Powerint公司的高效3.8W可调光PFC LED驱动器采用LinkSwitchTM-PL系列的LNK457DG,采用非绝缘的降压拓扑,输入电压190VAC到265VAC,频率47 Hz到63 Hz,230VAC时的效率大于83.5%,PF大于0.91,THD小于25%,起动时间小于300ms,适用于住宅区照明.本文介绍了3.8W可调光LED驱动器主要特性和指标,电路图,材料清单和PCB布局图.
This document is an engineering report describing a non-isolated dimmable LED driver (power supply) utilizing a LNK457DG from the LinkSwitch-PL family of devices.
The DER-301 provides a single constant current output with an output power of 3.8 W output.
The key design goals were high efficiency, dimmable and compact size, enabling the driver to fit into candelabra and B10 sized lamps and maximize efficacy.
The board was optimized to operate over the high AC input voltage range (190 VAC to 265 VAC, 47 Hz to 63 Hz). LinkSwitch-PL based designs provide a high power factor(>0.91) meeting current international requirements.
The form factor of the board was chosen to meet the space limitations of standard Candelabra LED replacement lamps. The output is non-isolated and requires the mechanical design of the enclosure to isolate the output of the supply and the LED load from the user.
The document contains the power supply specification, schematic, bill of materials,printed circuit layout and performance data.
图1. 3.8W可调光LED驱动器外形图
3.8W可调光LED驱动器主要特性:
Single-stage power factor corrected and accurate constant current (CC) output
Dimmable
Low cost, low component count and small PCB footprint
Highly energy efficient, >83.5% at 230 VAC input for 48 V
Fast start-up time (<300 ms) – no perceptible delay
Integrated protection and reliability features
Output short-circuit protected with auto-recovery
Disconnected load protection with auto-recovery
Auto-recovering thermal shutdown with large hysteresis protects both components and PCB
No damage during brown-out conditions
PF >0.91 at 230 VAC
THD <25% at 230 VAC; 48 V LED
Meets IEC ring wave, differential line surge and EN55015 conducted EMI
3.8W可调光LED驱动器主要指标:
图2.3.8W可调光LED驱动器电路图
3.8W可调光LED驱动器材料清单:
图3.3.8W可调光LED驱动器PCB顶层布局图(直径= .68” [17.3 mm])
图4.3.8W可调光LED驱动器PCB底层布局图
详情请见:
http://www.powerint.com/sites/default/files/PDFFiles/der301.pdf
上一篇:LED背光电视终于在美国平板电视市场排名第一
下一篇:适合低压背光或闪光应用的LED驱动器方案
推荐阅读最新更新时间:2023-10-18 16:15
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- 兆易创新GD25/55全系列车规级SPI NOR Flash荣获ISO 26262 ASIL D功能安全认证证书
- 新型IsoVu™ 隔离电流探头:为电流测量带来全新维度
- 英飞凌推出简化电机控制开发的ModusToolbox™电机套件
- 意法半导体IO-Link执行器电路板为工业监控和设备厂商带来一站式参考设计
- Melexis采用无磁芯技术缩小电流感测装置尺寸
- 千丘智能侍淳博:用数字疗法,点亮“孤独症”儿童的光
- 数药智能冯尚:ADHD数字疗法正为儿童“多动症”提供更有效便捷服务
- 创实技术electronica 2024首秀:加速国内分销商海外拓展之路
- “跨芯片”量子纠缠实现 有助建构更强大的量子计算能力
