The A8514 is a multi-output white LED driver for small-size LCD backlighting. It integrates a current-mode boost converter with internal power switch and four current sinks. The boost converter can drive up to 48 LEDs, 12 LEDs per string, at 80 mA. The LED sinks can be paralleled together to achieve even higher LED currents, up to 320 mA. The A8514 can operate with a single power supply, from 5 to 40 V, which allows the part to withstand load dump conditions encountered in automotive systems.
The A8514 can drive an external P-FET to disconnect the input supply from the system in the event of a fault. The A8514 provides protection against output short and overvoltage, open or shorted diode, open or shorted LED pin, shorted boost switch or inductor, shorted FSET or ISET resistor, and IC overtemperature. A dual level cycle-by-cycle current limit function provides soft start and protects the internal current switch against high current overloads.
The A8514 has a synchronization pin that allows PWM switching frequencies to be synchronized in the range of 580 kHz to 2.3 MHz. The high switching frequency allows the A8514 to operate above the AM radio band.
A8514主要特性和优势:
• Wide input voltage range of 5 to 40 V for start/stop, cold crank and load dump requirements
• Fully integrated LED current sinks and boost converter with 60 V DMOS
• Sync function to synchronize boost converter switching frequency up to 2.3 MHz, allowing operation above the AM band
• Excellent input voltage transient response
• Single resistor primary OVP minimizes VOUT leakage
• Internal secondary OVP for redundant protection
• LED current of 80 mA per channel
• Drives up to 12 series LEDs in 4 parallel strings
• 0.7% to 0.8% LED to LED matching accuracy
• PWM and analog dimming inputs
• Provides driver for external PMOS input disconnect switch
• Extensive protection against:
▫ Shorted boost switch or inductor
▫ Shorted FSET or ISET resistor
▫ Shorted output
▫ Open or shorted LED pin
▫ Open boost Schottky
▫ Overtemperature (OTP)
A8514应用:
LCD backlighting or LED lighting for:
▫ Automotive infotainment
▫ Automotive cluster
▫ Automotive center stack
图1.A8514方框图
图2.A8514采用P-MOSFET检测和VIN接地短路保护的应用电路图
图3.A8514设计案例电路图
图4.A8514采用精密输入电流检测和VSENSE接地保护的SEPIC配置应用电路图
详情请见:
http://www.allegromicro.com/en/Products/Part_Numbers/8514/8514.pdf
上一篇:白光LED抑制温升、确保使用寿命解决方法
下一篇:冲电气成功中标全球最大自行车邮购销售商的打印管理业务
推荐阅读最新更新时间:2023-10-18 16:30
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- 从隔离到三代半:一文看懂纳芯微的栅极驱动IC
