ADI公司的ADE5166/ADE5169/ADE5566/ADE55691集成了电表模拟前端(AFE)和具有8052 MCU核,RTC和LCD驱动器以及外设的固定功能DSP解决方案.工作电压2.4V-3.7V,25度C时动态范围1000:1时的有功功率误差小于0.1%,无功功率误差小于0.5%,微处理器采用基于8052内核,8052兼容的指令集,单周期4MIps特性.本文介绍了ADE5166/ADE5169/ADE5566/ADE5569主要特性,方框图, ADE5566/ADE5569电表框图以及采用8052 MCU,RTC和LCD驱动器的单相电表评估板主要特性,电路图,材料清单和PCB布局图.
The ADE5166/ADE5169/ADE5566/ADE55691 integrate the Analog Devices, Inc., energy (ADE) metering IC analog front end and fixed function DSP solution with an enhanced 8052 MCU core, a full RTC, an LCD driver, and all the peripherals to make an electronic energy meter with an LCD display in a single part.
The ADE measurement core includes active, reactive, and apparent energy calculations, as well as voltage and current rms measurements. This information is accessible for energy billing by using the built-in energy scalars. Many power line supervisory features such as SAG, peak, and zero crossing are included in the energy measurement DSP to simplify energy meter design.
The microprocessor functionality includes a single-cycle 8052 core, a full RTC with a power supply backup pin, an SPI or I2C interface, and two independent UART interfaces. The ready-to-use information from the ADE core reduces the requirement for program memory size, making it easy to integrate complicated design into 62 kB of flash memory.
The ADE5166/ADE5169 include a 104-segment LCD driver and the ADE5566/ADE5569 include a 108-segment LCD driver, each with the capability to store up to four LCD screens in memory. This driver generates voltages capable of driving LCDs up to 5 V.
ADE5166/ADE5169/ADE5566/ADE5569主要特性:
通用特性:
Wide supply voltage operation: 2.4 V to 3.7 V
Internal bipolar switch between regulated and battery inputs
Ultralow power operation with power saving modes (PSM)
Full operation: 4.4 mA to 1.6 mA (PLL clock dependent)
Battery mode: 3.3 mA to 400 μA (PLL clock dependent)
Sleep mode
Real-time clock (RTC) mode: 1.7 μA
RTC and LCD mode: 38 μA (LCD charge pump enabled)
Reference: 1.2 V ± 0.1% (10 ppm/°C drift)
64-lead, low profile quad flat, RoHS-compliant package (LQFP)
Operating temperature range: −40℃ to +85℃
能量测量特性:
Proprietary analog-to-digital converters (ADCs) and digital signal processing (DSP) provide high accuracy active (watt), reactive (var), and apparent energy (volt-ampere (VA)) measurement
<0.1% error on active energy over a dynamic range of 1000 to 1 @ 25℃
<0.5% error on reactive energy over a dynamic range of 1000 to 1 @ 25℃ (ADE5169 and ADE5569 only)
<0.5% error on root mean square (rms) measurements over a dynamic range of 500 to 1 for current (Irms) and 100 to 1 for voltage (Vrms) @ 25℃
Supports IEC 62053-21; IEC 62053-22; IEC 62053-23; EN 50470-3 Class A, Class B, and Class C; and ANSI C12-16
Differential input with programmable gain amplifiers (PGAs) supports shunts, current transformers, and di/dt current sensors (ADE5169 and ADE5569 only) 2 current inputs for antitamper detection in the ADE5166/ ADE5169 High frequency outputs proportional to Irms, active, reactive, or apparent power (AP)
微处理器特性:
8052-based core
Single-cycle 4 MIPS 8052 core
8052-compatible instruction set
32.768 kHz external crystal with on-chip PLL
2 external interrupt sources
External reset pin
Low power battery mode
Wake-up from I/O, temperature change, alarm, and universal asynchronous receiver/transmitter (UART)
LCD driver operation with automatic scrolling
Temperature measurement
Counter for seconds, minutes, hours, days, months, and years
Date counter, including leap year compensation
Automatic battery switchover for RTC backup
Operation down to 2.4 V
Ultralow battery supply current: 1.7 μA
Selectable output frequency: 1 Hz to 16 kHz
Embedded digital crystal frequency compensation for calibration and temperature variation of 2 ppm resolution
Integrated LCD driver
108-segment driver for the ADE5566 and ADE5569
104-segment driver for the ADE5166 and ADE5169
2×, 3×, or 4× multiplexing
4 LCD memory banks for screen scrolling
LCD voltages generated internally or with external resistors
Internal adjustable drive voltages up to 5 V independent of power supply level
On-chip peripherals
2 independent UART interfaces
SPI or I2C
Watchdog timer
Power supply management with user-selectable levels
Memory: 62 kB flash memory, 2.256 kB RAM
Development tools
Single-pin emulation
IDE-based assembly and C source debugging
ADE5166/ADE5169 Functional Block Diagram
图1.ADE5566/ADE5569功能框图
图2.ADE5566/ADE5569电表框图
(ADE71xx/ADE75xx/ADE51xx/ADE55xx 系列)
The EVAL-ADE7169EBZ-2/ADE5169EBZ-2 kit includes an isolated USB-to-UART converter (ADE8052Z-DWDL1) for communication and debugging purposes. The ADE7116/ADE7166/ADE7169/ADE7566/ADE7569/ADE5166/ADE5169/ADE5566/ADE5569 (hereafter referred to as ADE71xx/ADE75xx/ ADE51xx/ADE55xx) family is supported by the IAR develop-ment environment. Evaluation software developed in LabVIEW™ provides the means to evaluate the performance of the ADE71xx/ ADE75xx/ADE51xx/ADE55xx.
The evaluation kit includes a CD that provides all of the asso-ciated documentation, tools, and drivers to set up and use the evaluation board for the ADE71xx/ADE75xx/ADE51xx/ADE55xx.
评估板主要特性:
Full evaluation kit including evaluation board hardware, evaluation software, and development tools
Supported by IAR development tools for assembly and C code development Isolated USB-to-UART communication
LabVIEW evaluation software for evaluation of meter performance LabVIEW download tools for user firmware download
Single evaluation board supports ADE7116/ADE7166/ADE7169/ADE7566/ADE7569 and ADE5166/ADE5169/ADE5566/ADE5569
EVAL-ADE7169EBZ-2 comes with ADE7169 IC installed
EVAL-ADE5169EBZ-2 comes with ADE5169 IC installed
图3.ADE71xx/ADE75xx/ADE51xx/ADE55xx评估板外形图
图4.CT传感器连接到电流通道
图5.连接两个CT到电流通道
图6.连接一个分流器和一个CT到电流通道
图7.分流器用作电流传感器
图8.评估板电路图
评估板材料清单(BOM):
图9.评估板PCB布局图
详情请见:
http://www.analog.com/static/imported-files/data_sheets/ADE5166_5169_5566_5569.pdf
和
http://www.analog.com/static/imported-files/user_guides/UG-061.pdf
上一篇:用假负载法修彩电开关电源
下一篇:TI推出集成电感器的最高密度6A电源模块
推荐阅读最新更新时间:2023-10-18 16:12
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
