卖身”求生存。
[电源管理]
DC/DC LED驱动器 提供功率超过100W
  凌力尔特公司(Linear Technology Corporation)推出同步降压-升压型DC/DC LED驱动器和电压控制器LT3791,该器件可提供超过100W的LED功率。其4.7V至60V的输入电压范围使该器件非常适用于种类繁多的应用,包括汽车、工业和建筑照明。类似地,其输出电压可设定在0V至60V,从而使LT3791能驱动多种配置的单串LED。LT3791内部的4开关降压-升压型控制器以高于、低于或等于输出电压的输入电压工作,非常适用于汽车等应用,而在这类应用中,输入电压在停止/启动、冷车发动和负载突降的情况下,可能变化很大。降压、直通和升压工作模式之间的转换是无缝进行的,因此即使电源电压变化范围很大,该器件也能
[电源管理]
DC/DC <font color='red'>LED驱动器</font> 提供功率超过100W
基于NCL30000的单段式CrM TRIAC调光LED驱动器设计
采用NCL30000的单段式CrM TRIAC调光LED驱动器设计 为了促进节能,世界各地的政府机构或规范组织制定了不同LED照明规范,主要体现在对功率因数(PF)的要求方面。如欧盟的国际电工联盟(IEC)规定了功率大于25 W照明应用的总谐波失真性能,某些地区的其它国际标准也适用这规定。 另外,美国能源部制定及发布了针对固态照明灯具的“能源之星”标准。这项自愿性标准包含针对常见住宅和商业照明灯具(如嵌灯、橱柜灯和台灯)的系列要求,涵盖最低流明输出、总体光效、可靠性目标、光色温及一系列其它关键系统级要求。值得注意的是,这个标准中并不直接包含电源能效要求,但包含功率因数要求,即不论是何种功率等级,住宅
[电源管理]
基于NCL30000的单段式CrM TRIAC调光<font color='red'>LED驱动器</font>设计
解密:TI模拟的竞争力究竟源于何处
四月的深圳,连续暴雨,Steve Anderson先生还是如期造访了深圳。作为德州仪器(以下简称 TI )高级副总裁兼全球模拟业务部总经理的他,除了一系列内部会议之外,拜访客户当然是必须的。在东莞,Steve Anderson冒雨专程去见一家初创公司 TI遍布全球的10万家客户之一。 我自己也是从初创公司里成长起来的,所以对初创公司感同身受,我能够理解他们所处的环境,知道他们要做什么,也能够理解创始人肩负的压力。当我去拜访这些初创公司时,总是能够被他们所展现出来的创业热忱,强大前进的驱动力和创新能力感到非常鼓舞。 也许是这次见面非常成功,面对EEWORLD的记者时Steve Anderson显
[模拟电子]
解密:TI模拟的竞争力究竟源于何处
美国国家半导体推出全新白光LED驱动器
美国国家半导体公司 (National Semiconductor Corporation)宣布推出一款业界最小的白光LED驱动器,可以灵活控制显示屏背光亮度。这款型号为LM3530的升压转换器属于美国国家半导体PowerWise® 高能效芯片系列,可以驱动高达11颗串联的大电流LED,能够为智能手机等便携式多媒体电子产品的大显示屏提供充足的背光。LM3530芯片采用12焊球的micro SMD封装,整个芯片的体积只有1.615mm x 1.215mm x 0.425mm大小。 由于便携式电子产品播放的多媒体内容日趋丰富多彩,配备的显示屏也越来越大,用来播放短片的时间也越来越长。相应地,这也造成耗电量的大幅增
[半导体设计/制造]
应用于交流伺服系统多路输出开关电源设计
   1.引言   与直流电机相比,交流电机不需要换向器和电刷,其结构更加简单。调速范围宽、稳态精度高、动态响应快、转子惯量小、输出功率大等诸多优点,使得交流电机在工业生产中得到较广泛地应用 。对伺服系统供电的电源性能的优劣,直接关系到整个系统的安全性和稳定性 。开关电源与低效率的线性电源相比,因为其效率高、体积小、重量轻而受到广泛地关注 。美国PI 公司生产的开关电源专用集成芯片TOPSwitch-II,是一种将PWM 和MOSFET 合二为一的新型芯片,此系列芯片以其体积小、重量轻、价格低等优势,一经推出便得到广泛的应用,展示了良好的应用前景。    2.TOPSwitch-II 工作原理   TOPSwitch-II芯片
[电源管理]
应用于交流伺服系统多路输出<font color='red'>开关电源</font>设计
最新电源管理技术和设计理念
电子书无疑是目前便携电子市场最热门的应用,那么电子书的最大竞争力和卖点是什么呢?电子书的电源设计应该注意什么?电子书的屏幕如何实现与众不同呢?怎样实现电子书的超长待机时间呢?TI半导体事业部业务拓展工程师王轶就这些大家所关注的问题一一进行了分析探讨。 王轶指出,E-book与其它电子产品的不同之处在于具有一个特殊的屏,在电子书断电之后仍可显示图像,电子书最重要的就是屏。目前电子书的屏幕技术比较单一,要实现与其他厂商的差异化就必须保证电子书有很长的寿命,不会因时间久而老化。同时,产品的优劣还可以通过液晶屏翻页显示的快慢来检验。在谈到,E-book超长待机的设计考量时,王轶指出,TI E-reader最大的卖点是超
[电源管理]
凌特高效率、紧凑型电源管理解决方案面向手持应用
凌特公司(Linear Technology Corporation)推出面向手持应用的高效率、紧凑型电源管理解决方案LTC3550。该器件采用扁平16引线3mm×5mm DFN封装,具备双输入锂离子/聚合物电池充电器和高效率同步降压型稳压器。该线性电池充电器自动地选择合适的电源,通过高达8V(绝对最大值为 10V)的墙上适配器或USB端口以高效率给单节锂离子电池充电。独立工作简化了设计,无需外部微处理器实现充电终止。该充电器利用恒定电流/恒定电压算法,从墙上适配器电源可提供高达950mA 的充电电流,而用USB电源可提供高达500mA的充电电流。最终浮动电压准确度为±0.6%。LTC3550的电池充电器配备了已获专利的热调节电路
[新品]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
